GE Â 230/208 Volt Built-In Room Air Heat/Cool Unit Air Conditioner
Problem for GE Â 230/208 Volt Built-In Room Air Heat/Cool Unit...
I have a 8 year
By littlechum on Jun 23, 2009
I have a 8 year old GE Cirulaire 230volt/ 2600 BTU Portable(window air conditioner). it's only used occasionally in rela hot summer days. It's installed in a wall and only accessable outside about 25 (3 stories) ft straight up. I've been using the Ac on and off for the past 3 days and all of the sudden today it just shuts off all by itself. I checked to seeif i had blown a circuit Breaker but no! Nothing at all works...no power what so ever. Now I waited about 20 minutes and tried it again an lo and behold it turned right on and worked fine for about another 6 -7 minutes and then shut itself down again. I've now repeated this 3 -4 times. It will turn on after I let it set for a while, but once it does go on I have to reset the temperature guide. I can't believe it Froze up...but what else could be the problem? I checked the filter and it's nice and clean. However getting the unit out of the wall or accessing it from the outside is a major undertaking. Got any ideas on the problem and how I might be able to fix it? **** Wray
Solution #1
posted on Sep 17, 2009
Not Rated)
fransverhees
Rank: Master
Rating: 65%, 2 votes
Suction pressure compressor is to low due to loss of refregerant.
You have to take it somewere for repair and recharge.
Was this helpful?
Yes
No
Popular Solutions for GE Â 230/208 Volt
Questions and Unsolved Problems for GE Â 230/208 Volt
Do you recommend GE Â 230/208 Volt Built-In Room Air Heat/Cool Unit Air Conditioner?
Answer
Answer
I have a Fault code on a Panasonic Air-conditioning unit, F15 and F41 on another one. They are R22... (More)
Answer
would like user anual for air conditioning unit AMA2067 and the remote control
Answer
to begin with , I am sorry for the lack of model number, I am trying to locate the schematics for an... (More)
Answer
miller propane furnace for mobile home,was working turned the power back on and the red light... (More)
Answer
remove 1998 ford f150 ignition lock and cylinder
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioners Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
