Question about Ovens
Why my cooking range big burner giving yellow flame whereas other burners running.
    Genius:
  • 1,114 Answers
A yellow flame indicates not enough air is reaching the burner. That particular burner may have a clog which is preventing sufficient air.
Posted on May 18, 2014
redbeard00
  • 957 Answers
SOURCE: yellow flames causing carbon buildup
If the burner bar has an adjustable slider for increasing or decreasing air into the bar.That would be it. If not then there is a defect with the gas valve or burner bar.
Posted on May 30, 2009
dmftrucker
  • 1922 Answers
SOURCE: Propane stove burns yellow & creates soot
clean the orfices and tubes and then if possible adjust your air mixture setting also
Posted on Oct 02, 2009
  • 13 Answers
SOURCE: Front right burner on GE glass top range not working
If you have the glass cooktop slide-in model, the problem is most likely the burner "ribbon' under the glass top for the small burner has come loose. I fixed mine with only a phillips-head screwdriver, needle-nosed pliers, and a 1/4" wrench (1/4" socket on the end of a nutdriver works better). Here are the steps I took to fix it: 1) Slide the oven out from the counter so the sides of the oven are clear of the counter top. 2) Remove the phillips head screws-1 on each side of the oven near the top/rear. These will be the only phillips-head screws you will need to remove. 3) Open the oven door and remove the 4 hex-head screws at the top/front/inside the oven- there are 2 on each side which follow the opening of the door. Then close the door. 4) Pull off the burner knobs by gripping them and pulling straight up. Don't worry, you will not break them but you will need to give them a good tug. 5) Remove the burner retaining nuts that are under the knobs-you may need a wrench to loosen them but only tighten them by hand when reinstalling. 6) Pull the face of the control panel away from the oven slowly until you see a ribbon connector on the right side and then disconnect the ribbon and remove the face plate from the oven. 7) Remove the 4 hex-head screws from the face plate bracket (the plastic part that was holding the face plate) and pull the bracket toward the front of the oven until it flops over and rests on the oven door handle. 8) remove the 2 black screws holding down the glass top-one on each side of the oven-the screw heads face the front of the oven. 9) Disconnect the two wiring harnesses attached to the cook top. Don't worry, they only fit one way so you don't need to label them. 10) Lift the cook top until the wiring harnesses are clear of the holes and place it upside down on a flat surrface. 11) Remove the two retaining bracket screws and brackets from each side of the non-working burner. 12) Slowly lift the burner and flip it upwards until you see the ribbon coils. It should not be necessary to disconnect any wires. 13) Look at the ribbon coils very carefully to see if any of them are disconnected from their main connection points. If so, feed the ribbon back inside the pinch point (you may need a small screwdriver to open the pinch point first) and then use a pair of needle-nosed pliers to pinch the ribbon to hold it in place. I had to use a voltage meter set in the OHM position to find where mine were disconnected. Once you pinch the ribbon end back into place, put everything back together in reverse order. If your burner still does not work, your burner knob switch may be bad. I hope this helps. Good Luck!
Posted on Jul 24, 2010
  • 1891 Answers
SOURCE: Maytag electric range with ceran
the biggest burner is i belive r front . the burner with limiter will have to be replaced as it does turn on and cycle but after warm up shuts down so burner element are of and tempt sensor is bad . just replace it and our good to go mm
Posted on Sep 02, 2010
  • 19 Answers
SOURCE: Hello, We have a Kenmore
It sounds like yous stove is working fine. Cycles fine. If you think the stove is cycling more often than when new then ck the seal on the door. You may be loosing heat.
Posted on Jan 14, 2011
Testimonial: "Okay. Good advice. Thank you. "
How to change lower element in DeLonghi Airstream Convectio Oven
  • How to change lower element in DeLonghi Airstream Convectio Oven??
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Oct 28, 2017 | DeLonghi Ovens
    I have a whirlpool range rf263lxtq the oven stays consent on what is wrong with it
    Oven clicks as if it is relighting almost constantly.
    · Old electric range ovens use a coil heating element called a resistive coil.
