Question about LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
Dvd drive does not open
It seems that something has stuck in combo-drive, as when it doesnot have any CD/dvd, then huge numbers of tries are needed to open it, how to make it easily openable
  • mashish Nov 05, 2007
    but mine combo drive is not too old as it is just about year & half old.. and it is not used much??
  • Venugopal R Dec 05, 2007
    DVD Rom is not opening
  • 1,463 Answers
Usally there a pin hole on the cd-dvd driver put a pin in that and it should open ok.
or time to trade in for a new one .)
Posted on Nov 04, 2007
My SONY CD-RW CRX320EE reads CDs but it doesnot read dvds correctly and it doest write on Cd when i want to make cd ,it makes it but the cd doesnot open. the dvds donot open but somtimes open. please help...
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jan 07, 2011 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
It is unable to read DVD
try clening the lens..if it doesnot work, upgrade the firmware of the drive
Jun 18, 2010 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
This drive reads a dvd but not cds. do you have
may be it's only a DVD ROM drive not a combo,
you will need a combo to read both DVD and CD
if it was reading CDs earlier then the CDs might have scratch in them, try with new CD.
did u make changes to the cables inside, if you did check if the cabels are connected properly to the drive
Dec 06, 2009 | Sony DDU1613 16X DVD-ROM Drive, Black...
if your dvd drive is stuck in your ole computer!!! you need to give more info on what type of computer you have? is it a dell compaq "what"?... if you are trying to get a DVD out of your dvd drive then thats easy, in the front you will see a very small pin hole. push a pin into it and you will open the drives draw.
Aug 17, 2009 | Memorex (32023244) CD-RW/DVD-ROM Combo...
Acer 4520 cd/dvd driver problem
Try to use another DVD. you told you tried you old DVD from your toshiba. maybe is not compatible.. try in another.. then use your DVD in another laptop if the same from problem.check your board and DVD connection...if this under warranty bring to warranty..
if in Bios also can not detect this is hardware problem...
May 28, 2009 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
My lg dvd rom play cd doesnot play dvd
Dec 28, 2008 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
Combo drive not reading DVD
my combo drive also not reading dvd :(
Dec 23, 2007 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
My dvd combo does not read dvd
There are separate lasers for CD reading, and for DVD reading. This is why it is possible to have a drive that reads only CDs but not DVDs, or the other way around. And your particular combo unit seems to have a lot of these problems. Since the drive doesn't work it's almost definitely a problem with the drive itself (I'm assuming that there is nothing wrong with the discs you tried to read). If that drive is still covered by a warranty period, send it back for repairs. Otherwise, I can't see the harm in trying to tinker with it yourself as the DVD portion of it is dead anyways. Ummm, on a side note...CompUSA is going out of business and they are selling things cheap. I got a DVD lightscribe burner for $40...booyah!
Mar 26, 2007 | LG (GCC-4522BI) CD-RW/DVD-ROM (Combo)...
Not reading DVD
It's common problem with combo drives in notebooks, they don't seem to last long. Try this:- Go to my computer>properties>hardware>device manager and look down the list for your cd/dvd drives and click the '+' sign then highlight your dvd drive and right click to delete. Restart the pc and windows will find the drive again automatically and install the drivers. If the problem persists the laser is faulty in the drive and the drive will need to be replaced.
Mar 07, 2007 | Sony CRX830E CD-RW/DVD-ROM (Combo) Burner
LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive Logo
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
