Question about Music
How to do trouble shooting-testing of all functions-of Roland Vs880 digital workstation
I have a roland e96 trouble. Fist indikator in lcd internal battrey low, but not change the battey. now my roland e96 is blank.
You need to replace the battery. It will most likely be a coin sized battery in a slip in holder on the main board. If you need help, here is ROland Customer Service contact info-
Support Roland
After that, you can reset the E96 back to the factory settings by following the directions here-
Roland 96 Initializing the 70 86 96 Restoring the Factory Settings...
Mar 18, 2015 | Roland Music
How do I fix a Roland Digital Piano FP-8 that has refused to play sounds despite the fact that it displays lights?
If everything lights up and responds to button pushes like normal, and you've done a hard reset as described in the manual, check to see if you have sound out of the headphone jack. It's most likely not a user serviceable problem and will need to go to the shop, but it will probably be the output amp rather than the main board.
Mar 07, 2015 | Roland Fp-8 Digital Piano Email Us For A...
Analog test eror onroland td5
I have the same problem with my module and I can\'t find the solution anyware for the thing.Closest solution that I could find is something about Roland power adapter.Apparently module won\'t work with any adapter with the same voltage,only Roland or Boss B.R.A. adapters works.I have original Roland adapter and still shows an Analog test error.
Have you find the solution in meantime by any chance?
Sep 09, 2012 | Roland Music
I'm trying to burn a song to a CD-R using a Boss BR 1180 but every time it completes, there's no song on the CD. I record, bounce, record on 9/10, then try to write to CD and it never works.
"it never works"... this is NOT enough information for us. You are not telling us how the CD is tested. If you are testing it in a boombox type player, that is not a test. First thing is to look at the bottom of the CD to see if you can detect written tracks... with right lighting you can tell if it has been burned. REMEMBER that CD's, unlike phonograph records, are written from the middle outward. Many consumer players have trouble playing CD's that are written but not "finalized". If you CAN see written area (compare to unburned CD) then likely the burning is taking place, and the problem is the format is either not complete or incompatible with your player. Try reading the disk in your computer. Also you might want to visit the forums for the Boss/Roland workstations at
Aug 19, 2011 | Boss Micro BR Digital Recorder
I Have a Casio Privia Digital Piano and a Roland DP-10 pedal. The pedal function is inverted. When I press it stops the sustain and the effect comes back when I release the pedal. The pedal does not have...
Yep... Roland pedals are reversed, that is, normally closed contacts. Unlike some Yamaha keyboards, the Casio doesn't have an inversion function available. You have two choices to solve this: 1. Buy a pedal with the corect sense 2. Open the Roland pedal and MAYBE with a soldering iron you can move a wire to select a contact with the opposite sense.
Aug 05, 2011 | Casio Privia Px330 Px-330 88 Key Digital...
I plugged a sustain pedal from my Yamaha DX7 on the dumper pedal jack but it works opposite as it should (by pressing the pedal sound cancels as i release the keys; when pedal runs completely free sounds...
every sustain pedal got different polarity.. normally just go to global setting on your keyboard and change damper polarity setting to plus or minus (select which one work with your sustain padle).
Jul 26, 2011 | Korg M50 73 Note Workstation
BR-1600 unit will not burn discs
You might go over to and look in the forums there. They deal a lot with Roland digital recording workstations.
Jul 14, 2011 | Boss BR 1600 Cd Br1600 Cd 16 Track Digital...
I have a Roland FP-8 that I used for performances. I have noticed some static in the past couple of weeks in the sound. Now it doesn't play at all. The display lights up normal, and the buttons work and...
your sound process digitaliser has burned out the crackling should have warned you as to the fault and had it replaced (fixed) right away this is a simple repair but does need to be done by an electronics tech
Jan 02, 2011 | Roland Digital Piano FP4 Black With Stand...
Simple way is MIDI out from Juno to MIDI in on MPC, then (depending on how you want to work), connect MIDI out from MPC to the in on the Juno. If you do this you MUST turn local control off on the Juno or else you'll get double triggers (internal + msg in from MPC). Now to record sequences on MPC , set MIDI to as track in setup window (on the 2500, this is accessed by pressing MODE then pad 9, then press button under the corresponding tab [on LCD]) then set your MIDI channel by port, meaning if your MIDI cable is physically connected to out A, in your LCD in bottom right corner it will show as follows: 1A. This indicates you are transmitting on MIDI channel 1; port A. Remember, MIDI IS NOT AUDIO!!!!! Since the Juno is a synth and not a workstation, all transport controls are handled by the MPC, that's pretty much it... Hope this helps a little, enjoy!
P.S. Go to its THE sh**! They also have links for their e-book I have one for the 2500 and its awesome!!!
Aug 16, 2010 | Roland Juno-D
For Sale Brand Korg OASYS 88 88-Key Workstation ????2100.00 EUR
If you scroll to the bottom of the page and click on Advertisers the site can help you.
Aug 05, 2009 | Music
Music Logo
15 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
