Question about Hampton Bay Dryers
Trying to take down ceiling fan #175-652. blades off. can't find any more screws to remove pendant cover at ceiling
  • 38 Answers
SOURCE: I need to remove my hampton bay ceiling fan from the ceiling.
On some fans the part that goes against the cieling to cover the box can be turned and then will drop down on the stem to give you access to the wiring and mounting. There is usually a seperate wire for a light kit that has a wire nut on it and is not connected from the factory.
Posted on Jan 15, 2008
  • 139 Answers
SOURCE: hampton fan
You are probably missing a part. There should be a mounting plate...usually round...that attaches to the ceiling or electrical box. The mounting plate would have small tabs or a lip around the edge with threaded holes for attaching the cover.
Posted on Jan 16, 2008
Crossedwires
  • 44 Answers
SOURCE: blade problem
The Hunter web site should have them. If not I have found simular ones at Radio Shack and also have ordered them from parts suppliers like Mouser, Digi-key, Allied electronics Mat electronics. All of which can be found and ordered from online.
Posted on Feb 09, 2008
MrARCADIAN
  • 284 Answers
SOURCE: Fan not blowing air.
theres a small toggle switch on the fan
that switch is to change direction on the way the fan is blowing
one direction for downward blowing
the other direction is for upward blowing
depends on the area you have to determine which is the best, but i doubt area restriction will hamper force air blowing, air will flow regardless, the area might be big so you dont feel it.
as being living in the attic, HOT AIR rises, so you might want to invest in some installation for the ceiling, because whent he sun hit the roof, it will create an oven effect, in your living area. the hot air is always present, you should have a ventilation fan blowing the hot air out, like thru a small window, the more hot air you blow out, the better.
not sure if this make sense. not sure how big the room is, as FANs are NOISY by nature.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Posted on Aug 16, 2008
DId you check the capacitor, is that ok?
Brgds,
Amit
www.avpower.wordpress.com
Posted on Apr 04, 2009
How do I uninstall a ceiling fan?
Turn the power off, to be safe i recommend turning it off at the breaker box, there should be a list on the onside of the panel door showing what switches operate what. or you can simply leave the wall switch that operates the fan in the off position if you're sure nobody will turn it on. If fan has a light remove the glass bowl over the bulbs, should be three screws it the top of the glass fixture, loosen them with your fingers, if they are to tighttry pushing up on the bowl from the bottom to relieve pressure off the finger screw. Remove light bulbs then unbolt each fan blade, once the blades are off remove the motor cover should be one small screw at top of the cover close to the ceiling, once the screw or screws are removed if the cover does not come down you may need toturn it using both hands, it only needs to turn a little bit and no need to be gentle. With the motor cover off the mounting bracket should be easy to spot. Some brackets only have one srcew on one end and a tad that slides into a slot on the upper bracket, by removing the one screw this will allow the motor assembly to swing down but still be attached to the bracket for support. Whith the motor hanging the wiring in the fixture box in the ceiling should be visible, pull the wires out of the box so ythat the wire nuts are accessible. there will bee three wires coming from the fan, one screwed directly to the box or bracket, loosen the screw with a screwdriver and pull the wire from the box, the other two wires attached to wires with wire nuts, one at a time remove the nuts by twisting them off with your fingers, pull the wires apart and twist the wire nut back onto the wires coming from the box in the ceiling, the fan should now be disconnected. romove the motor from the brack by turning it 90? and sliding the tab out of the slot in the upper bracket. remove the upper bracket piece from the fixture box. Now that you have done this installing a new light fixture should bea breeze for you.
the video shows a different easier type of fan removal. There are numerous types of fans and how they are mounted, i hope this helps you
Apr 09, 2014 | Dryers
How do you remove a canopy cover from a Hampton Bay fan?
Turn off the circuit breaker supplying power to the ceiling fan. The circuit breaker is in your home electrical box and may control more than just the ceiling fan. Place a stepladder under the Hampton Bay fan.
Remove the light bulbs and light covers from the fixture, if you have a light assembly on your ceiling fan. Remove the screws securing the light assembly housing to the fan with a Phillips screwdriver. Lower the light assembly, and hold it in one hand.
Twist counterclockwise the wire nuts securing the wires for the ceiling fan and light assembly, using your free hand to separate the wires. Lower the light assembly from the fan and set it in a safe place.
Turn the screws securing the fan blades to the unit with a Phillips screwdriver. Remove the blades from the fan and set them aside. Find the screws securing the canopy to the ceiling mounting plate. Loosen the screws two complete revolutions. Turn the canopy counterclockwise and unhook it from the screws. Slide the canopy over the fan motor housing and away from the fan.
