Question about Karcher Garden
No pressure only tap water pressure not power from the washer
  • ivor batham
    ivor batham May 20, 2014
    have tried all connections water comes through ok but no pressure
  • 118 Answers
The sliding valve at the bottom of the unit is stuck, find the cap screw unscrew it and remove the spring and valve clean it and lube it with silicone grease and put it back together. GOOD LUCK.....
Posted on May 24, 2014
I have no water pressure coming out of the frost proof faucet... tap is on full, but water is bearly coming out. What can i do?
Rubber washer at the end of inside of tap may be cramped and full of dirt or buckled. when turning tap on.You need to shut off water pressure and take tap apart.
May 24, 2018 | Plumbing
What does 4C mean during a wash cycle
4C Water is not supplied.
• Make sure the water taps are open.
• Make sure the water hoses are not clogged.
• Make sure the water taps are not frozen.
• Make sure the washing machine is operating with sufficient water pressure.
• Make sure that the cold water tap and the hot water tap are properly connected.
• Clean the mesh filter as it may be clogged.
NOTE
When the washer displays "4C", the washer do draining for 3 minutes. During this time, the Power button is inoperative.
Feb 11, 2018 | Washing Machines
Stalling pressure washer
Make sure you have a strong water supply going into it. On the two I have owned, they would struggle and the motor would "rev up" quite a bit if there was even a slight kink in the supply hose, or if the tap wasn't opened all the way.
May 18, 2012 | Craftsman 2500 PSI Briggs & Stratton...
The rinnai 20 Infinity is perfect but have recently noted a problem. I found the basin hot water tap in the bathroom begin dripping only when the kitchen hot water tap is turned on. I don't know how...
Some taps are designed to release excess pressure but it could just be a dodgy tap washer that leaks when the pressure of hot water in pipe work builds. Change the tap washer in your tap, see if it fixes it, if not it's just the design.
Jul 02, 2011 | Water Heaters
Washing machine displays FH fault and water tap closed light comes on,water taps are both on and working correctly.
? If there is no water in the unit: —Make sure that both valves at the water source(s) are turned on all the way. —Check for plugged or kinked inlet hoses or plugged screens in the inlet valves. —Verify inlet valve operation. ? If there is water in the unit: —Verify drain pump operation. —Verify that the pressure switch hose is in good condition and properly connected to tub and pressure switch. 1. Verify there is not a siphon problem. 2. Unplug washer or disconnect power. 3. Verify wire harness connections to inlet valves, pressure switch, drain pump, flow meter, and Central Control Unit (CCU). 4. Check all hoses for possible leaks. 5. Plug in washer or reconnect power 6. Verify pressure switch operation. 7. Verify flow meter operation by blowing air through the part and measuring the resistance. 8. Verify CCU operation by running a Diagnostic test or any cycle.
Apr 27, 2010 | Washing Machines
I get a check water tap error 2 to 4 times a load
I have this problem. This code is due to restriction of water flow. In my case, we have sand in our water, and I have installed a filter between the water line and the washer. When it gets clogged, the flow is restricted and the Check Water Tap message appears. Your washer has filters on the back of the washer itself that may be clogged and need cleaning (which is why I installed the water filter between the washer & water line to prevent it from getting into the washer filter). Your washer manual shows you how to check/clean them. Also, you may have low water pressure during summer months due to lawn watering in your area that could cause this lower water pressure.
Jun 23, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
How do i know if my outside tap has a non - return valve i want to start using a pressure washer
Dear del_brenda_s,
I have been servicing Power Washers for the last 5 years. And I cannot understand why you need a non-return tap outside. I think "outside" you are refering to the main supply after the water meter.
Well if your power washer needs a non-return, you can fit a cheap garden hose non- return attachment.
Regarding the non-return at the outside tap,..this is most probably NON-RETURN. If you want to be sure you can contact the water works division of your country and city...and I am sure they know what sort of taps should be used. In my country it is a must that a non-return outside tap is used. This is important so that when there is a cut in the water supply, the water meter and the whole system will not have to be bled out of air when the water comes again.
Regards,
Fulltech.
Apr 19, 2009 | Karcher K2.26 Electric Power Washer
Error code E10 on the electrolux ecovalve EWF1087 front load washer. What does this mean?
E10 is a timeout code. I found the answer on google by refining my search criteria. The tap was not turned on enough for the washer to fill up in time before the timeout was reached. After restarting the washer and turning the tap on further, the washer cycle completed without error.
Jul 22, 2008 | Electrolux Washing Machines
Water flow very very slow though the pressure from main tap is fine
almost certainly not a fault with washer. check small filters in the fill hose and make sure hose not kinked
Jul 18, 2008 | LG WFT1071TP Top Load Washer
Garden Logo
85 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
