Question about iPhone Apps
My 2004 dodge 1500 magnum v8 ac compressor goes on and off constsntly...blows warm air
    Genius:
  • 1,114 Answers
It sounds like the AC system is low on refrigerant. Auto parts stores carry refrigerant kits to re charge the AC system, or you can take the vehicle to a repair shop that works on AC systems.
Posted on May 18, 2014
How to troubleshoot ac compressor on 2004 dodge 1500 ram pickup
It is low on freon If it is cycling on and off the low pressure switch is causing the cycling. you probably have a small leak. put a can of freon with leak detector in it to help find the leak.
May 18, 2014 | iPhone Apps
My 97 dodge ram 1500 V8 magnum has a wire on the left side of the power distribution center that I don't know where it goes
that is the power wire comes from battery to the box through the fuse then powers all the fuses and relays in that distribution box. if your talking about the wire connector with no wire in it. that is an aux power source to run anything needing 12volts like a salter or snow plow.
Mar 20, 2013 | Cars & Trucks
I need to know how to replace my water pump and thermostat on a 2004 Dodge Ram 1500?
Here's how to replace water pump.Here's the water pump.Here's how to replace the thermostat.Here's the thermostat.
Dec 29, 2012 | 2004 Dodge Ram 1500
Need to change?? how do I change the bearings and clutch on ac compressor for the 1997 dodge ram 1500 - it has a v8 magnum engine
You need a special puller / installer to remove the clutch on the a/c compressor.... It may be cheaper to pick up a used compressor and swap it out.. You can obtain the re-fill charge cans at most auto part stores and fill it your self.
Feb 12, 2011 | Dodge Ram 1500 Cars & Trucks
I have no diagram for the belt routing for my ram 1500 4x4 with a 4.7 litre magnum V8
No year , so took a shot 2004 with AC. Should be same for years in that area.motor1258_8.jpg
Jan 25, 2011 | Dodge Ram 1500 Cars & Trucks
2004 Dodge Ram 1500 = A/C not blowing cold while at idle
A couple of things to look for is low freon, Weak cooling fan or a weak compressor. Hope this helps. Good luck.
Jul 04, 2009 | Heating & Cooling
With ac running cold, blows warm when truck is stopped
I have a dodge 2007 ram 1500...most likely its an RPM issue. The compressor requires a certain RPM to maintain the required pressurized vapor.
Apr 29, 2009 | Heating & Cooling
Air conditioning not blowing cool air
To get the refrigerant in you have to have a technician purge the system first. Hope that helps.
Apr 22, 2009 | 1996 Dodge Ram 1500 Club Cab
iPhone Apps Logo
47 people viewed this question
Top Apps Experts
Bill Boyd
ray gallant
Are you an App Expert? Answer questions, earn points and help others
