Question about iPhone Apps
How to troubleshoot ac compressor on 2004 dodge 1500 ram pickup
It just goes on and off constantly blows warm
It is low on freon If it is cycling on and off the low pressure switch is causing the cycling. you probably have a small leak. put a can of freon with leak detector in it to help find the leak.
Posted on May 18, 2014
My 2004 dodge 1500 magnum v8 ac compressor goes on and off constsntly...blows warm air
It sounds like the AC system is low on refrigerant. Auto parts stores carry refrigerant kits to re charge the AC system, or you can take the vehicle to a repair shop that works on AC systems.
May 18, 2014 | iPhone Apps
Fuse keeps blowing on a/c on 1500 dodge ram
if you dont use ac then just pull the ac wire off in other words unplug it should be on the backside of your ac compressor
Apr 01, 2014 | 2001 Dodge Ram 1500 Truck 2WD
Dodge Ram Pickup, 2004/ A/C System
It should be moving air from outside the grille thru the radiator and into the engine compartment.
Oct 08, 2012 | 2000 Dodge Ram 1500 Truck
I just replaced the AC compressor in my 06 3500 Dodge Ram. It worked great for a week, then the passenger side started blowing warm, now all vents blow warm? Had freon checked and compressor, both are...
The expansion valve could be sticking or the blend doors not opening. Since the problem started on one vent, then i would lean more toward the actuator on the blend doors. I hope this helps.
Jul 29, 2011 | 2008 Dodge Ram Pickup 3500
2004 Dodge Ram 1500 = A/C not blowing cold while at idle
A couple of things to look for is low freon, Weak cooling fan or a weak compressor. Hope this helps. Good luck.
Jul 04, 2009 | Heating & Cooling
Dodge Ram AC not blowing cold
By pass both pressure switches one at a time with small wire or a paper clip. If comperssor kicks on replace the swich that you bypassed.
if not it could be the fan clutch ot the compressor. Compressor runs about $400.00
Jun 15, 2009 | 2000 Dodge Ram 1500 Truck
With ac running cold, blows warm when truck is stopped
I have a dodge 2007 ram 1500...most likely its an RPM issue. The compressor requires a certain RPM to maintain the required pressurized vapor.
Apr 29, 2009 | Heating & Cooling
Air conditioning not blowing cool air
To get the refrigerant in you have to have a technician purge the system first. Hope that helps.
Apr 22, 2009 | 1996 Dodge Ram 1500 Club Cab
iPhone Apps Logo
41 people viewed this question
Top Apps Experts
Erin Wood
Erin Wood
Are you an App Expert? Answer questions, earn points and help others
