Question about Black & Decker Scroll Jig Saw Blade
How do you release the blade on a Pendulum pjs550 jig saw so it can be replaced
5 Suggested Answers
brewerstool
  • 141 Answers
SOURCE: jig saw model 7580 type 4, replacement for blade clamp
There is no model 7580 Jigsaw. The only model close to that I can see would be the 7588 Type 4. Unfortunately that part is unavailable for this model. You may want to contact your local Dewalt service center and see if there is a substitute for that part.
Posted on Sep 12, 2009
rowdy45176
  • 2176 Answers
SOURCE: How do I change the blade on a Black & Decker
Go to Dewaltservicenet.com and type in your model number and you can download the instruction manual for this tool with detailed instructions on how to change the blade. It is 8 pages long.
Posted on Oct 10, 2009
  • 26 Answers
on most newer jigsaws there should be a collar that you just slide back to remove old blade and insert new one
Posted on Oct 08, 2010
puertobori
  • 7733 Answers
SOURCE: unable to purchase blades for model 7588D b&d
go to eReplacementParts.com : Power Tool Parts and Tool Repair
Posted on Nov 02, 2010
How do you change a jig saw blade
At the front, above the blade, is a finger slot. Insert finger and pull forward. Blade will be released. Insert new T blade and release finger.
Apr 24, 2016 | Dewalt Saws
Makita4350 collet out of line and cant install new blade
Makita 4350FCT Top Handle LED Light Jig Saw Parts
The best is to replace position 20 complete sometimes with the collisse position 36 also position 6,7,8 11 and 12
Feb 16, 2016 | Makita 4350FCT Top Handle Jigsaw with LED...
How do I release the blade on a Pendulum pjs550 jig saw so I can replace it?
Hi Helen,
Push the reciprocating head protecting your hand with a glove if necessary. All the way to a center point just above the shoe or table of the tool. Then loosen the two fasteners that bind the blade keep horizontally from the spool head. An Allen head is a six sided wrench. Where a Torque style is a star style. Either equivalent in a T-handled wrench works best. On to removal.
Support the spool head from shifting around with one hand whilst torqueing the fastener counter clockwise to remove or loosen it to free the blade. Should the blade be seized or jammed in the well of the spool head. Use a pair of needle nose plyers to free the blade by vigorously shaking then pulling.
All of this should be done with the electrical plug removed from power to protect your safety. For me. Safety glasses should always be worn.
Performance Power Pendulum Jigsaw 550W PJS550 customer reviews product...
May all your projects be prosperous. Fare. Well.
May 18, 2014 | Black & Decker Scroll Jig Saw Blade
Jig saw b4300 blade replacement
This tool has no mechanism for the fixating ot the saw but only a short ***** part 53 its a fault in the manual , it simply replace the saw with a screwdriver. or simply the clamp ***** to release turn it loose and from the top you can replace the clamp *****
Bosch B4300 0601582535 Jig Saw Parts
Sep 05, 2013 | Bosch 1581AVSK Top Handle Jig Saw Kit
Bosch b4300 jigsaw blade replacement
To change the Bosch B4300 blade - If the grey knob does not turn to release the broken blade, you need to use a LONG THIN flathead screwdriver down the center hole at the top. Unscrew until the broken blade is loose. Pull out. Replace the new blade and then screw the it tight through the same hole at the top. DONE.
Jan 25, 2012 | Bosch 1581AVSK Top Handle Jig Saw Kit
How do i remove the blade on a black and decker U255S Jigsaw
either on the left or right side of the blade holder there will be a little lever to pull that will release the blade, pull on the blade at the same time you pull on this release
Jan 17, 2011 | Black & Decker Black Decker Orbital...
I have a milwaukee jig saw, 6268-21 that I cannot load blades.
Yes the Milwaukee 6268-21 does require the use of certain jigsaw blades. You have to use T-shank type blades. You push the tension lever hold it while putting the blade in as far as it will go, then you release the tension lever slowly and it will engage the blade. You should then check by pulling on the blade to make sure it is seated properly and will not come out.
Oct 20, 2009 | Milwaukee Tool Milwaukee Orbital Jig Saw...
My husband has a BLACK & DECKER JS515 VARIABLE SPEED JIG SAW WITH QUICK CLAMP 3.5 AMP which i accidently broke the blade on...i cant figure out how to change the blade..any help would be greatly...
Here is a link to the instruction manual, and just under the place where it says Save These Instructions it tells you how to change the blade.
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/90520882,JS515.pdf
Fitting the saw blade (figure A)
- Hold the saw blade (9) as shown, with teeth facing forward.
- Push the lever (3) downwards.
- Insert the shank of the saw blade into the blade holder (10) as far as it will go.
- Release the lever.
There is a little lever where the base of the blade fits into the holder that you depress to release the blade...You can see a picture of it in the manual.
I hope this answers your question...if so, please take a aec to rate this post...thanks.
Mar 23, 2009 | Black & Decker Single Speed Jig Saw
Cant change a blade on 500watt pendulum jigsaw fmtc500js
Hi
There is a click mechanism to replace the blade at the top of the blade.
best regards savumihai71
Jan 18, 2009 | Saws
Black & Decker Scroll Jig Saw Blade Logo
Top Black & Decker Saws Experts
Jason
Mike Carew
Are you a Black & Decker Saw Expert? Answer questions, earn points and help others
