Question about Dell Inspiron 1100 Notebook
Won't boot up and battery and power lights flickering fast...
Hi, I was working on my dell inspiron 1100 when all of a sudden it just died. All that happens now is that the two lights on the front for the battery and the power flicker really fast. There is no response from any of the buttons and nothing starts when you press the power button...
Have you hard of this before?
  • 4 more comments
  • Hugh Law Nov 04, 2007
    When it died, it was running off AC, but now that it has died it won't turn on with either AC or battery. I have tried removing the battery and running off AC alone, but still no response...
    The lights on the front only flicker when the AC is connected, so i am presuming that the AC adapter is working fine...
    Ok, this is wierd...
    I went through all the things you suggested, battery didn't need recalled, power cord seemed ok when moved about etc...
    I played about seperating the various parts of the ac adapter, ie detaching the mains section to the part that goes in to the computer. when i put it back together again the flickering stopped. When i tried to reboot again, the flickering started as long as i was pressing the power button. Repeated the process again and this time the battery seemed to be charging, so i tried to boot the laptop up again and it seemed to work. Got as far as the windows XP boot screen and then it died again... I have a feeling that the battery has no charge left in it, so i am going to try and charge it for an hour or so and see if i can boot up then...
    I wil let you know how i get on...
  • Hugh Law Nov 05, 2007
    Ok , so this morning i switched on the laptop and everything seems to be fine again. A very strange problem indeed...
    After thinking about it a bit longer, the laptop had been sitting for quite some time unplugged from the mains so I think the battery must have been completely dead.
    However, I'm still not sure why I wouldn't be able to run of AC even if the battery was dead...
    I'll leave it for now and hopefully things will sort themselves out.
    Thanks you so much for your help, this is the first time i have used this website and I'm sure i will be back again in the future... well hopefully not...
    Best of luck,
  • heather9179 Apr 02, 2008
    I am having the same problem with my computer. It won't power up and even when plugged into the AC when power button is pushed the battery light turns on orange. Nothing else happens. Please help
  • Anonymous Aug 31, 2008
    Yes this is the same problem with my dell It was fine and next thing it wont fire up. Nothing except flashing lights from the front of the laptop when its plugged in to ac power and nothing at alll when unplugged from outlet.
  • Anonymous Dec 06, 2008
    me dell does not do anything. tried different battery and power cord. no power up and no lights not even a battery light.
    plz help
I can't installed window in my laptop dell inspiron 1100 .
Posted on Sep 29, 2008
  • 221 Answers
I would say it's overheating. It may have damaged your motherboard
Posted on Aug 15, 2008
Same problem with my inspiron 1100
piece of junk
Posted on Apr 16, 2008
Can't be sure your problem is related to your machine overheating, but as the owner of an Inspiron 1100 myself I recently found a blog with postings by an 1100 user who has taken several steps to cool down his laptop. More importantly, his blog has had literally dozens of comments posted by readers who have experienced similar overheating issues -- leading me to believe that overheating is a common problem with the 1100.
Here's the URL for the blog:
This isn't to say that in your case the battery isn't the problem. I'm just suggesting a possible alternative.
Posted on Nov 05, 2007
  • 1,601 Answers
When you start it , do you have it running on the power supply or battery? Or, does it not matter?
Posted on Nov 04, 2007
  • 3 more comments
  • Thomas Christopher
    Thomas Christopher Nov 04, 2007
    Try to measure the voltage on the charger.Use a multimeter on power supply and see if it matches the output on the plug.
    From what I am reading, overheating is a common problem.A lot of folks are very upset with Dell.
    move the power cord around slowly and see if it will bootup.
    the wire by the plug on those get worn and break.
    Also, did you know?
    On August 14, 2006, Dell announced a recall of portable system batteries. As part of the recall process, Dell continues to require its suppliers to revalidate the data which led to the recall. This has resulted in a revised list of battery serial (identification) numbers. The affected battery model numbers and date range remain unchanged.