    This is nothing more than an electrical wire encased in a sheath. They have flat black coils over rounded burner drip bowls that catch your drips and spills.
    · The newer glass-ceramic cook top style element produces heat that radiates through the glass top to the cookware above.
    · Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
    · Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
    2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
    3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
    spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
    Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
    If it would not fix the problem, replace the bake burner and the igniter.
    There is a small chance for the spark module itself to be bad as well.
    ELECTRIC OVENS:
    CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
    Feb 15, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
    Pilot light flame too loeeds adjustment
    Adjust the pilot flame height using the adjustment screw for each burner.
    Mar 12, 2014 | Magic Chef Ovens
    Fridgatare modle #FGG3054KFB I have a frigidaire range that has been converted to propane. When the oven is turned of it has a strong propane smell and there is alot of moistier inside. The flame is about...
    It shouldn't be burning yellow and emitting soot at all;sounds like on of these possible causes-
    (a)blocked burner airways(this can lead to yellow tipping and sooting on LPG powered appliances because insufficient air is getting through to the burner causing it;you can also get this effect on LPG barbecues say if dead insects or spiderwebs are in the burner pipes and airways after a period of storage),
    (b)incorrect aeration being set when the burner was converted using LPG jets(too much gas and not enough air causing yellow flames/smells and sooting),
    or (c) if you use propane cylinder gas a dicky or faulty regulator. I would get it looked at investigating all the possibilities I mention and taking action to correct this where necessary ie clearing the burner airways(if this is causing your problem), adjusting the aeration in the burners until you get a clear noiseless blue flame without any excessive yellow and sooting(but even after good adjustment you may find still get a very slight yellow tip without sooting at the top of the flame;this does happen with propane gas and there is a slight tendancy for this to happen more often with butane-butane tends to display very slight yellow tips on ignition increasing slightly as the burner warms up to full temperature) or if you use propane cylinder gas replacing the regulator if that is necessary.
    Nov 22, 2010 | Frigidaire FGB24S5A Gas Single Oven
    Hello,do you know what would cause the following problem in an Electrolux Cooker,MODELNO: DD061, PROD NO: 948522135, SERIAL NO: 42900006. THERE IS AN ODD TASTE OFF THE FOOD WHEN COOKED IN THE MAIN OVEN?
    is it a gas range?are you getting soot? you need to look at flame while unit is on, remove oven botton to expose the burner, easy!!!! 2 screws on back inside over and pull bottom up. shut door turn on range and look at flame if it is yelolow and long flames you need air ajustment at burner, inside very bottom door you will see the air shutter, open it a litttle if falmes are yellow and long and test it again.
    Feb 01, 2010 | Ovens
    Sep 21, 2009 | Frigidaire FGB24S5A Gas Single Oven
    Yellow flames causing carbon buildup
    May 30, 2009 | GE JGRP17 Gas Single Oven
    Oven lights on low flame but will not come up on high flame .cannon chester cooker.suspect by pass is not working. Do I need control knob/thermostat with the phial. Thanking you.
    all gas range ovens have a small metal box in the back upper area of the broiler burner; a gas line runs into this box as do two wires; this is a "flame control " gas valve; the way it works is: after the pilot has been lit as you turn the oven temp control a heating element in the box causes a small valve to open allowing a larger amount of gas into the oven burner to ignite the whole burner If you can only get pilot flame on high replace this valve
    Apr 26, 2009 | Ovens
    Not enough gas to range?
    you either have a gas pressure problem from your meter outside or a bad pressure regulator on the range. if you use a magnehelic guage (get from a plumming supply house) you should be getting about 11inches of water coloum, or you can call your gas company to check it out... Let me know how it goes.
    Jan 09, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
    Large yellow flame, not cooking food thoroughly
    I think ill give it a try for you. The gas lines come in thru you cutoff valve then thru you gas valve and on to the burner. right before the burner you will see a bell shape fitting. The gas line is in the center of the fitting and there will be some opening around this fitting That fitting has dust clogging it up. This is where the gas mixes with the air Turn your oven off and blow this fitting out.
    Oct 25, 2008 | Blodgett 911-DOUBLE Gas Oven
    Ovens Logo
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
