Question about Toro TimeCutter MX5060 50" 23HP Lawn Mower 2012 Model
What would cause right steering handle to not function properly?
  • Toro Master
  • 2,760 Answers
Belt slipping/broken, oil level low in hydraulic pump (ck seals) , dirt in steering valve body ?
Posted on Jun 03, 2014
Steering wheel airbag removal on 2006 Cadillac cts cant find bolts
There are no bolts ! it takes a special tool , there are spring loaded Fasteners .
Pull the handle of the air bag tool away from the instrument panel (I/P) releasing one of the spring loaded fasteners.
Steering Wheel Inflatable Restraint Module Replacement
Tools Required J 44298 Driver Air Bag Removal Tool
Removal Procedure
Caution: Refer to
SIR Inflator Module Handling and Storage Caution in the Preface section.
Caution: Refer to SIR Caution in the Preface section.
showgif.do?image=640349
Caution: A deployed dual stage inflator module will look the same whether one or both stages were used. Always assume a deployed dual stage inflator module has an active stage 2. Improper handling or servicing can activate the inflator module and cause personal injury.
  1. Disable the SIR system. Refer to SIR Disabling and Enabling .
  2. On the back side of the steering wheel are 3 openings for removing the steering wheel module.
  3. Adjust and install J 44298 into 1 of the holes.
  4. Important: Seat the air bag removal tool all the way in to perform properly.
  5. Pull the handle of the air bag tool away from the instrument panel (I/P) releasing one of the spring loaded fasteners.
  6. Repeat this step for the other 2 fasteners.
  7. Pull the inflatable restraint module gently away from the steering wheel.
    showgif.do?image=818476
  9. Important: Note the wire routing positions on the steering wheel module connectors, the redundant control routing positions, and the horn wire routing positions for the correct assembly.
  10. Remove the connector position assurance (CPA) (4) and the electrical connector from the steering wheel module.
  11. Remove the horn contact lead (2) from the steering column cam tower.
  12. Remove the steering wheel module (5
Mar 09, 2015 | 2006 Cadillac CTS
What would cause the turn signal to blink continuously?? The only time the left one stops blinking is when you use the right signal??
sounds like the turn signal switch in faulty.
i found some great info that explains the switch and its functions.
Self Canceling Signals How Turn Signals Work
(page 4)
Cheers!
Oct 30, 2014 | Cars & Trucks
What would cause right steering handle to not work properly?
Worst case, you have a damaged wheel motor :(
Your machine is still under warranty? Speak with an authorided dealer ASAP as continuing to run it can cause a lot more damage within the wheel motor / pump system.
May 18, 2014 | Toro TimeCutter MX5060 50" 23HP Lawn Mower...
2003 chevy silverado steering wheel turns easy to the left but really hard to turn back to the right while vehicle is not rolling
check the power steering rack / box for correct hose connections .. check steering / rack for correct operation as the valves in the unit may not be functioning properly.
Mar 09, 2014 | Cars & Trucks
Have a pellet stove that has been working perfect for years, then last night it shut itself off and when I opened door there was this black tar on everything inside and the windows were also black. I had...
Several of things come to mind: Have you changed the type (Brand) of pellets, recently?
Have you had your chimney (stack) cleaned in the past year? Is the fresh air intake functioning properly? Is the auger feeding to much or to little pellets?
Changing brand of pellets - Not all wood pellets are made the same. If you recently changed brands, you will need to tweak your stove to handle this new brand. This will affect how the auger feeds.
If you chimney (stack) hasn't been cleaned in the past 12 months, it may be partially clogged with creosote and not drawing properly and it is liquefying and running back down the chimney and not allowing for a clean burn. And could cause a chimney fire.
Fresh air intake: If that's not functioning properly, you're getting incomplete combustion. Which will cause the black tar looking substance you described. Couple that with changing brands of pellets and you have a problem.
The above are the first things that came to mind. I hope it steers you in the right direction to troubleshoot the problem. Please let me know.
Mar 28, 2011 | Heating & Cooling
I have a clicking sound in the front steering everytime I turn the wheels from left to right, the problem started at 40,000 miles. The car is a Chevrolet Malibu LT V6 2006. I have heard the electriacal...
check the tie rod ends see if one is bent this cause clicking cause hitting other stuff and maybe the steering lock mechanism not fully disengaging
Sep 15, 2010 | 2006 Chevrolet Malibu
On the advice of a friend, I turned my steering wheel full lock bout 15 times while stationary in drive. to try and get some potential air out of the rack. The car is fairly new, only about 8 months old. I...
This should not have damaged anything! If your experiencing problems with your system you may have a bad power steering pump, or obviously a defect in the rack and pinion, Hopefully the vehicle is still uder warranty! If it is, take it to a ford delearship, and let them fix the problem for you. As long as your steering system is functioning properly, you should be able to turn your steering fully in all directions while sitting stationary all day long, without any problems
Feb 14, 2010 | 2008 Ford Fusion
Steering wheel/tires locked up- 2008 jk 4x4- took to service center on friday- would not turn left or right- service manager confirmed probably the gearbox? however, today (monday) they put it on the rack...
First impression is that something in the steering box is loose inside causing the internal gears to bind. When it is lifted in the air, there is no pressure on the system from road resistance causing whatever has jammed to become functional again. If all the steering linkage components are free, I suggest that you replace the steering box. If done at home using scrapyard parts, you likely could replace the pump and the steering box for considerably less than the shop would charge. A chlton or haynes manual can guide you through the repair.
Wait? for what? Reliable steering and brakes are far more important than a running engine! If either do not work properly it can be dangerous!!!
Jan 12, 2010 | 2008 Jeep Wrangler
Washer stops when handle released
unloader valve not functioning properly causes pressure overload and stalls engine
Sep 02, 2009 | Garden
How to identify power steering problem
Start the car, keep it in neutral and then turn the steering left and right. If it takes a significant effort to do so, then it is not working
Jan 07, 2009 | 2004 Chevrolet Malibu
Toro TimeCutter MX5060 50" 23HP Lawn Mower 2012 Model Logo
112 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
