Question about Dryers
How do I turn on without the remote control
My fan is not wired into the wall, it plugs into any socket. It would come on sometime when I turned the tv but I no longer have the tv. How can I make it turn on without the remote control. Can I bypass the remote control? Please help Its hot here in the desert. Thanks
  • Dryers Master
  • 3,904 Answers
If you have a switched outlet you can plug it into that and operate it with the wall switch. There are also many products like the "clapper" out there that work great as well.
Posted on Jun 05, 2014
  • Lester Chaves
    Lester Chaves Jun 05, 2014
    The fan is in the off mode, does the fan have to be on in order for the switch to work? Do you know a way to put the mode on the on posittion?
  • Lester Chaves
    I hope thats true, but remember my fans have no on or off switch, its all on the remote control that is lost. So if the machine is off by the remote how will it turn on? Its hard for one to think that a electric fan that runs only by the remote that there must be an on and off switch on the fan iitself but it has none thats why I wondered if I could somehow by pass the romote or trip the fan by switching some wires around. I know this all sounds really dumb about a fan but I paid a good price for them and they are pretty knew considering the remotes had been lost a short time after purchase by the movers.
SOURCE: Ceiling fan and lights with remote control
I got a new reciver installed in ceiling fixture,works fine:Boytin
Posted on Mar 25, 2008
SOURCE: Remote control ceiling fan
I am changing the remote in hunter fan an i got the wires mixed up coming from the fan what wire goes where?
Posted on Apr 12, 2008
SOURCE: Hampton Bay Classic Collection 52" remote ceiling light/fan
rechecked wiring, but blue with blue, white with white, etc., now lights work with remote,but fan only works with wall switch - so why doesn't fan work with remote,if lights work the remote & receiver must be ok?
Posted on Jun 04, 2008
SOURCE: hunter ceiling fan
The frguency on the fans can be changed to anothere by reseting thelittle switches located inside the remot and the reciever. Dave at DLDELUE@CFAITH.com
Posted on Jul 16, 2008
  • 37 Answers
SOURCE: How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Posted on Jan 27, 2009
Help. I need help properly connecting wires on a new ceiling fan.
Usually, the fans with remotes will dim the lights by holding the light button for a few seconds. So, the red wire would stop this feature if wired directly to the fixture. That would eliminate the wire coming out of the receiver for the lights. If you want the light to dim, then tape off the red wire, so the remote will dim them. The wall switch won't work anymore. If you want to connect the red wire , tape off the wire from the receiver that connects to the light sockets and connect the red wire to the wire for the light sockets. This will operate the fan but the remote will not dim the lights. If you have a motor speed controller in the wall from the old fan, remove it and replace it with a switch or eliminate the switch altogether so the remote will control the fan speed.
Nov 13, 2016 | Dryers
Magic fan
u need to show a good technision of electronic
Jul 19, 2008 | Hunter 21617 Palermo Brushed Nickel...
If it came with the remote & there are no pull chains on the fan, then you probably can only use the remote. Probably needs a new receiver. What make/model of fan is it?
May 18, 2014 | Dryers
Casablanca Isatope 52 inch fan not working
The combination of wall switch control and remote control tends to throw the unit into a tizzy. Try disconnecting power at the source and starting all over again. You may have to abandon wall switch control and rely solely on the remote.
Apr 02, 2017 | Casablanca Fan Televison & Video
Turn on without remote control
If the TV was switched OFF by remote control for the last time, you can't switch it back ON, without its remote control.
Just try this. Unplug the TV from AC mains wall socket. Wait for at least 5 minutes and plug it back. Switch it ON by its front panel power ON/OFF switch. Just press any button [Ch UP / Ch DN or Vol UP / Vol DN] Sometimes this might turn ON your TV.
Jun 02, 2012 | Televison & Video
Fan will not turn under it's own power, but turns freely by hand. Light bulbs light up very dimly. Light sockets show 120volts when the switch is turned on if all light bulbs are removed, but if a...
You probably have a wire nut connection that is just barely connected. Perhaps it's a connection between stranded wire and solid wire where only one of the strands is making contact with the solid wire.
Jan 09, 2011 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
The remote controls the fan speed but wont dim or control the light. the unit wont work if the light switch is off so I cant use the fan at all unless the light is turned on
mcdevito75 here, Generally the Ceiling fan motor is hooked up by-passing the wall switch but still to the hot laed going to the wall switch whlie the lights are hooked up to the hot lead after the wall switch, So without the remote, Manually operate your fan and lights. First with the wall switch off the fan should work and the lights no work. Now turn the fan off with the pull chain on the fan shroud close to the ceiling. Now turn wall switch on and lights should work with wall switch and the fan should also work. if so, re-program the remote or change the batteries or even re--place the remote.
Jul 26, 2010 | Hunter Ceiling Fan Light Remote Control
Wall remote that controls ceiling fan & lights not working
Either the bulb is blown or the connection under the wire nut is loose. First check the bulb then turn off the power at the panel and check each wire nut by unscrewing it and making sure that the wires are tightly twisted together before reinstalling the wire nut.
Mar 26, 2009 | Hunter 27187 Remote Control
Wireless ceiling fan
there are remote controlled fan out on the market.
there are also devices the make it remote, but the cord is for power so i dont think you can hide the wires to much without going thru the ceiling.
if you have no access of the cieling then the wire must be there for powering of the fan run along the wall, try stapling the wire to the cieling like around the egdes of the ceiling then perhap painting the wire the same color of the ceiling.
you do not have much option to work with.
you have to make sure you buy the right remote controll
but it still need power.
http://www.csnceilingfans.com/Ceiling-Fan-Remote-Controls-C14870.html
there a site for remote controls for fan or just buy a new fan all together. im sure they put the plug there for a reason because if you use the fan alot they do go bad.
Good luck
Aug 16, 2008 | Dryers
Hunter ceiling fan w/ remote won't work
You need to change the receiver inside the fan. It is located in the top canopy of the fan. you don't have to buy a new remote just the receiver to save money and match the dip switches to the remote.
Nov 13, 2007 | Dryers
Dryers Logo
129 people viewed this question
Top Dryers Experts
