Question about Samsung Digimax S630 Digital Camera
I have the same problem
After my mom used my camera to record my graduation video after that when I turn on my camera it only lasts 2 seconds and turns itself off and I did not drop it
    Novelist:
  • 107 Answers
Hi:
If you did not drop it, you probably have some dust or small particles around the outside of the lense. They prevent the lense from fully opening. The lense cover might have the same problem. As a result it is stuck.
When the lense open up try to clean around the lenseor the cover. If it opens, but not all the way out, try to pull it out NOT too hard.
When it opens, try dust off. Make sure you do not force too hard on all of the steps above.
Good LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Jun 24, 2009
My Flip Mino HD camera turns off while recording!
I had the same problem! But I turned it off, stuck a paper clip in the little hole inside the hole at the bottom for 10 seconds, then i held the power button for 5 seconds till it turned on and it works just fine now :)
Nov 18, 2012 | Flip Video Mino Camcorder
VL-Z3 will not record video
Having the same problem. I got this from a friend who also gave me a blank cassette. I could record on the cassette without any problems, but when it comes to using a memory card, it said the same thing. First it said Format Memory Disk, which I already did. Then when I tried to record, it says Please Use Photo Button. My son's graduation is coming up in 12 hours and I still haven't found a solution!! If someone could enlighten us on how to fix this, it will be greatly appreciated.
Jun 11, 2012 | Sharp VL-Z300U Mini DV Digital Camcorder
Need detailed instructions on how turn video around so can see it upright instead os sidesways
This is very difficult to accomplish. You need to use quite sophisticated software for video editing in a computer to achieve rotation of video. As goofy as it sounds, the easiest way to rotate video is to rotate the monitor on which you are viewing. It's not a great solution, but you can't do it in the camera.
May 22, 2009 | Canon PowerShot SD1100 IS Digital Camera
CANON SD1000 can't TURN vertical downloaded video into horizontal
If you have windows movie maker (its part of the default installation of windows XP) you can use the rotate filter in the video effects tools.
Import your video into movie maker and select "Video Effects" under tools.  Scroll through the various effects until you find the "rotate 90".  Apply the effect and save the video.
I hope this helps!
Nov 25, 2008 | Canon PowerShot SD1000 Digital Camera
Recording problems
I actually connected it straight into my VCR and used the line 2 input and I was ready to record. I would still like to know how I could hook it up to my computer so I could burn a CD instead. Have any ideas?
puzzled mom
Sep 28, 2008 | Sony Handycam CCD-TRV318 Camcorder
Recording and copying
probably writing error.
Was it playing w/ Sync on the cam ?
If so, try different burning software like Nero.
Mar 25, 2008 | JVC GZ-MG130U Camcorder
Can't turn on my camera!
Hi..
I have a link and some information I found on the video option to your camera. This link is for the manual located on hp.com:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=371583&lang=en&cc=us&lc=en&dlc=en&
The following is how to stop video:
To stop recording video, press and release the Video
button again; otherwise, the video will continue recording
until the camera runs out of memory.
NOTE
If you have set the camera to Self-Timer or Self-Timer -
2 Shots (see Using the Self-Timer Settings on page 44),
the camera will start recording 10 seconds after you press
the Video button. However, with the Self-Timer - 2 Shots
setting, the camera only records one video clip.
After recording has stopped, the first frame of the video clip
appears on the Image Display. While it is processing, you can
delete the video clip by pressing the Menu/OK button
Good luck and please let me know if there is anything else i can hep you with--feedback would be geat.. thanks, d
Feb 27, 2008 | HP Photosmart R707 Digital Camera
DCR-DVD108 Problem
It's the disc not the camera......I purchased a 3 pack of Sony DVD-R discs. I put the first disc in and it recorded once. The next time I tried to record I got the message "movie recording disabled". After calling Sony, searching online, resetting the camera and reading through the manual I replaced the disc with another from the 3 pack and it is recording just fine. I read that recording straight to DVD has many problems, and I believe this is one of them. SONY SUCKS!!!!!
Feb 26, 2008 | Video Cameras
Samsung sc-d353 blurry now black
Problem is fixable and not expensive either : CCD sensor is faulty and needs replacing.You do have a case for having this problem sorted out by Samsung agent free of charge because the sensor should last 10 years +.
Sep 04, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Black screen
Go to www.samsungclassaction.com for more info.
May 21, 2007 | Samsung SC-L901 Camcorder
Samsung Digimax S630 Digital Camera Logo
128 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
