We have a new house and it came with central air. I have turned on the air and turned on the circuits and noticed that the outside fan on the outdoor unit was spinning round (good) now, I checked and the fan is not turning. Turned the unit on and off, still no turning and checkecd the circuit breakers...Any help please. Model is Aire_Flo Outdoor unit AFAIR12B30-A P I hear a low hum to the unit outside. I see trouble here.
  • dionneny Jun 24, 2009
    Thanks, I checked the outside fuse box and it had the "fuse broken" light on. We went to Menards and replaced the fuse. You saved us 100s of dollars on a service call, and I want to thank you.
  • 43 Answers
First check to be sure the circuit breaker for the outside unit is not tripped. Turn the two pole breaker all the way off all the way off and then back on. If the outside unit still does not run you may have fuses in a disconnect box by the outside unit that are blown. You can check them with an OHM meter. No OHM reading means they are good.
The low hum you hear is probably the control voltage from the thermostat pulling in the contactor (switch that starts the outside unit). If no line voltage (230 VAC) comes to the unit it will not run.
Posted on Jun 24, 2009
  • FunnyPlumber
    FunnyPlumber Jun 24, 2009
    That is good I could help made your unit run. My concern now is what caused the fuse to blow? It would be a good idea to have a qualified air conditioning technician test your system to try and find what caused the fuse to blow as if you don't it will probably blow again. Fuses just don't go bad by themselves.
    Best wishes and may your toilet never run over.
    Terry aka Funny Plumber
  • 69 Answers
Yes indeed Id have to say the motor hasent been oiled....call a hvac guy and see how much theyd charge ya for maintenance call and decide then as if its priced right for you. after the inspection he'll tell you "XXXX" is wrong and you need this or that.
Cool air from home vents with central AC outdoor unit fan will not turn on. Inside home really loud when on!!
its look like blower problem , 1st check blower speed controller, check blower motor , check its ball bearing etc , its does not have any link to external unit .
Jun 15, 2014 | Goodman Heating & Cooling
Central heating and air fan not working
it may have frozen and loosened someting it might just need to be seviced
Feb 27, 2014 | ATP HVAC - Heating, Ventilating, and Air...
My air conditioner fan is not working
Check the outside fan and make sure it rotates freely. If it doesn't spin freely it needs to be replaced. If it does spin freely then check the capacitor. If the capactitor is OK the check the fan motor windings for continuity with an ohmmeter. Let me know what you find.
Jul 18, 2010 | Heating & Cooling
I have the York Outdoor Split System Air Conditioner- Model # h4de024S06A, Installed in my home on june 12, 2004. We had no problems at all until last night when we noticed that the Furnace of the Fan is...
I think you may have 2 problems. Thje outdoor fan not coming on would cause the compressor to either go out on high discharge pressure or internal overload. Either the fan is bad or the capacitor is bad or both, which can be replaced.
The second problem is either the unit froze up on you and for the short time that it will cool before it quits. You may want to make sure you cool speed for your indoor unit is set to hi cool speed which is usually black
Jul 06, 2010 | Heating & Cooling
Hi i have a rheem central air unit. The outside unit does not want to turn on. i just recharged it with freon about a month ago so it cant be that
Check the circuit breaker(s) for the outdoor unit. Then set the thermostat to make the unit come on and see if the contactor pulls in. If it doesn't turn the fan switch from auto to on and see if the indoor fan comes on. If not your transformer could be shot. If the contactor pulled in on the outside unit check the capacitor for the fan and compressor.
May 21, 2010 | Heating & Cooling
Hello We have a Trane central air
Bad thermostat, improper wiring or bad circuit board in furnace. Turn off the disconnect outside.
Dec 30, 2009 | Heating & Cooling
Unit not coming on. air isn't getting cold
First check the breakers for the condensing unit (outside unit) and the disconect outside by the unit (could be a breaker ,a pull off/on switch or fuses)If its ok , you should have 220 ,240 volts to the unit contactor (you'll see it after removing the cover on the condensing unit).When the termostat is in the cold position and the temperature its set is lower than the one inside the house the contactor should be pulled in and give power to the compresor and the fan.But if the termostat is in the cooldest set and the blower inside the house works and the contactor in the condensing unit is not pull in the problem is in the termostat or in the low voltage wire.
Apr 24, 2009 | Heating & Cooling
Airconditioner problem
This unit has a bad Start/Run Capacitor or a bad Fan Motor! Replace the $10 Cap...An then the $90 fan motor if the Cap dont solve it!
Oct 01, 2007 | Heating & Cooling
Heating & Cooling Logo
113 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
