What atre 7 conitients of the world - Computers & Internet
My windows laptop does not detect the mic when i plug it in. it used to, and i know that the mic works
If using windows 7 go to sounds then properties then go to microphone than make sure enable after that test levels
Oct 14, 2013 | Audio Technica Audio-Technica ATR-20...
I get problem in my printer CANON IRC3580i the erorr code is: E000020-0012, so any body can help me?
1. Check to see if the ATR shutter comes off; if so, re-fit it.
2. Wipe the ATR sensor window with a damp cotton cloth.
3. If the symptom still occurs, replace the ATR sensor with a new one. 0012 is for the cyan drum
Sep 08, 2010 | Canon imageRUNNER C3200 Copier
Error codes 000070-001 and 00020-081 for iRC3180i
E020 Drum/Developer-related error
XX=01:Y XX=02:M XX=03:C XX=04:K XX=00:Any color
XX10 In INIT control of the initial setting,
SGNL is less than 62. Clean the ATR sensor window, Check on attachment of the developing unit, Check on a break
in the ATR sensor, Replace the ATR sensor
XX11 In INIT control of the initial setting,
REF is less than 62. Check on a break in the ATR sensor, Replace the ATR sensor
XX12 In INIT control of the initial setting,
SGNL is 960 or more. Check on a break in the ATR sensor, Check on operation of the shutter, Replace the ATR sensor
XX13 In INIT control of the initial setting,
REF is 960 or more. Check on a break in the ATR sensor, Replace the ATR sensor
XX50 When density data is computed using
SGNL value and REF value in ATR
control, REF becomes 0 due to backup
data corruption.
in the ATR sensor, Replace the ATR sensor,
Replace the DC controller PCB
XX51 When density data is computed using
control, the sensitivity coefficient
becomes 0 due to backup data
corruption.
XX81 P-SENS-P is less than 255 when a base
(drum face) of patch detection is read
out.
Clean the patch image reading sensor window
XX90 A computation result of patch reading in
patch detection is less than 16. Check on attachment of the developing unit, Replace the patch image reading sensor, Replace
the developing unit
XX91 A computation result of patch reading in
patch detection is 1008 or more. Check on toner leak from toner buffer in the developing unit, Replace the patch image reading
sensor
XX92 A computation result of patch reading in
patch detection is less than 42 for Y/M/
C and less than 73 for Bk 3 times in
succession.
the developing unit
X93 A computation result of patch reading in
patch detection is 522 or more for Y/M/
C and 543 or more for Bk 3 times in
succession.
sensor
XXA0 In ATR control, SGNL is less than 62. Clean the ATR sensor window, Check on
XXA1 In ATR control, REF is less than 62. Check on a break in the ATR sensor, Replace the
ATR sensor
XXA2 In ATR control, SGNL is 960 or more. Check on a break in the ATR sensor, Check on
XXA3 In ATR control, REF is 960 or more. Check on a break in the ATR sensor, Replace the
ATR sensor
XXA8 In ATR control, the detected T/D ratio is
upper than its upper limit (13%) 10
times in succession.
developing unit, Replace the ATR sensor
XXA9 In ATR control, the detected T/D ratio is
lower than its lower limit (3%) 3 times
in succession.
and,
E070 ITB HP detection error
0001 HP of the ITB fails to be detected even
after the specific period of time.
Abnormality of the HP sensor,
Deviation of the belt from its position to
either edge, or soiling of the seal
Clean the HP detection seal, Clean/Replace the HP
sensor
...so, I pressume that something is broken, because you are getting these two error codes... call service, or write on emma.servis@gmail.com for service manual.
Hope that helps!
Aug 10, 2010 | Canon Office Equipment & Supplies
Plesae describe the error code E00020
E020 There is a fault associated with the drum/developer.
