Question about Danze Home
New danze cartridge no water
Replaced new danze washerless cartridge twice and still no water in shower. PB valve separate.
  • jpatzelt May 22, 2014
    Hi Chris legat, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 62 Answers
Possible issue with pressure balancing cartidge, When you remove parts, turn off water, remove parts, slowly turn on water and see if brass valves lets water out. If yes pressure balancing cartridge or cartridge itself is defevtive.
Posted on Aug 16, 2014
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: dissassemble danze washerless shower valve
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
Danze shower on off valve leaking. How do i repair it?
This a common problem with most shower valves.After time the internal parts of the valve wear and need to be replaced. You can purchase a new shower cartridge for about $50.00 at your local hardware or on line. Be sure to turn off the water before removing the old cartridge. Install instructions should be included or go to Danze.com
Dec 02, 2016 | Danze Home
How to install a cartidge shower 1 handle separate PB
make sure that you have installed the right way not upside down or backwoods...pull back out and check the alignment....good luck
May 18, 2014 | Danze Home
My Danze showerhead runs even when turned off
try cleaning the inside of the valve with 1500 grit wet sandpaper. and then put a lot of waterproof plumbing grease in there and also on the cartridge. sometimes you can get a build up of hard water inside the valve body and that will cause leaks. just dont over do it with the sandpaper and dont anything more abrasive than 1500 grit.
Nov 26, 2012 | Danze D135300BT Single Handle 3/4 Volume...
Installed new Danze shower valve the water is on but will not come out why?
shut off your water and pull the cartridge out off unit...make sure you have no trash in cartridge...turn water on without cartridge in but only part way to see if you have water flow to value...then make sure no damage to cartridge or some of these have plugs that need removed on install of cartridge....you may need to remove test plug that is in there ....try this...good luck
May 09, 2012 | Danze & Single Handle Tub And Shower...
I have danze single handle shower head leaks when turned off
you need new seats and springs that are in cartridge...replace them or buy the whole cartridge and replace that....turn off water and install new one you can buy at lowes or your nearest plumbing supply...good luck
May 09, 2012 | Danze Home
Danze UPC tub/shower valve leaks constantly at tub spout
shut off water and pull cartridge...go to lowes or plumbing supply and match up cartridge and replace...you may also just replace seats and springs if cartridge is ok....cheaper...but if not sure just replace whole cartridge...make sure hot is on left...
Aug 15, 2011 | Danze Home
I have a Danze D112000BT Single Control Pressure Balance Mixing Valve with Screwdriver Stops that was installed in 07, it been working fine then last week it all of a sudden became really stiff to turn...
Danze cartridges are known to have problems after time with hard water. If you call Danze at 1-888-328-2383 USA
Canada: 1-800-487-8372
They have a lifetime warranty of defects, and will replace the cartridge for that valve for free. It will actually be best to have a plumber do it because taking the cartridges out can be simple, putting them back in and tightening it up the way it should be can be tricky. It is nice that you have the valve with the screwdriver stops. That allows you to remove the cartridge without having to turn the water off to the entire house. Simple turn each stop to turn the water off, remove cartridge, put new cartridge in.
May 01, 2011 | Danze & Single Handle Tub And Shower...
Shower valve has a thumping sound when other faucets or toilets are turned on and off.when you turn shut offs to danze shower valve off sound goes away.could this possibly be the plunger in the valve?
Vfiippone,
I have the same issue with a Danze Sonora shower Valve. I called Daze and they sent me a new cartridge. After installing it I have the same problem. I also put a surge arrester on my toilet which had little effect. If you find the cure please post it.
Nov 04, 2010 | Danze D500058BNT Parma Shower Trim Kit w/...
Need an instruction sheet for cartridge replacement for Danze Sheridan tub and shower faucet
This link will get you to the Danze illustrated parts list for the Sheridan single control tub and shower valve.
http://www.danze.com/products/pdfs/D510055_ip.pdf
Aug 08, 2010 | Danze Sheridan Tub & Shower Faucet
Dissassemble danze washerless shower valve. Older, NOT ceramic disc model. Replace cartridge, short square stem washerless round cartridge.
Nov 02, 2009 | Danze & Single Handle Tub And Shower...
Home Logo
138 people viewed this question
Top Danze Home Experts
Mike
Paul Bade
Dennis
Are you a Danze Home Expert? Answer questions, earn points and help others
