Question about GE (PSS26MSRSS) Side by Side Refrigerator
How can I replace the control board on a liebherr cnesf 5013?
Where is it located?
Help! Our ice cubes are frozen but not dumping and our tray is filling up with water fitting a solid sheet of ice. Can anyone help? Thanks
Hello;
My name is Peter. I am a retired field refrigeration technician.
It sounds like your ice maker has a bad motor module/circuit board.
It is like a control board. This module reads a temperature sensor that indicates the water is frozen and ready for harvesting the ice cubes. Then it turns on a electric heater under the ice cube mold, then turns on the motor to harvest the ice cubes. After the ice cubes are harvested, it opens the water supply solenoid valve to fill the mold with water. The ice maker needs to be replaced.
Feb 27, 2016 | Liebherr Refrigerators
Where is the water filter for Liebherr CI1650 located?
There isn't a water filter. You should install an inline filter to the water line that comes in to feed the ice maker.
Jun 18, 2014 | Liebherr CI1650 30" Built-in...
Lights and pump turning on and off rapidly in succession
I had this, there are two circuit boards, one on the front under the switches the second in the back near the compressor. which is really hard to reach, your guessed it, its the one near the compressor that needs replacing, its around 70 pounds stirling..
Oct 19, 2013 | Liebherr KES4260 Refrigerator
I have two Liebherr Fridge Freezers. The first is a ICN 3056, it failed after 2 years with a loss of the refrigerant. The second ICN 3066 has now lost its refrigerant after 5 years service. Is this a...
Deston, I hate to be the one to break this to you but...the standard of quality and control over the board of appliances is no where it used to be or needs to be. Turning out a well build product one can be proud of has been replaced by pure profit motive. Having said that ANY refrigeration system that looses its coolant befor 8 to ten years has manufacturing / design problems. And I see this in all most all makes and modles.
Oct 13, 2013 | Liebherr Refrigerators
I have a Liebherr No-Frost Premium, with the freezer at the bottom of the unit three years old. I've had a number of problems with the box. The immediate pressing one is that the thermostat seems...
For that problem, the electronics control board and the thermostat must be check. Since the display doesn't follow the control button and it adjust itself automatically without controlling, it's already sure that the control is the problem. Check first thermostat then electronics control board. Be sure that the door are tightly close.
It is a pleasure to advice you.
Jul 09, 2011 | Liebherr SBSes 74S2 Premium NoFrost
Liebherr k 2724 4 years old. Light works, but neither the freezer or fridge sections are chilling. Has been this way for 24 hours. Wiring seems ok in back, and light switches off when door closes. Any...
All you to do is to check on the control knob, this could be faulty or loosen , do replace if found faulty . this is the common problem that a refrigerator do have and replacing the control knob solve the problem .
Good luck......
Aug 08, 2010 | Liebherr Refrigerators
Liebherr frige/freezer switching on/off by itself
its the main board relays on the board on the back panel or just inside the lower area on the left wall near the compressor compartment
Jul 30, 2010 | Refrigerators
Ice build up inside refrigerator Liebherr K3150
may be you have a bad temperature sensor or bad control board.
Mar 01, 2010 | Liebherr K3150 Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
35 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
