Question about Toro TimeCutter MX5060 50" 23HP Lawn Mower 2012 Model
What would cause right steering handle to not work properly?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 73 Answers
Worst case, you have a damaged wheel motor :(
Your machine is still under warranty? Speak with an authorided dealer ASAP as continuing to run it can cause a lot more damage within the wheel motor / pump system.
Posted on May 20, 2014
Steering wheel airbag removal on 2006 Cadillac cts cant find bolts
There are no bolts ! it takes a special tool , there are spring loaded Fasteners .
Pull the handle of the air bag tool away from the instrument panel (I/P) releasing one of the spring loaded fasteners.
Steering Wheel Inflatable Restraint Module Replacement
Tools Required J 44298 Driver Air Bag Removal Tool
Removal Procedure
Caution: Refer to
SIR Inflator Module Handling and Storage Caution in the Preface section.
Caution: Refer to SIR Caution in the Preface section.
showgif.do?image=640349
Caution: A deployed dual stage inflator module will look the same whether one or both stages were used. Always assume a deployed dual stage inflator module has an active stage 2. Improper handling or servicing can activate the inflator module and cause personal injury.
  1. Disable the SIR system. Refer to SIR Disabling and Enabling .
  2. On the back side of the steering wheel are 3 openings for removing the steering wheel module.
  3. Adjust and install J 44298 into 1 of the holes.
  4. Important: Seat the air bag removal tool all the way in to perform properly.
  5. Pull the handle of the air bag tool away from the instrument panel (I/P) releasing one of the spring loaded fasteners.
  6. Repeat this step for the other 2 fasteners.
  7. Pull the inflatable restraint module gently away from the steering wheel.
    showgif.do?image=818476
  9. Important: Note the wire routing positions on the steering wheel module connectors, the redundant control routing positions, and the horn wire routing positions for the correct assembly.
  10. Remove the connector position assurance (CPA) (4) and the electrical connector from the steering wheel module.
  11. Remove the horn contact lead (2) from the steering column cam tower.
  12. Remove the steering wheel module (5
Mar 09, 2015 | 2006 Cadillac CTS
What would cause right steering handle to not function properly?
belt slipping/broken, oil level low in hydraulic pump (ck seals) , dirt in steering valve body ?
May 18, 2014 | Toro TimeCutter MX5060 50" 23HP Lawn Mower...
Straightening steering wheel on honda element
This needs to be done with special equipment, if you adjust it with out a front end alignment machine hooked up everything else will be out and you will wear out you tires and cause other problems with vehicle handling.
Jan 25, 2012 | Cars & Trucks
I have purchased a 2002 model Nubria. It is an automatic, and on accelerating from 70 to 80 km/h, the cars steering 'floats' to the left or to the right, and requires the driver to compensate. I have...
Take the car to a front end alignment shop and get an estimate for repairs. Sounds like a bent tie rod but a mechanic would have the right equipment to diagnose and repair your car. This will help with both the handling and the life of the tires.
Mar 13, 2011 | 2000 Daewoo Nubira
Power steering pump return line hose keeps busting. why?
Was it replaced with the proper type of hose? If your using a generic hose it may not be able to handle the pressure of the pump and it could cause it to burst.
Jan 03, 2011 | 2001 Chrysler Town & Country
I have a clicking sound in the front steering everytime I turn the wheels from left to right, the problem started at 40,000 miles. The car is a Chevrolet Malibu LT V6 2006. I have heard the electriacal...
check the tie rod ends see if one is bent this cause clicking cause hitting other stuff and maybe the steering lock mechanism not fully disengaging
Sep 15, 2010 | 2006 Chevrolet Malibu
I need a free 1987 Caravan steering column diagram so I can determine why it's wiggling and tighten it so it's safe. the steering wheel is very loose and where I need to get in to tighten whatever is loose...
Rather than take a crash course on how to rebuild a
steering colum. I recomend checking at the local
salvage yards for a used one. To repair your colum
properly you would have to remove it anyway. Also
the parts you would need are not so abundent for a
23 year old car. Hope this helps.
Mar 06, 2010 | 1987 Dodge Caravan
Ford focus power steering problem
Hi, it does sound like your on the right track as the noise gets louder when you turn the wheel. without turning the wheel you should have a slight noise that will get louder when you turn the wheel this would then point me to believ the power steering pump needs replacing.
As your not loosing any fluid then the rest of the steering should be ok so changing the pump will solve your problem, just remember to make sure you bleed the pump properly and the steering properly after fitting the new one as not doing this properly could cause damage to seals inside the rack itself causing more problems than you need so double check you have bled all the air out ok.
Let me know how you get on or if you need further assistance ok
Oct 11, 2009 | 2005 Ford Focus
My turn signal flashes really fast I replaced the bulb and it still does it unless you wiggle the handle, The handle its self works properly i.e. clicks into position for left or right turn, is there a...
try your emergency flashers, do they blink at a normal speed? if yes, replace flasher for turn signals.if not check the bulbs on the side that blinks fastest,even if they look good there could be a broken filiment.tap on the bulb, if the filiment moves it's a bad bulb.
Jul 09, 2009 | 1998 Chevrolet Monte Carlo
Left directional does not stay blinking
The locking plate is held in place by a retention ring that fits in a groove on the steering column. There are several ingenious ways to get it off but you might as well go rent/loan the correct tool as its one of those things that comes off easier than it goes on. The tool will depress a small but very strong spring behind the plate so the ring comes off easily, carefull dont let it fly off and get lost. If the turn signal stalk is not broken this is a good sign as you say that the right side works, you should be able to see what is going on once you have it opened up. Sometimes the turn signal actuator assy can be taken apart and cleaned the springs adjusted and reassembled. If you dont have the experience or the patients just get a new one, but it can be done.
May 11, 2009 | 1995 Pontiac Grand Prix
Toro TimeCutter MX5060 50" 23HP Lawn Mower 2012 Model Logo
52 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