Ask a helper to hold the fan motor housing if you have a Hampton Bay fan with a down rod. Slide the canopy over the down rod until it rests on top of the motor housing. Disconnect the fan wires from the ceiling wires, twisting the plastic wire caps counterclockwise. Slide the hangar ball, at the top of the down rod, out of the mounting bracket. Slide the canopy over the top of the down rod to remove it from the fan.
Regards
Sep 28, 2011 | Dryers
REMOVAL FROM CEILING
In general, the steps are:
1. Turn off power at the breaker -- not just the light switch.
(There are still "hot" wires in the junction box when "Off".)
2. Take out any light bulbs.
3. Remove any light globes. Some screw in, but most are held by springs so just pull gently with a bit of force.
4. Remove fan blades. Most have a spring at the inside edge of the blade -- press down on the spring and push the blade toward the fan motor.
5. Remove the ceiling mount cover. There is usually a circular ring up next to the ceiling; just twist it off with your hands ("lefty - loosy, righty-tighty").
6. Unscrew the ceiling mount screws. Usually there is one or two in a "simple" hole, and two one "sliding" slots. Take out the "simple" screws, and loosen (but don't remove) the "sliding" screws. Be careful not to drop screws or washers into the fan motor.
7. Twist off the ceiling mount cover to expose the wiring.
8. Disconnect all wires. For safety, put a wire nut on the wires from the ceiling.
9. Tip the fan and remove it from the ceiling mount. Keep in mind that the fan is pretty heavy, and you're on a ladder!
NOTE: Be careful not to put any pressure on any of the blade holders, especially if you intend to re-use the fan. If you do, the blades will wobble.
10. If you're installing a new fan, you can probably re-use the mount. If you want to put up a simple light fixture, remove the mount by unscrewing the two long screws holding it to the junction box.
Jul 17, 2010 | Hampton Bay AC414-LRU 52'' Kemper...
How do I get my hampton bay antigua fan down from the ceiling
first you will need a ladder and a screwdriver/phillips a couple wire nuts or electrical tape.at the "top" of the fan you will see a bowl shaped cover it will have usually no more than two screws in it..loosen or remove those screws to access the fan hanger inside.once you get that far inside you will see several wires .undo each wire seperatly and cover with a wire nut or electrical tape(please make sure your power is off to that circuit) once you have unhooked all the wires from the fan and secured them out of the way. lift the fan out of the hanger itself (sometimes it is easier to remove each blade from the motor housing before removing the fan from its hanger ) those screws can be found at the base of each blade on the motor housing..If you are moving or adding a cieling light be sure to remove both parts of the fan hanger..the second part will still be attached to the cieling..usually two screws holding it into place..if just replaacing the fan,,you can sometimes leave the second part there and hang the new fan with it..
Jul 30, 2009 | Hampton Bay 73554 Antigua Ceiling Fan
We have a hampton bay fan and can not get it off the ceiling how do you remove it?
I have no experience with ceiling fans and for me removing the housing didn't get me anywhere. For our fan (Model 23758) there was a nearly invisible ring of material at the base of the fan where it meets the ceiling. This was in place for apparently aesthetic purposes as it hid the screws that secured it to the ceiling bracket. By rotating this ring and pulling down, we were able to to remove it.
Jun 30, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Screws that hold the fan blade don't tighten up to the blades
replace your blades and washers and screws with a new ones.
Apr 07, 2009 | Hampton Bay 24002 Ceiling Fan
Dont know how to remove blades
look as far up as you ca... it may be one of those fans that the whole thing is attached to each other... my dad had to take the whole thing down one time in order to unscrew them
Apr 02, 2009 | Hunter 23852 Classic Original Ceiling Fan
Removing ceiling fan blades
Wait? Why would you want to remove the blade? Are they broken? Is the fan unbalanced? Try cleaning the blade. If the fan still wobbles, try tightening the screws. If the fan still wobbles, Unscrew the blade and unconnect the blade from blade iron. Buy the new blade iron. If the blade is broken, Also buy the new blade.
Jun 13, 2008 | Angelo Brothers Westinghouse (r) Savona ES...
Ceiling fan
If the fan blade mounts are removable, go to your local hardware store with one of the mounts, and find some screws that will fit. You might not be able to get the same color, but if you check a few stores you should find something with the right shape of head to fit snugly.
Apr 17, 2008 | Hampton Bay (261025) Dual Mount Ceiling...
im trying to install light to ceiling fan but the wires are a different color and light wont come on
Jan 15, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Dryers Logo
162 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
