Question about Garden
Chain replacement Is the replacement chain for the craftsman 358.360280 modek a S 72
What is the replacement chain for the craftsman pro 41418 chainsaw?
Call your local Craftsman Chainsaw dealer and ask them to order one for you. This site may be able to find it for you... http://www.searspartsdirect.com/partsdirect/brands-products/Craftsman-Parts/Chainsaw-Parts
Jul 20, 2014 | Craftsman Garden
Filing angle for Husqvarna chainsaw 450 --20 ' bar chain 72 links?
On .325 pitch chain the top plate angle should be 25 degrees, there is normaly a match mark on top of each cutter, the depth gauge should be set at 25 thousands of an inch.
Apr 02, 2013 | Husqvarna 450 Chain Saw 18 Inch Bar...
I have a craftsman 16" 36cc chain saw. Engine
First thing is make sure chain brake is not engaged is so equipped. Next make sure that chain tensensioner is not to tight to allow chain to rotate. I wouuld remove bar and chain from saw and spray both several times with WD-40 and work chain link by link until they all move freely.Clean and lube guide channel on bar and make sure that bar is not dented or badly rusted.If all else fails replace bar and chain. Good luck and thank you.
Mar 14, 2011 | Craftsman Garden
40" tevion lcd tv. modek no lcd 4040.wont come out
It should be fixeable. Does it do anything now?
I would blanket change them all.
Feb 18, 2011 | Televison & Video
I am looking for a manual for a Craftsman 10" Band Saw Model No. 103.0101
I have a 10" table top bandsaw and i need to replace the drive belt. Can't find a manual for this and don't know the size of the belt.
Aug 14, 2010 | Craftsman 1/4 x 72-5/8" Band Saw Blade, 6...
I have a craftsman gas chain saw model 358.352180. It leaks oil from underneath the saw even when not in use.
Make sure you drain the oil when storing your saw. That's because the saw is designed to supply a generous amount of oil to the chain and bar.
May 19, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Garden Logo
150 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
