Lgr40 memory i can't install a second memory stick in my computer. the computer won't start with the second memory stick
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 308 Answers
Could be a parity issue. Make sure of the following
Both memory are the same in size (for better performance) and buffer rate (all can be found on the memory card sticker/label.
Note that some can look the same and everything but then then there are not what the machine memory dimm slot takes....you should check in the computer manual if you have any.
Also take the memory out (both) and insert them individually in one memory slot after the other and turn the computer on to see if it works. You may have a faulty memory as well or a bad memory dimm slot.
Good luck and do let me know what happens next
Posted on May 18, 2014
Computer won't read my memory stick pro duo. Computer won't read my Droid SD card and I am using the adapter.
is it possible that the auto play window just isnt poping up. go to the start menu > my computer> the look to see if it shows up there. have a great dat
Aug 25, 2011 | Sony 2GB Memory Stick PRO Duo Memory Card
How to replace a memory card from a hp dv5000
1. Power off youtr notebook
2. Remove power supply calbel from side of notebook
3. Remove battery from notebook
4. Ground yourself to get rid of electrostatic, do not touch exposed compenents till you do so!
5. Use screwdriver to remove smal square plastic cover from underside of notebook
6. Install memory into open slot making sure that you have the correct type and speed for notebook
6. Install cover onto underside of notebook
7. Install battery, then cable, and start up notebook
8. Verify that all memory is recognized in Windows (or whatever OS you are using)
Jul 10, 2011 | HP Pavilion dv5020us Notebook
I have a toshiba satellite x205-s9349. It won't boot at all, no beep codes or screen. The fans start and the hard drive lights go on for a bout 4 seconds and then the fans turn off and nothing....
Try this
unplug plug the power cord and remove the battery and hold the power button for 45 seconds,Then reinstall the battery and and try to start the computer,
if it fails to start
unplug plug the power cord and remove the battery and hold the power button for 45 seconds and
remove the memory and any usb devices that may be plugged in,then start it,
If it starts
Allow it to load completely and then shut it down and install one memory stick and restart, if all is well after if loads completely, shut down again and install the other memory stick and restart, if all is well again wait until it loads completely and then plug in and allow to load each of the usb devices you may have
Jun 29, 2011 | Toshiba Satellite X205-S9349 Notebook
I installed two new 1 gigabyte memory sticks into a Dell Inspiron 6000, which previously only had 2 256 megabyte memory sticks installed. When I first installed the 2 gigs of new memory, the laptop turned...
Once you installed the memory, did you enter into the System BIOS Setup screen? Do this and verify that the system recognizes the newly installed 2GB RAM. This should let the system access the new memory once you boot.
Jan 01, 2011 | Dell Inspiron 6000 Notebook
My laptop is not allowing me to go for microsoft website and it is not allowing me to download free antivirus as i dont have a antivirus instaled on my laptop and it shows that your computer has suspected...
On a second computer, download the _free_ anti-virus software from Microsoft: http://www.microsoft.com/security_essentials
and copy the file onto a USB memory-stick.
Carry the memory-stick to your computer, and install the software. It will remove the "scareware" 'AntiVirus2010' software.
Feb 01, 2010 | HP 378248-001 keyboard for Compaq nc6110,...
About my ram of p4m800-m7 rev 3.1 i have a 512mb ram already installed and i buy a new ram with a 1gb size and i would like to install it but my question is is it okay to put them together? my 512mb ram is...
The black rectangular chips on the side, or sides, of the ram module are DRAM chips. Dynamic Random Access Memory.
('Chip' is slang term to denote IC, or Integrated Circuit)
Each Dram chip is of a specific size, (or can be said as Amount)
There are manufacturers who make the Dram chips, and then the chips are used by the ram memory manufacturer.
Doesn't matter how the Dram chips are arranged. The ram memory manufacturer could put them all of one side, if they designed it that way.
1.Your motherboard will support, (Use), DDR at 333Mhz, or DDR at 400MegaHertz.
(PC2700 and PC3200, respectively)
2.The ram memory module must use 2.5 Volts.
(JEDEC has set the voltage standard for DDR Sdram at 2.5 Volts, so no worries here. Only time to check this, is if you have some High performance ram, that may be set to use a higher voltage)
3.It must be Non-ECC ram, and Unbuffered.
4.Cas Latency should be 2.5 to 3.0 (Ram Timings)
Short solution?
Computer off, and unplugged from power. TOUCH the metal frame of the computer case to relieve your body of Static.
Handle the ram 'sticks' by the body of the stick, and refrain from touching the gold plated contact pins, on the bottom.
If the 512MB stick is in SLOT 1, remove it. Install the 1GB stick in Slot 1. Make SURE it is seated!
(Slot 1, is the ram memory slot that is closest to the Processor. It is the first ram memory slot that the Processor reads)
Leave the computer case open. (Refrain from putting your hands in while the computer is plugged into power)
Plug the computer into power. Wait 30 seconds. Turn the computer on.
Computer boots up? (Starts)
Okay.
Unplug from power. Install the 512MB stick in Slot 2.
Plug into power, wait 30 seconds. Turn the computer on.
Computer boots up?
You're good to go.
1GB ram memory stick is in Slot 1, and the computer does not boot up?
Incompatible ram memory. Remove it. Reinstall the original 512MB stick in Slot 1.
Nov 26, 2009 | EliteGroup P4M800-M7 Motherboard
Upgrading ram on laptop, new ram not recognized.
remove the bios battery for a few seconds...and place it back on ...this will make it see the new ram memory modules...if you are sure they are compatible ..they will work .....in fact ..the ddr1 333 512 M is more that compatible with your system and it will work after you remove the battery ...\ my recommendation is to reinstall a clean operation system after you boot up ...and format the C partition too...this have to be done after memory changes to get the max out of them ..
Nov 13, 2009 | Dell Inspiron 1100 Notebook
How to download from memory stick to my dell computer
gerrygeldart:
First, use a usb cable and download to the computer with the installed software, if needed.
Second, Buy and use a card reader to get the pictures from the memory stick to the computer.
Aug 09, 2008 | Fuji FinePix A600 Digital Camera
MEMORY UPGRADE
Sorry for the delay in my response.
Your computer will accept a maximum of 1 GB of memory. If both memory modules are the same brand and part number then it is possible that one of the sticks are bad.
Try each 512 MB memory stick in the first memory slot, without installing a second stick. This will troubleshoot to find out if one of the 512 memory sticks are bad. If both check out ok, then the problem is with the video adaptor.
Have you tried adjusting the refresh rate on the monitor as I described in my first response?
My final possible solution would be to upgrade the bios. Below is a link to the webpage for your computer system. You will find links for troubleshooting guides, driver and software downloads, product specifications, etc. If you click on driver downloads, then choose your operating system, you will be directed to a page that should provide the latest ROM (bios) update.
http://h10025.www1.hp.com/ewfrf/wc/product?product=93322&lc=en&cc=us&dlc=en&lang=en&cc=us
Jul 28, 2008 | Computers & Internet
Installing 2 sticks of 1 gb ram = DRAM error beeps
If the computer is working with one gb stick and not the other, try this:
Swap the sticks with the one that does work. If it works then its the memory card slot on the motherboard. If it doesn't boot up, then it's the memory stick.
Jun 13, 2008 | Gigabyte GA-K8NS Motherboard
Computers & Internet Logo
David Payne
David Payne
