Question about JVC AV-32D305 32" TV
Remote Control malfunction
ModelJLC32PC3002 Serial 1DA1023300415 Remote 098003060012/120515 C I have Tivo through DirectV. Batteries are fresh in the remote control, however, I am unable to control the volume with the tv remote nor the DirecTV remote. DirecTV stated they no privy to any other manufacture's product. Please advise what action should be taken to correct this malfunction. The tv was purchased new approximately 2 years ago. Thanks. Gregory
  • 13 Answers
SOURCE: jvc remote control
"i already paid for the tv so why pay for something that should be readely available to me in the first place I should have access to all the features on the tv ".. WRONG!!!!!!!!!You should have a warranty for this TV but it's old , anyway. First,receive a reference image (let's say CNN).Second:press "Sleep Timer" key and set the value to "0". Then press "Display" and "Video Status" keys at the same time. Third: use "Vol +/-" and " Channel +/-" to select "2.DEF(D)".Go to "D03: V.SIZE" and modify step by step the value for best fitting. There is also switch " SW401" on the main board for centering the image . Finally, press "EXIT" key till you exit the "Service Menu". Don't try to modify anything else!!!!!!!!!!!!!!!!!
Posted on Nov 20, 2007
  • 579 Answers
SOURCE: Opening the case of a JVC Remote Control
Not having seen that particular one, remote cases usually have a couple screws under the battery to lock the case together and then a number of plastic tabs around the perimiter that hold the joint closed. find the screws (sometimes they hide them under labels) - I don't know what it is about screws that manufacturers don't like to show. Either think they are not cosmetic or don't want us take-it-apart maniacs to get in. Anyway, get the screws loose then (this is the hard part) carefully pry open the case joint, feeling where and how the tabs snap out and then be careful not to have everything inside go flying when the last one lets loose. Almost impossible to not leave little gouge marks in the joint.
Hope Ya Fis It!
Posted on Jan 08, 2008
premtech
  • 934 Answers
SOURCE: JVC Channel Code locked and need to unlock
The square box is not a channel lock it's closed caption and labled CC in your menu.. Go into the menu and set CC off... No more box...
Posted on Jan 27, 2008
talon1973
  • 17 Answers
SOURCE: JVC I'art flatscreen TV remote doesn't work
This maybe a sticky one.
#1. Original remote may have something spilled in it or may have dirty battery contacts.
First check battery contacts and make sure it's not corroded. Clean with small brush and baking soda. Let dry thouroughly and replace with fresh batteries.
If this isn't the problem or you tried this, then move on.
Next, Get these materials. A cloth, 50% amonia and 50% water sulution two small blad pocket knife and a philips head screwdriver.
Some remotes will have screws holding remote covers and internal board and others do not. If your remote have screws, remove them all. If not, then start prying your remote apart with your pocket knives. Do so very carefully as not to damage anything inside.
Next, lay down remote button facing down, and remove circuit board. Now, take note of rubber button pad(s) position(s) and remove them. Place these pads in your water - amonia solution.
Clean all cntacts and rubber pads, and remote housing. Now before reassembling remote, look at the IR lamp at end of board. Look underside and notice solder joints. Wriggle lamp and see if solder joints move. If so, have this resoldered. Now reassemble remote and give this a try.
#2) Codes may have not been entered right with your new universal remote. Go through all codes again just to be sure.
#3) IR receiver in set maybe damaged or not receiving power to it or the microproccessor has quit responding to the remote commands. Have a good technician check into it if problem is evident that your set has simply stopped responding to remotes.
Good luck,
Jason.
Posted on Jan 09, 2009
  • 10 Answers
SOURCE: remote control code for jvc tv
HERE IS SOME CODES FOR THAT TV 557 558 559 560
Posted on Jan 11, 2009
Why will the volume on my remote control for my tivo box not work when everything else does
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://youtu.be/wUpnETSm6_k
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Jan 12, 2017 | Tivo Televison & Video
Tip
DirectTV RC65 Programming
TIVO DirectTV RC65 Remote Control Programming
Here are the steps to program your TIVO Direct TV RC65 Remote Control:
  1. Locate the 5-digit code for your DIRECTV® Receiver. (See Users Manual)
  2. Power on the DIRECTV Receiver.
  3. Slide the MODE switch to the DIRECTV position.
  4. Press and hold the MUTE and SELECT keys until the green light under the DIRECTV position flashes twice, then release both keys.
  5. Using the number keys, enter the 5-digit code. If performed correctly, the green light under the DIRECTV position flashes twice.
  6. Aim the remote at your DIRECTV Receiver and press the PWR key once. The DIRECTV Receiver should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
Your TIVO DirectTV RC65 remote control is now setup to control your DVR. A digital copy of your remote's owners manual is available here.
Instructions for the RC65 Code Search function to find compatible remote codes are here.
I hope that helps.
on Apr 02, 2010 | Tivo DirectTV Remote Remote Control
My remote as stopped working my tivo box
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience.
If remote control is working OK, check and replace the remote sensor inside the TV. Contact any service technician.
Aug 13, 2014 | Tivo C00210 Remote Control
Check the remote control for its infrared emission by pressing all buttons on it. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box. or "How to check a remote control"
May 18, 2014 | JVC AV-32D305 32" TV
I need the remote (RC23) code for a series 2 Tivo Model TCD54008
if the remote is RC23, the tivo codes are 01442 & 01142. If you actually have a Rc16, then you can only control the tivo partially with code 20618 on either AV1 or AV2 device slots.
Jul 31, 2009 | Directv RC23 Remote Control
Need to program a directv philips series 2 remote
tivo button is the Directv button (tivo home) at the top of the remote. if u have the new directv remote, the tivo home button is the menu button. remote needs to be on satellite. to program codes.
Dec 20, 2008 | Philips DSR708R DirecTV / TiVo DTV...
Directv Tivo recorder no remote programming code for Visio 37''
If it were a Tivo series 3 you might have better luck with it.
http://www.tivo.com/setupandsupport/technicalsupport/compatibilityhelp/Using_the_Learning_Feature_of_the_TiVo_Glo_or_Series3_Remote.html
I've had my series 2 Tivo for about 2 1/2 years and never found the correct codes for it. I think it works off of a list of TVs manufactures about 3 years ago.
Nov 22, 2008 | Vizio L37 Television
REMOTE WON'T WORK WITH TV
The problem is the DVR is only programmed using a set amount of codes. They don't update them. If your DVR is a few years older than your TV set, you're out of luck. .
You could contact DirectTV customer service and see if they have a solution in technical support for that tv. It's possible another set of manufacture codes will work with it and tech support has it noted.
Sep 12, 2008 | Tivo DirectTV Remote Remote Control
Tivo DirecTV Remote-Program AKAI LCT2721AD
Try this: On the Tivo remote press and hold the TV Power button and the Directv/TIVO button at the same time. Hold both buttons down for about 4 seconds or until remote light stays red. Then press the channel up button until the tv turns off. You may press the button over 100 times. You need to go slow. When the TV turns off press the enter button (or select button).
Dec 09, 2007 | Tivo DirectTV Remote Remote Control
JVC AV-32D305 32" TV Logo
23 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
