Question about Toshiba 20VL14 20 in. EDTV-Ready LCD Television
I have a Toshiba LCD Flatpanel (model 20VL14). it has a normal factory malfunction in the adaptor box (modelTAA-Y58) that shuts down the television completely when it over heats. today i was playing some video games on it. I had shut it down to do something for ten minutes. then when i turned it back on again to play some more, it black screened. only problem is that this time the television is still on! you can hear the audio, but there's no video. i checked if it was the channels, and no matter what input or channel i put it onto, it stays black. i tried unplugging and replugging the adapter, same thing. i tired turning it off and back on. this time, it had a split second of snow before going black screen, and continued that way every time i shut it down then turned it back on. what's the problem, is it fixable? or would i be better off buying a new television?
SOURCE: Toshiba 20vl14 power loss
Mine does the same thing!!
Posted on Apr 26, 2008
  • 15 Answers
SOURCE: goes on and off on and off permantly
your backlight is going out.. get it replaced
Posted on Feb 01, 2009
SOURCE: Flickering tv screen when playing playstation games.
I had a similar problem show up for my Olevia 65" HDTV. I solved it by putting my TV into "game" mode, where it doesn't do any picture correction. Now the game works just fine.
Posted on Mar 07, 2009
as400jockey
  • 3 Answers
SOURCE: White/Grey screen with non-HD channels
I removed the HDMI cable and connected with component video and rca audio. No more white screen.
Picture quality looks good. I don't know if it's as good as HDMI, but then I don't need to reboot the TV three times to get to teh on-demand menu... Grrrrr....
I am trying to contact Toshiba on this as well. I have seen several reports of this problem on the web.
Posted on Feb 06, 2010
SOURCE: toshiba 40rv525r LCD t.v. have sound but turned
Sorry, I donʻt have solution, but I do have this exact same problem, same model of TV! Iʻm wondering if youʻve had it fixed yet and if so, how did you do it?
Posted on Jul 27, 2010
I have a 26' Toshiba LCD TV Model: 26WL65G. When I plug in and turn it on it seems to start normally, but when screen turns on blue screen appears as normal and it goes back to stand-by mode...
Note that if it is a backlight inverter board problem you will still have sound. SInce you have no sound I would suspect a power supply or main A/B board malfunction. Do you know how to use a multimeter?
Dec 11, 2011 | Televison & Video
What is the setup code for VIZIO 42" LCD HD Flatpanel Model: VJ430M?
Start here.
http://www.vizio.com/ I could not find the manual, but they do have Chat and Q&A on site under support tab.
Nov 10, 2010 | Televison & Video
How to I permanently set the picture size on my toshiba 32AV502R? I choose pic size, but when I shut the tv or go to a different input.. it resets when I come back.
Unplug,replug about an hour later should be back to normal reset to factory setting.It should work now because not in custom setting anymore.
Dec 10, 2009 | Toshiba 32AV502R LCD TV
Dell inspiron 1100 turns on for a few minutes and then shuts off. it does give message "battery low, connect to external power source." but i have my a/c power adaptor already connected. i checked my...
15vac is pretty normal for a laptop battery. Its likely that your laptops power inlet has malfunctioned and no longer is capable of recieving voltage. Besides, your power terminal should be getting 120vac, it's just your adaptor that reduces the voltage to 15-19 vac usuable for laptop batteries. Also your laptop computer is rather an older model, my mother has one and I've worked with it a while. Laptop batteries also don't last forever, It might be wise to move onto a better laptop.
Please rate my answer.
Oct 12, 2009 | Computers & Internet
No HDMI input socket on Toshiba 'HD Ready' TV
There is an easy way to adapt the cable.
Any good computer shop will have the adaptor.
Take the HDMI cable to them, and tell them you want an adaptor to go to composite signal.
(I know that they're made, many of the graphics cards I use to build computers come with that cable adaptor)
You also might try Best Buy or Radio Shack, but you might not have much luck with them.
Dec 03, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
problem with power supply ask technician check it...
May 04, 2008 | Toshiba 20VL14 20 in. EDTV-Ready LCD...
Laptop doesnt start
there must be a problem with the voltage output of the adaptor... because many modern laptops react by shutting down when they encounter voltage ranges that they r not supposed to...
Feb 01, 2008 | Toshiba Satellite A45-S151 Notebook
Mw27h62
X-box Sounds like it could be a bad inverter board, Toshiba p/n#72001911 and they cost about $35 plus shipping... This is a common failure with this model causing anything from intermittent shutdown to simple loss of video. Get it in the shop and have them check it out. Might also take the part number with you so they don't have to research it... Good Luck Bill
Jun 08, 2007 | Toshiba 20DL74 20 in. EDTV-Ready LCD...
Sanyo camera shuts down and won't power up
I connected my Sanyo VPC - 603 digital camera to an AC/DC adaptor due to battery malfunctions. After about 5 seconds, i heard a spark sound and the camera went off. What might have gone wrong? How can it be repaired?
Apr 10, 2007 | Sanyo Xacti DSC-S4 / VPC-S4 Digital Camera
Toshiba 20VL14 20 in. EDTV-Ready LCD Television Logo
64 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
