My thomson freeview recorder has stopped giving me the option to record the series
  • 88 Answers
Try going into main menu and settings then try to find factory reset .reset all . You may ahave to reload channels afterwards to do this go back to settings then installation then find the button to replace channels .let me know if you are successful . My email is michaeljamescolegate@gmail.com . Yours faithfully Mike Colegate
Posted on Jun 20, 2014
SOURCE: CNNECTING DMREZ27EB FREEVIEWDVD RECORDER, TO MY TV 2 SCARTS, AND MY PANASONIC VCR VIDEO RECORDER
I CONNECTED SCART TO TV 1 TO DVD FREEVIEW SCART 1, THEN I VCR SCART IN/OUT TODVD FREEVIEW RECORDER SCART 2, THEN RF CABLE FROM FREEVIEW RECORDER OUT TO VCR RF IN ,VCR RF CABLE OUT TO TV RF IN. RF SLOT IN ON FREEVIEW LEFT EMPTY THEN CHANGED TV TO AV 2 WHEN USING TO RECORD /PLAY EITHER VCR OR/ FREEVIEW DVD . I DO HOPE THIS HELPS SOMEONE. IT TOOK ME A WHILE TO SORT OUT REGARDS R. ELLIOTT.
Posted on Feb 23, 2008
SOURCE: Thomson DT16300 TV Recorder Continually Freezes
Just got off the phone to TopUp TV and they knew how to sort this out.
Follow these steps
1. Turn on unit and press menu
2. choose set-up
3. then choose Help
4. On the help screen type the number 1397 on your remote - This will take you to an Engineer set-up screen.
5. Scroll down to option 7 (disable library video window) and toggle this option to "YES"
navigate back to your programs and delete the recording that was giving you the problem.
Posted on Dec 31, 2008
  • 212 Answers
SOURCE: My thomson DTI6300 digital TV recorder shows that
If you have no recordings and it's playing up, I'd do a complete reset as follows;
Restore Factory Defaults
This will restore all the factory settings and erase the contents of the box.
Menu>Set-up>Help>Green>Red
Format HDD
This will re-partition and re-format the hard drive.
Menu>Set-up>Help>Green>Blue
This will wipe everything you have recorded. It will also dump your 14 day Electronic Program Guide which will take upto a day to reload. Leave the unit on standby.
You might want to take this opporunity to do a channel scan as well.
Posted on Jan 22, 2010
  • 7 Answers
SOURCE: Thomson dti6300-16 won't record freeview channels....
maybe a defragged hard drive follow this procedure:
1. Select Menu, Set-Up, Help.
2. Press the Green button on the remote control.
3. This shows the Advanced Information screen.
4. Now press the Blue button which will prompt you with a warning box.
5. Now press the Green button if you wish to proceed.
6. The DTR will take around a minute to complete the reformat, and will then automatically restart itself.
Next do a channel rescan.
Posted on Feb 15, 2010
SOURCE: I have a Thomson DTI6300-16 freeview box. I'm
This could solve problem
Posted on May 06, 2010
Do a recording on my thomson dv3 digital terestrial recorder
The Thomson DV3 is now called Top Up TV. The manuals for the product are here: http://www.topuptv.co.uk/help+centre/downloads
This site also gives the codes to make the Top Up TV box control your TV volume. Hope this helps.
Sep 16, 2014 | Televison & Video
I have a Thomson digital recorder which will not now give me the choice to record the series
it could be that the hard drive has failed, if it will also not give you playback of previous recorded tv, then its probably failed,
there is a good chance you can just replace the harddrive and should not be any more difficult than doing it in a pc,
most will just fit in and out, and when power back on will ask you too format media / harddrive
but always do it with the power off
Nov 24, 2013 | Tivo Series2 TCD649080 Video Recorder
Thomson freeview dv3 recorder
Buy one universal remote control, which have setup codes for your Thomsun device. Brand name isn't matter.
May 06, 2012 | Thomson Internal Push Ring,id 2.000 In -...
After recording a programme last night on my thomson freeview box a flashing orange light came on. i have tried switching it off at the plug, but the flashing light is still there
Hi, a common problem with the thomson freeview boxes is capacitors leaking in the power supply, The ones that go usually are the two 1000uf capacitors. If any of the capacitors look deformed, ie the tops look domed in any way. I would change them , Handy if you know how to use a soldering iron. If you can use a soldering iron remember to put the new capacitor in the same way ( the wires are marked so you must put them in the same way round).
pete
Nov 27, 2010 | Thomson Televison & Video
Thomson dti6300-16
You can still record all the freeview channels. What has happened is you've run out of room on your hard drive. First you must deselect all the top up channels;
menu > 'Setup' > 'Customise TUTV', and un-ticking all boxes releases space and produces a report of '100%' free for recording. The time available for recording depends on the size of the hard drive and amount of data saved in each recording and 15% of disc space is not counted. This is for software or programme information etc. and, even when not subscribed, ads from TUTV are downloaded to library. However they are replaced or removed automatically, and messages are deleted after a week.
Also delete all the recordings in the library you don't need anymore.
Oct 02, 2009 | RCA Thomson Digital Cable Modem (DCM305R)
Oct 02, 2009 | Arris DCT2608
Thomson topupbox
hi i have sorted the problem i went on line of the make of the thomson freeview and their was other people with the same problem and they help me by reading their instrutions on their page now it is working .
May 04, 2009 | Thomson DTH8000 DVD Recorder
Mar 05, 2009 | Arris DCT2608
Thomson 80gb freeview recorder box (Top up tv model) UK
have you connected the small cable at the back?
Jun 04, 2008 | Televison & Video
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
Electro Med Services...
