Question about RCA 20F512T 20" TV
TV will not power on
Took it apart and noticed fuse was blown. Replaced with good fuse. Blew the fuse. Then took another look at the rest of the circuit board and found that position RT801 model MZ73L 9Rm shows signs of electrical burns on the circuit board. Is there any way I can get this particular part and solder it in myself? Very familiar with electronics. Thanks
How , i also took out this , thinking it has short circuited as the problem was exactly same . see what happens after chaging it
Posted on Mar 21, 2010
The MZ73L is a posistor, its basically 2 thermal resistors back to back. One is connected across the mains, the other one connects the deguassing loop to the mains. When the TV is 1st turned on the mains connected R is cold so its neighbour is cold, that allows a large surge of current into the degaussing coil. The mains connected one rapidly gets hot and heats up the other one, this increases the resistance of it and the current being dumped into the degauss coil fades away. As the 1st one is a heater it will get hot and you will see signs of heat on the PCB, BUT its still a very good place to start. The heat is normal, but if the 1st ceramic disk in it has died then you will short the mains and blow the fuse with it.
Posted on Apr 20, 2008
  • 979 Answers
You will need to acquire the service and parts manual. This will guide you to the correct part number(s) you'll want to order. Any reputable parts dealer can help you in that aspect.
What usually causes these types of problems is a failure of the device itself or a "chain reaction" sort of event, causing the visibly defective part to smoke through no fault of it's own. Be sure to check for proper voltages before condemning the wrong area. Hope this helps...Accordianman
Posted on Nov 04, 2007
Sylvania LC320SLX 32 in. LCD TV wont turn on
There is short circuited component/s at its main power supply regulator board. Check and replace them. It is best to replace the circuit board as card bassis, rather than trying to repair it.
Jun 13, 2013 | Sylvania LC320SLX 32 in. LCD TV
I have aVizio VX42L HDTV10A. was watching a show when we heard a loud pop.Then all went dark. Would not turn back on. I took off the back cover and found the ceramic fuse was blown on the board # DPS-283AP...
This means you have a dead short, It is probably a Diode in the power supply area, but without testing board you don't know. If you know basic electronics, i would say check all diodes in power supply and look hard for something burnt and replace that also. Or just replace power board, check shopjimmy.com
Dec 08, 2010 | Vizio VX42L 42 in. LCD TV
My SD-532 HD5 Pioneer TV wont turn on so I took it apart and noticed a fuse was blown so i replaced it and then it blew again. Any suggestions why?
Hello hnelbach, From what I can tell by your description, one of the subsystems in your TV as developed a short circuit (hence the fuse blowing). I would suggest that you get a qualified TV Technician to repair this TV since there are no user serviceable components in this TV. This TV has very dangerous voltages which can kill under certain circumstances. I would have the technician look at the deflection board. This board contains the Convergence AMP, and Horizontal Circuitry. These circuits are the usual culprits in this type of problem. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 14, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
Problem with Sansui LCT37SD power supply unit
Diagram of SANSUI LCT37SD.
Power supply default.
Apr 22, 2009 | Televison & Video
AMP DOES NOT POWER UP
if it dont smell blown then make sure your fuses in the amp are good and the fuse to the power is good
Mar 24, 2009 | Kenwood KAC-729S Car Audio Amplifier
Blown fuse on panasonic tv
Maybe the horizontal output IC are on short circuit.
Nov 04, 2008 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
Ilp iwt3206 32" sdtv
Next best guess is the larger filter capacitors in the power supply are bad and shorted out, you can check with an ohm meter across capacitor leads (with power unplugged)
Apr 21, 2008 | iLO 3200 32 in. LCD Television
Thermister Blown / Fuse
We offer no warranty as we are just guessing without hands on testing of the problem.
Jul 05, 2017 | Emerson EWC20D4 Combo
Insignia LCD TV 26"
A blown fuse is a symptom not the cause... You might take a look at the caps E919,E920,E921 (all 680uf/35v). The board can be accessed by removal of center cover w/o removal of the entire back.
Bill
Nov 15, 2007 | Insignia IS-LCDTV32 32 in. Television
RCA 20F512T 20" TV Logo
787 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
