Question about Samsung AS18A6RB Air Conditioner
Inside air sensor defect - Samsung AS18A6RB Air Conditioner
  • 1,140 Answers
The air sensor is part of the thermostat assembly. It controls the room temperature to whatever temperature it is set at. If the temperature varies too much, you may need a new thermostat. Other problems could cause various temperatures in the room. Low on refrigerant, due to a leak in the sealed system. Water in the system freezes and thaws to cause larger temperature variances.
Posted on May 31, 2014
Chevrolet check engine code 113
Intake Air Temperature Circuit High Input
The Intake Air Temperature Sensor measures the rise and fall of the air temperature inside the Intake Manifold. This provides critical data needed for the Powertrain Control Module (PCM) to control the Air Fuel Ratio, the Ignition Spark Timing and many components of the Emission Control Systems.
Code P0113 sets when the voltage signal to the PCM from the Intake Air Temperature Sensor Circuit stays above 4.5 volts while the Coolant Temperature Voltage readings are rising and falling within an appropriate range.
Common Problems That Trigger the P0113 Code are
Defective Intake Air Temperature Sensor Dirty air filter Defective Mass Air Flow Sensor Faulty or corroded Intake Air Temperature Sensor wiring or connections
May 01, 2014 | Soltek SL-75FRN2-L Motherboard
Replaced emissionpvc valves ,evaporator canister ,evaporator solenoid , throttle sensor leak detector for bad flow, still didn't erase p0114,so changed throttle sensor and map sensor now have p0113 h
  • Defective Intake Air Temperature Sensor
  • Dirty air filter
  • Defective Mass Air Flow Sensor
  • Faulty or corroded Intake Air Temperature Sensor wiring or connections
Mar 31, 2014 | 2004 Dodge Durango
1984 toyota truck has high CO
here are the causes of high CO:
Defective Oxygen Sensor
- Inoperative Air Injection System (if equipped)
- Leaking or defective Fuel Injectors
- Restricted air filter (especially if high CO is present only at high RPM)
- Vacuum leaks resulting in improper MAP sensor operation
- Defective air mass or air flow sensor
- Malfunctioning fuel evaporation system or purge valve
- Defective Catalytic Converter
- Defective thermostat (cooling system), thermostat stuck open
- Oil contaminated with fuel, excessive miles between oil changes
Since this is not injected, you can rule that out.
Feb 09, 2013 | Lanier UNKNOWN
Hi.We have a LG Art Cool mult split, two inside units not work, the green ligths flashing 2 times, and 6 times. hellp-me please.
Green flashing 2 times indicates indoor in piping sensor defective- Replace it.
Green flashing 6 times indicates indoor out piping sensor defective-replace it.
thanks.
Feb 07, 2011 | Heating & Cooling
I have a code flashing on my ecu for a honda
This is from the first or second google search for "honda civic ecu codes". I'm actually going through this myself.
EF Ecu Trouble Codes
Reading EF ecu Trouble codes
Reading them's pretty simple. When there is a long flash this indicates tens and a short flash indicates ones.
Look under the Passenger seat (under the passenger kick panel for flashing LED - engine code. Short the plug under there.
For example: Flaaaaaash Flaaaaaash Flash = code 21
Flaaaaaash Flash = code 11
Flash Flash = code 2
1) Primary oxygen sensor- Defective circuit or unplugged/ Defective sensor
2) Oxygen sensor "B" - Defective circiut or unplugged/ Defective sensor
3) MAP (Manifold Absolute Pressure) Sensor - Defective circuit or unplugged/ Sensor
4) CKP (Crankshaft Position Sensor) - Defective circuit or unplugged/ Defective sensor
5) MAP (Manifold Absolute Pressure) sensor -Mechanical problem/ Disconnected piping
6) ECT ( Engine Coolant Temperature) Sensor- Defective circuit or unplugged/ Sensor
7) TP (Throttle Position) Sensor -Defective circuit or unplugged/ Defective sensor
TDC (Top Dead Centre) Sensor -Defective circuit or unplugged/ Defective sensor
9) CYP (Cylinder) - Defective circuit or unplugged/ Defective sensor
10) IAT (Intake Air Temperature)sensor- Defective circuit or unplugged/Defective sensor
12) EGR (Exhaust Gas Recirculation) -Defective circuit or unplugged/ Defective sensor
13) Atmospheric Pressure Sensor - Defective circuit or unplugged/ Defective sensor
14) IAC (Intake Air Control) Valve- Defective circuit or unplugged / Defective sensor
15) Ignition Output Signal - Missing or defective ignition output signal
16) Fuel Injector System - Defective circuit or unplugged/ Defective fuel injector
17) VSS (Vehicle Speed Sensor) - Defective circuit or unplugged/ Defective sensor
19) Automatic transmission lockup control Solenoid Valve- Defective circuit or unplugged/ Defective solenoid. A/T Only.
