Window air unit got wet now it wont turn on it worked fine before we cleaned it out now the power wont come on
  • 146 Answers
Check the circuit breaker
Posted on Jun 24, 2009
Heat pump compressor wont come on in heat mode, works fine in cool mode, we get heat occaisionally for about 2 min, then the compressor shuts off. it is a fridgedaire window unit.
Try setting the thermostat at a normal heat setting. By raising the temperature too high the unit thinks that the heat pump won't be effective and go into strip heat mode.
Nov 17, 2013 | Frigidaire Energy Star Room Air...
Goodman GSC130421ab has no voltage to contact after washing coils....it worked just before powering off unit at diconnect to clean the condenser coils
very posisble.check the fuse on the board on the indor unit. replace with equal size fuse (not bigger probably 3 amp). if the indoor unit comes on then the fuse is fine and i would suspect the coil on the contactor has shorted
Oct 02, 2012 | Goodman CKL36AR36 Air Conditioner
My AC mod#LRA257ST2 will not come on. Was working fine and just went off now it wont start. I have checked the power and it has it. Is there a fuse on the unit that may need to be reset
There are no fuses on such units, have you reset the GFI plug if it has one? Have you tried another plug or outlet? Clean the air filter and any coils or parts you can reach and retry.
Sep 02, 2012 | Frigidaire FAC126P1 wall/window Air...
When I attempt to turn the unit on, the display flashes but wont stay on
The main circuit board is bad. The circuit board can be repaired with a one year warranty. Call (336) 499-2505 for more information.
May 23, 2012 | Ecoquest Fresh Air Air Purifier
What maintance do goldstar conditions need? My cooler is not working as well and I cleaned the front filter. I'm not sure what window conditioner I have.
these units need to be cleaned every few years. so take it outside, get your garden hose; and clean the coils on both sides. front an back coils need to be clean. a coil cleaner should be used but good water presure should do fine. try not to get switches to wet. or cover them first. spray coils clean. let dry in the sun. tilt unit to get most water out then blow dry with a fan or just wait till its dry it will work like new after your done.good luck
Aug 23, 2010 | LG Goldstar GWHD5000 wall/window Air...
Bad Odor
You need to clean the indoor coils with a coil cleaner. Its probably mold that has been dormant until you turned the unit on and it became wet. Clean the indoor coil real well with an approved cleaner. Some Home Depot's carry a coil cleaner that is in a spray bottle.
Apr 11, 2009 | Frigidaire FAC107P1A Wall/Window Air...
Window air conditioner with built in heat pump
turn off the power and call a service man
Jan 04, 2008 | Heating & Cooling
My air conditioner stopped working.
lets check do you have plug something els in the outlet to check for ac curent? the cable of this unit have an overload braker? need more info but better call a tech...good luck
Aug 11, 2006 | Kenmore 6000 BTU Single Room Air...
Heating & Cooling Logo
124 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