For the first 2 digits of detail code xx12 through xxD0,
xx=01: Y
xx=02: M
xx=03: C
xx=04: Bk
xx20
xx24
xx25
xx30
xx34
xx35
xx40
xx50
The fault can occur as when a new drum
unit has been fitted. It is detected in about
90 to 120 sec after idle rotation of the developing
assembly.
unit has been fitted. It is detected during
ATR control or in about 150 sec after idle
rotation of the developing assembly.
assembly.
unit has been fitted. It is detached during
assembly.
The fault occurs when an image is being
formed. It is detected when toner supply
operation is started.
There is a fault/open circuit in
the ATR sensor. The drum unit
is not fitted normally, or is
faulty.
the SALT sensor.
the SALT sensor.
The ITB has deteriorated.
the ATR sensor. The setting of
the ATR sensor computation
value is wrong. The drum unit is
not fitted properly, or is faulty.
The sample image fails to be
drawn in ATR control. There is
a fault/open circuit in the SALT
sensor. The drum unit is faulty.
the SALT sensor.
The ATR sensor communication
value is faulty. There is a fault/
open circuit in the ATR sensor.
The drum unit has been fitted
improperly. (The machine cannot
detect the drum unit). The
The developer concentration
computation value is faulty (set
when a new drum unit is fitted).
xx60
xx70
xx80
xx81
xxA0
xxB0
xxC0
xxD0
target value is faulty (set when a
new drum is fitted; the value is
extremely small).
new drum unit is fitted; the
value is extremely small).
The actual value is considerably
high in relation to the ITB surface
reflectance when a new
drum unit is fitted. The SALT
sensor is faulty.
drum is fitted.
The measured value of the developer
concentration is considerably
low. The ATR sensor is
faulty. The SALT sensor is
faulty. The ITB is soiled.
The drum unit is approaching
the end of its life and is causing
the T/D ratio to drop. The ATR
sensor has an open circuit.
The supply of toner for the toner
container to the developing assembly
is faulty. The developing
assembly is supplied with toner
excessively. The ATR sensor has
an open circuit.
has failed. The toner
cartridge motor fails to rotate.
The toner container is empty.
The toner supply mouth of the
drum unit is damaged. The ATR
code xxEE,
xx=00: fault in access to drum
unit
xx=01: fault in access to toner
container
The fault occurs while ATR control is being
executed.
executed.
formed.
formed and, in addition, when the T/D ratio
drops while 20 prints are being made
continuously. It is detected when toner
supply operation is started.
Aug 04, 2010 | Canon imageRUNNER C3200 Copier
Canon3100 with code e000020-01a9 and -02a9 and -03a9, turned off. checked drum, fuser seems ok help
data corruption.
corruption.
out.
the developing unit
sensor
succession.
the developing unit
XX93 A computation result of patch reading in
succession.
sensor
ATR sensor
ATR sensor
in succession.
BUT FIRST: Check the ATR SENSOR, left from the developing rotor you have an "rail" with atr sensor - vacume it!!!!! Vacum all dev units, and copier
Apr 20, 2010 | Canon imageRUNNER C3200 Copier
E020 sub code 0481
ATR Error (E020-XXXX) Display due to Dirt on ATR Sensor Window
Cause
The waste toner may adhere on the ATR sensor window or the sensor shutter. As a result of that, it may be faultily detected as ATR sensor fault and trigger the ATR sensor error (E020-XXXX).
The detail codes (xxxx) are as follow: XXA0, XXA2, XXA8, XXA9, XXC0, XX10, XX11, XXDA.
Filed Measure
Clean the ATR sensor window and the ATR sensor shutter with the following procedure. 1) Remove the ATR sensor from the main body. 2) Press the plunger [1] of the ATR sensor lever solenoid in the direction of the arrow. 3) Clean the ATR sensor window [2] and the ATR sensor shutter [3] with lint-free paper [4].
Pls rate thanks!!!!!!!!! dont forget testimonial mate.
Oct 17, 2009 | Canon CLC 1150 Color Copier
Worlds 4 and 7
for world 4and7 you have to be mini on world 2 then defet the boss on that like mini and there is world 4 on the map (do the same on world 5 for 7)
Jul 29, 2008 | Nintendo New Super Mario Bros. for DS
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