20) Electronic Load Detector - Defective circuit or unplugged/ Defective sensor
21) VTEC Solenoid Valve- Defective circuit or unplugged/ Defective solenoid
22) VTEC Oil Pressure Switch - Defective circuit or unplugged/ Defective switch
23) Knock Sensor - Defective circuit or unplugged / Defective sensor
30) Automatic Transmission Signal- Defective circuit or unplugged/ Defective sensor
31) Automatic Transmission Signal "B"- Defective circuit or unplugged/ Defective sensor
41) Primary Oxygen Sensor Heater- Circiut malfunction
43) Fuel Supply System - Defective or malfunctioning Fuel Supply Sytem
45) System too lean or too rich - Malfunction in the fuel monitoring systems
48) LAF (Lean Air Fuel) sensor - Defective circuit or unplugged / Defective sensor
54) CKF (Crankshaft Speed Fluctuation) sensor- Defective circuit or unplugged / Defective sensor
61) Primary Oxygen sensor circuit- High/ Low Voltage, Or slow response
63) Secondary Oxygen Sensor circuit- High/ Low Voltage, Or slow response
67) Catalyst System Efficiency Below Threshold- Malfunctioning catalyst system
70) Automatic Transmission - Malfunction with Automatic Transmission Controls
71-74) Random misfire in Cylinders 1-4- Condition present Creating Misfire
80) EGR (Exhaust Gas Recirculation) Insufficient Flow Detected
86) ECT (Engine Coolant Temperature) Circuir Range / Performance Problem
90) Evaporative Emissions Contrlo System - Leak Detected In Fuel Tank Area
91) Fuel Tank Pressure Sensor- Low Input
92) Evaporative Emission Control System Control System- Insufficient Purge Flow
Ask your autoparts store how much the parts are and decide if it has a point to even do it, its a 19 year old car. You should also ask if that employee works on the side and would do it for you, if you aren't comfortable.
Mar 01, 2010 | 1991 Honda Civic
What does trouble code C-2204 mean on our Minolta C451
this is a waste toner box error the waste toner box could be defective or the full sensor is defective i would start with replacing the waste toner box and clean the sensors on the door with some canned air the waste box and the sensors are located inside the lower front door the instructions on how to remove the waste box are on a label on the inside of the door
Dec 01, 2009 | Konica Minolta bizhub C250 All-In-One...
Dust inside engine and clogging sensor - 2010 Equinox
dust what kind of sensor is this, never heard of such a problem, there no sensor that should hit dust and oil, maybe your talking about a mass air flow sensor, if so that a bad call on the shop to tell you that,maf sensor does get dirty, but they must of put on a defective one, it would take at least a year or two to recollect dirt, the air is filtered with air filter. they should just tell the truth, they got a bad part,goodluck.why scare people with lies, if it the mass air flow sensor.
Oct 27, 2009 | Chevrolet Equinox Cars & Trucks
How can I avoid camera moisture condensation on my Sony a1e camera, it keeps saying turn off for one hour or eject tape and is doing this constantly.
Camera gives Moisture error sign if it really have moisture condensation inside or its moisture sensor itself got defective.
if moisture is inside, blow hot air in camera mechanism for 5-6 minutes by hair dryer (not so closed with mechanism) and check / test.
If problem still exist it means moisture sensor is defective and i know its Sony high-end model camera and know how to fix it yet I would recommend to take camera to Sony Service center for proper repair.
Dec 06, 2008 | Sony HVR-A1E HDV Digital Camcorder
Hitachi model number unknown !! (faded 0ff unit)
dirty unit and need for cleaning
clogged up expansion valve
defective fan motor
deffective air sensor
May 22, 2008 | Hitachi RAS-09UH Air Conditioner
Samsung AS18A6RB Air Conditioner Logo
51 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
