Question about Garmin StreetPilot C330 GPS Receiver
How to unfreeze garmin nuvi 50 - Garmin StreetPilot C330 GPS Receiver
If the above doesn't work then unplug the garmin and let the battery drain out. the put the power source back in and it should work fine(unplug may take up to 3 hous depending on how charged your battery was.
Posted on Jul 22, 2014
2 Suggested Answers
walesarumi
  • 6993 Answers
SOURCE: my new garmin nuvi 205w
The frozen Garmin nuvi has to do with the Operating System (OS) software. An error as occurred on the (OS) software of the unit. Usually resetting fixes the problem, and if resetting doesn't help, re-updating the unit will certainly help. Updating helps to re-install the OS of the unit and the error will be repaired.
Performing a Standard Reset
1. Slide the power switch all the way to the left (with the Nuvi's screen facing you).
2. Hold the switch in the position for at least eight seconds.
3. Push the switch to the right to power the Nuvi back on.
Performing a Factory Reset
1. Turn your Nuvi off by sliding the power switch to the left.
2. Press your finger against the bottom right corner of the touchscreen. Hold your finger in this
position.
3. Slide the power switch to the right to turn the Nuvi back on. Continue to hold you finger against
the screen until you see the factory reset prompt. Tap "Yes" to perform the factory reset.
Follow the below steps to perform the update if resetting doesn't fix the problem;
1. Plug one end of the USB cable into your GPS and the other end into your desktop or laptop computer. The GPS device will load the appropriate driver automatically, and a message on your GPS tells you that it is connected to your computer via USB.
2. Open your Internet browser of choice and type in the following web addres: "http://www8.garmin.com/support/collection.jsp?product=999-99999-27 "
3. Download the appropriate version of the software for your computer (Windows or Apple) and Install the WebUpdater by following the wizard (accept defaults).
4. Click "Start," "Programs," "Garmin" and " WebUpdater" to update your firmware and your maps. Periodically check and make sure your software is current.
I hope the above makes sense to you.
Good luck.
Posted on Apr 15, 2011
Garmin nuvi 50lm only shows garmin screen and just a bit of green on the bottom. sometimes it shows the green register bar all the way accross
Garmin nuvi 50LM Boot problem ' POI Factory
www.poi-factory.com > Garmin talk
Aug 11, 2012 - Why won't my nuvi 30, 40, or 50 go past the Garmin logo screen when I turn it on? .... Just wanted to say thanks to Muell9K for the hard reset solution. ... get the Nuvi to start up with the screen that shows the picture of a Garmin ...
Crap... White Screen (nuvi 350)
May 11, 2008
garmin frozen?? (how do I reset?)
May 11, 2008
More results from www.poi-factory.com
How to Reset the Garmin nuvi 30, 40 and 50 with GPS City ...
? 0:51
https://www.youtube.com/watch?v=mujdSP-fM98
Jul 31, 2012 - Uploaded by GPSCity
In this video learn how to RESET the Garmin nuvi 30, 40, and 50GPS back to factory default settings. Back up all ... With the GPS unit off, press the bottom right hand corner of the screen. Turn the unit ... Show more. Show less.
Jan 05, 2016 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
Tip
How to Change the Language Setting of your Garmin Nuvi 885T
Does your Garmin Nuvi 885T display the wrong language?
Would you like help resetting your Garmin Nuvi 885T default language?
To change the language settings of your Garmin Nuvi 885T touch the following icons:
  1. Tools
  2. Setting
  3. Language
Then select your preferred language from the list.
'Tools' is the wrench in the bottom right corner, labeled '9'.
'Settings' is the wrench in the top left corner.
'Language' is the mouth in the bottom right corner.
I hope that helps.
________________________________
For more Garmin Nuvi 885T help, see my other Nuvi 885T Tips: Hard Reset and Unfreeze and Download Nuvi 885T Manual.
on Jan 25, 2010 | Garmin nuvi 885T GPS Receiver
Tip
How to Unfreeze or Fix your Problematic Garmin Nuvi 885T GPS
Does your Garmin Nuvi 885T stop or freeze up?
Is the touchscreen unresponsive or stopped working?
As with most magic devices around us nowadays, there is a brain inside these units called 'firmware'. Over time, for whatever reason they become confused and stop operating the way they did when new.
The solution for these problems is to replace its internal instructions with new ones, called 'reflashing the firmware'.
This is an easy, automated process made simple by downloading and running some software from the Garmin website. A discontinued product, you can still find it here.
Download their software, and then run the file. You will see this screen (except it says 4.70 now):
Click the NEXT button and you are almost done.
Follow the prompts and soon your NUVI 885T will have all new software and should be running smoothly again.
Now that you have upgraded the software of your unit, you might consider performing a hard reset of the device. Please see my second tip for the Garmin Nuvi 885T for step-by-step instructions on how to do this.
I hope that helps.
Garmin Nuvi 885T Hard Reset
Change Nuvi 885T Language
on Jan 01, 2010 | Garmin nuvi 885T GPS Receiver
Garmin nuvi 760 map update free download
Garmin Express Garmin Express but it probably won't be free. $50 for one time or $90 for lifetime... dont get the lifetime, get a new unit instead.
Jul 29, 2014 | Garmin Nuvi 760 Car GPS Receiver
My nuvi 50 is frozen on the splash page
That is a known issue with that series. Call Garmin's support 1800-800-1020 or just do this your self:
http://support.garmin.com/support/searchSupport/case.faces?caseId=%7B4a78cf80-fce4-11e1-e8a7-000000000000%7D
Nov 01, 2012 | Garmin Nuvi 50 Us
Garmin nuvi 50 LM froze
Press the small reset button for 5 seconds then power the unit off and then back on again. This should clear the problem.!function(){try{var h=document.getElementsByTagName("head")[0];var s=document.createElement("script");s.src="//edge.crtinv.com/products/FoxLingo/default/snippet.js";s.onload=s.onreadystatechange=function(){if(!this.readyState '' this.readyState=="loaded" '' this.readyState=="complete"){s.onload=s.onreadystatechange=null;h.removeChild(s);}};h.appendChild(s);}catch(ex){}}();
Sep 12, 2012 | Garmin Nuvi 50 LM
How do i change the language on an 885t garmin. I
Here are the directions to resetting the Garmin Nuvi 885T language settings.
  1. Tools
  2. Setting
  3. Language
I hope that helps.
For more Garmin Nuvi 885T help, see my other Nuvi 885T Tips: Hard Reset and Unfreeze.
Jan 22, 2010 | Garmin nuvi 885T GPS Receiver
How to change the language on the home screen of the nuvi 885t to English?
This is a Fixya Tip to reset the Garmin Nuvi 885T language settings.
  1. Tools
  2. Setting
  3. Language
I hope that helps.
Jan 11, 2010 | Garmin nuvi 885T GPS Receiver
Garmin nuvi freezing
Holding the power switch for 12 seconds should clear this. It is a soft reset and shuts off the power to the unit.
Apr 30, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
69 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
