Question about Fisher and Paykel Dishwashers
How do I clear the error on a Fisher and Paykel DW60CSX1 error message E6
I have fixed the leak that activated the flood switch but now all i get is all lights flashing and beeping. the beeping stops after about 10 seconds but the lights still flash and i can hear the pump going. Any help would be appreciated
    Problem Solver:
  • 5 Answers
To fix essentially you need to reboot... unplug at wall - wait about 30 seconds - 1 min then replug. should reboot and be back to normal.
if you can, pull drawer out at end of cycle so condensation does not cause this problem going forward... ours does this when it's higher humidity
Posted on Jun 16, 2014
  • 251 Answers
SOURCE: How to reset the flood switch on a fisher & paykel
Hi - unfortunately my good friend it cannot be reset as one would like quite easily anyhow... water has found its way to the base of the drwaers and have activated the flooding switch - one could pull it apart to dry it - tip the water out from the base but if the leaks not repaired you will have the same problem later and will be on-going.
5 Fault Codes
Fault Code LED Display Fault Possible Causes
F1 ----#
The flood switch has been activated.
A leak has occurred in the base of the dishwasher.
Cause
 The fill valve has failed open.
 The flood switch is faulty.
 Excessive water has been added to a wash sub cycle, indicating leaking seal or siphoning.
hope this is useful tp you - let me know if you require further asspstance...
Posted on Jul 17, 2011
  • 3247 Answers
SOURCE: My fisher & paykel dishwasher
please confirm which model do you have 820 or 920.
I am assuming this is the one without display.
most likely cause is the flood switch at the base has actuated. This means water has leaked through the door gasket.
One way to check is to turn power off and draw the dishwasher out from under the sink. May have to disconnect the electric and water inlet.
Tilt the dishwasher to one side and wait for about 1 hour. Try the power on and see if the beep goes away.
You can access this switch by opening the chassis. It is item 5 on page 10 of this parts catalog. You can use a hair dryer to dry the circuit board.
If no help then you have to call the technician as there is not much service information readily available for this model.
See this user manual if you do not have one.
Posted on Jan 24, 2011
SOURCE: error code. Fisher and Paykel Dishwasher
well since you asked on the 5th July, and no reply, doesnt look like you may get one. I thought thats what this site was about??
Posted on Sep 22, 2008
SOURCE: Fisher-Paykel DD603 DishDrawer shows F1
Fisher-Paykel DD603 DishDrawer shows F1 fault code. The Flood Switch has been activated. I need instructions on how to re-set the flood switch. I have two drawers that are possitioned one above the other and the are both giving the error of the activated flood switch. Any advice or instruction is greatly appreciated.
Posted on Sep 23, 2008
  • 75 Answers
SOURCE: My dishwasher keeps flashing F1 error message
The f1 code is caused moisture in the electronics part most likely in the door.see if there is any way that you can see where moisture might get in and plug that spot up. In the case of the f1 code when not using the dishwasher leave the door propped open to help dry out the electronics.
Posted on Nov 18, 2008
E6 error code on fisher and paykel dishwaher
The code E6 is for the flood switch
Pull the appliance out, tip it back about 45 degrees and see if water runs out of the base.
If it does, drain the base (under where the tub) completely and the anti flood should reset.
If there is an aquastop device on your fill hose, after draining the base, turn off the water supply, disconnect the aquastop device and allow it to de-pressurize. Connect it back up and try again.
If it happens again, you'll need to check for a leak.
The normal cause is over foaming, using multifunction tablets and rinse aid, or just spilling rinse aid.
Dec 28, 2016 | Fisher and Paykel Washing Machines
Fisher and paykel error code 6 on dishwasher
Dec 28, 2016 | Fisher and Paykel Dishwashers
How to reset error code on DW60csx1
It is likely the flood switch itself is faulty and may need to be replaced.
Apr 01, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
DW60CE dishwasher - E6 fault flood switch activated. Unit has not been use
After tipping the dishwasher on its side & it releasing its water from its tray, the fault cleared. I removed the bottom cover & inspected its internals for traces of a leak or evidence of leaking.
I could follow the calcium or detergent trail from the rear water duct connection near the top feeding sprayer arm, down the back of the dishwasher & into the tray. The lock nut on the duct where it enters through the inside S/S skin had become loose & simply needed to be tightened.
Jun 09, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
E6 fault unable to reset all cycle lights showing
E6 is "Flood switch activated."
Turn the water off and disconnect power to the dishwasher, then empty water from the inside. Clean drain well and check the drain hose at the back. If that does not work, then the water pressure switch is at fault. Call your Fisher & Paykel dealer or Authorized Service Center.
Dec 06, 2011 | Fisher and Paykel 24 in. DS603MFC Built-in...
5 Fault Codes
F1 ----#
Cause
Jul 16, 2011 | Fisher and Paykel DS602 Dishwasher
F1 error on top and bottom. Power won't shut off until unplugged.
Generally it means the flood switch under the drawer (inside the housing is activated). This means water is leaking from somewhere - foam in detergent, cracked or crinked hoses, door seal leak etc.
To fix, take the drawers out from housing and dry the flood switch located in the centre of the housing base. Need towels and hair dryer.
Make sure the power is turned off.
Jul 14, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Have Fisher and paykel Nautilus dishwasher showing F1 fault - what does this mean? Dishwasher was leaking water all over the floor dont think major problem as it starting draining when power was reset
f1 means u have a leak where pump and control module is. that is located under sump.the water has activated a flood switch near drain pump. need to find leak to fix problem. make sure power is off to unit b4 looking.please reply to how u go. good luck
Mar 16, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Hi Both drawers show error F1 flashing beeping with rinse light on and both pumps run after power is applied to machine
F1 error indicates flood switch in base has activated, meaning machine has leaked. This causes machine to drain continously, and can only be stopped by switching off power. Not easy to fix if you don't have experience- bottom drawer has to be removed to access flood switch, then machine needs to be test run and checked for leaks. Best to call the professionals!!
Oct 03, 2009 | Fisher and Paykel 23 in. DD603H SS...
Fisher-Paykel DD603 DishDrawer shows F1 fault code. The Flood Switch has been activated. I need instructions on how to re-set the flood switch. I have two drawers that are possitioned one above the...
Jul 22, 2008 | Dishwashers
Dishwashers Logo
597 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
