Question about Kenmore Dryers
I need to put in hi-limit thermal fuse how .show
I need to put in hi-limit thermal fuse how .show me kenmore 80series gas model 76812692 ser.no. mg2302559 I get no heat but it runs .
  • 97 Answers
Hello Friend, This problem will be an easy quick fix for you. All you need is a thermal fuse, your cost under $20. Remove back cover from dryer, look down towards where the air blows out, then just to the left where all the wires are. You will see a little white plastic part with two wires plugged into it, this part is called a thermal fuse. Just unplug these wires and replace the thermal fuse. This should solve your problem. Happy to help, Tim.
Posted on Jun 24, 2009
Kenmore Elite model #110700932990 dryer has no heat
My experience has been that most of the time when a gas dryer does not heat, that the igniter has gone bad...
The other less common problem is that the coils of the gas valve go bad...
Other problems can be the thermostat, the high limit, or the thermal fuse going bad...
Here is a tip that I wrote about not heat in gas dryers...
gas no heat tip....
heatman101
Nov 23, 2010 | Kenmore 74642 Gas Dryer
Gas kenmore dryer, no heat . the gas heat does not turn on. i tried running it without the vent but no help.
It could be several things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Apr 25, 2010 | Kenmore Dryers
Kenmore dryer Model 110.86982 Year 1989 does not heat
If you bypass the hi limit thermostat you will blow your thermal fuse within minutes. The hi limit thermostat is a bi-metal thermostat which warps when heated to kill power to the element. If its bypassed then the element will not turn off.....which will in turn blow your thermal fuse which is rated at a higher temp than the hi limit. So unfortunately it will not work.
Hope this helps _MJ_
Feb 07, 2010 | Kenmore Dryers
Kenmore gas dryer 70932, 70942, 70952 won't heat. Dryer turns on and tumbles but won't heat.
Check the following areas to combat this issue. the most common problem spot will be a blown Thermal fuse.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Oct 04, 2009 | Kenmore Dryers
My dryer runs but does not heat Kenmore 110.74722400
1. Gas valve coils
2. Thermal fuse
3. Igniter
Sep 05, 2009 | Kenmore Dryers
Kenmore gas dryer wont heat up
1. Gas valve coils
2. Thermal fuse
3. Igniter
Aug 11, 2009 | Kenmore 73952 Gas Dryer
Our Kenmore 87042 thermal limited tripped. Can we
This is repairable. Most dryers have a thermal fuse, or limiter, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Aug 06, 2009 | Dryers
80 series kenmore dryer not heat
Aug 04, 2009 | Kenmore 84052 Dryer
No heat burner comes on for a few minutes and then goes out
Check the following to address this issue.
1. Gas valve coils
2. Thermal fuse
3. Igniter
Jun 02, 2009 | Kenmore 72062 Gas Dryer
Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Apr 06, 2009 | Kenmore 64742 Electric Dryer
Dryers Logo
75 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