    To ensure that all potentially affected batteries are identified and returned to Dell, we are requesting that customers recheck their batteries. Throughout this recall, Dell’s primary concern continues to be the safety of its customers.
    Please go to Dell Battery Return Program to verify if your battery or batteries are subject to this recall and to order the replacement batteries. Dell will provide a means for you to return the affected batteries for proper disposal. If you have additional questions not covered on the recall website, or cannot access the website, please call Dell toll-free at 1-866-342-0011, Monday through Friday, 8:00 a.m. to 6:00 p.m. Central Time.
    Customers also can write to the company at:
    Attn: Battery Recall
    9701 Metric Blvd., Suite 200
    Austin, TX 78758, USA.
    Please note that the recall is for the described batteries onlyl and not the notebook computers themselves.
    Dell apologizes for the inconvenience caused by this issue. Shipment of quality products always has been and continues to be our foremost concern. As always, if you have questions or concerns about this or any other subject, please feel free to contact us.
    This message has been updated to reflect our ongoing committment to getting all of the affected batteries replaced. No additional batteries have been added to the recall.
    Thomas Christopher Nov 05, 2007
    Sounds good. Please do let me know.
    Thomas Christopher Nov 06, 2007
    shuggy1001, please rerate this as solved. Thanks,
Dell Inspiron 1100 won't turn on
unplug, take out battery then hold power button for 30 seconds then plug back in and turn on
if the3 laptap gos on without the battery you need a new battery
Jun 14, 2013 | Dell Inspiron 1100 Notebook
My dell inspiron mini 10 won't boot.There is just a flash of white light then a flash of amber light when I press the power button. That's it, nothing else.
Remove the main battery and try again, also! the power adapter charger should be checked for correct voltage, if okay! pull one stick of ram and test, and the second piece not forgetting to put the first one back and power up, if all this fails you will need to get it assessed.
Mar 25, 2012 | Dell Inspiron Mini Netbooks
I want to upgrade my inspiron 1100 processor
To be honest, the Inspiron 1100 is probably not worth the effort and cost to upgrade
The fast is proc is a 2.4 GHz Pentium 4 CPU, max ram 1GB of RAM,
You can find several dell portables below $500
Jan 30, 2010 | Dell Inspiron 1100 Notebook
What does it mean when lights flicker on dell inspiron 1100
Most of the time it means your battery is dead... try to unplug the battery on the bottom of the laptop and plug in the power supply. Try to turn on the computer. If it comes on, then you have a bad battery. Check eBay for a new one.
If it comes on but still flickers with the AC adapter plugged in, then you have a bad battery and it needs to be replaced.
Dec 09, 2009 | Dell Inspiron 1100 Notebook
Dell Inspiron 1100 won't power up with battery & power pack both conected
A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective.
Nov 09, 2009 | Dell Inspiron 1100 Notebook
Dell Latitiude 1100 Will not boot has poweron issue
I also have a dell inspiron 1100. It seems that it has overheated, and your motherboard or CPU has fried, or died from the heat. What you say sounds like a motherboard failure
There is currently an ongoing lawsuit. Also, take my advice, and instead of trying to fix it, you're better of getting a new computer, as the dell is getting old anways. I spent some extra cash and got myself a vaio.
Aug 15, 2008 | Dell Inspiron 1100 Notebook
Try the following:
1. Try to boot the notebook with both battery and adaptor attached.
2. Try to boot with ONLY the battery.
3. Try to boot with ONLY the adapter.
If you can't boot with only the adapter, the adapter has died. If you can't boot with only the battery, the battery is dead.
But as stated above, make sure your battery is sufficiently charged.
In case of a dead battery or adapter, check whether the device is still under warranty. Contact HP if so.
Let me know what you found out.
Jan 24, 2008 | Dell Inspiron 1000 Notebook
Boots halfway and dies
One from all problems can be:
Hdd problem or power suply
If u have another hdd change it and try
Let me know if u got help?
Nov 27, 2007 | Dell Inspiron 1100 Notebook
Dell Inspiron 1100 Notebook Logo
464 people viewed this question
Alun Cox
