Question about Electronics - Others
3kw LFPSW DC12v or 24v/AC220V: - Electronics - Others
Westerbeke 3kva generator cuts out when kettle boils
Depends on the Generator size. It may well be that it has a suggested 3kva max output. Generally a little overrated. Your 3Kw kettle might be over 3Kw input.
These things mean the generator safety cutout operates just below 3Kva. The generator would be fine with a short time 3KVA output only. better for it to cut out than the cook!
Trick would be to have a 2kw kettle or a 4kva genny
Nov 24, 2014 | Kitchen Appliances - Others
My generator ET900 is starting normally but it does not get AC220V output. I don't no where is the problem someone can help me for this problem.
fuse or broken wire or its not generating power and suggest get electrical generator engineer in to diagnose and tell you where problem is and save hours messing about !
Feb 18, 2014 | Boating
I am going to install my new mytag oven MEW7530WDS01, can you tell me the Amp. protection required for this oven? it is a 220V
If it is just a single oven then a 13amp fuse is all that is required for the oven.
If you are unsure, then check the rating plate.
If the total amperage does not exceed 3kw, then it is safe to use it with a 13amp fuse., Anymore than 3kw, then it should be hard wired, with a minimum 30 amp fuse for protection.
Feb 12, 2011 | Maytag MEW7530WDS Stainless Steel Electric...
We have analog tv and freeview box but arial is in loft. signal strength is 70 percent and is good most of time.have found bad breakup when running 3kw shower and 3kw kettle, no other apliances interfere,...
The problem with inside aerilas is the signal strength of 70% contains noise as well. You could try using a higher gain aerial and the interference will be limited with a better signal.
Any electrical items can interfere with a poor signal.
Dec 30, 2010 | Televison & Video
Under AC 110V condition, everything looks fine pretty well, but it is not worked completly under AC220V condition. What's problem??
I give 240 supply and set smps switch setting was 115, so transistor was blast, so trasistor no was erase, so plz send me trasistor no.
Nov 29, 2010 | Enhance Technology (ATX1140H) 400-Watt...
Does the bush AE6BFS single fan oven require hardwiring or can it plug into normal socket
Generally speaking, a single oven can be used from a normal 13 amp socket.
If you are not sure, check the power used by the oven on the rating plate, as long as it does not exceed 3kw, then itt is o/k to use from socket.
If more than 3kw, then it will need to be hard wired.
Oct 25, 2010 | General Ovens
Zanussi ZJD 125 on a timer switch
No prob, the washer never draws the full 3kw at any one time.
Plz rate this solution.
thanks.
Dec 18, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Electronics - Others Logo
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
