Question about Sewing Machines
Thread keeps winding around my bobbin holder. What could I be doing wrong?
    Novelist:
  • 268 Answers
Misthreading, most likely. Take all the thread off and out of the machine and clean the machine, especially around the feed dog and bobbin case areas. Rethread from scratch, remembering to thread the upper part of the machine with the presser foot up, and make sure the bobbin is sitting in the bobbin case right way around. Fetch up the bobbin thread and hold it and the top thread end together behind the presser foot while you take the first few stitches of the seam.
Posted on May 23, 2014
SOURCE: bobbin thread getting jammed
kyoungblood4
Are you making sure that your pressure foot is up when you thread the upper thread? If it isn't then your thread is not seating correctly in the tension disks. It will then be loose and make a birds nest(mess) under what you are trying to sew. The other thing to check is which way you are putting the bobbin into the bobbin case, different machines do it different ways. Some want the thread to come out of the case in the same direction as the slot on the case and some want it to come off in the opposite direction.
Guest,
Probably when your son broke the needle he knocked it out of time. You will need to have a sewing machine technician to repair that.
Hope this has been helpful for you bothl Liz M
Posted on Aug 08, 2008
SewTechWayne
  • 186 Answers
SOURCE: problems winding bobbins on my singer 4622 sewing machine
I have two possible solutions:
1. you have the wrong bobbin and it doesn't grip the winder.
2. the small spring on the winder spindle is missing or bent, it is what applies pressure to the bobbin for winding.
good luck!
Posted on Jan 31, 2009
  • 6 Answers
SOURCE: Singer CG 550 Top thread keeps wraping around the bobbin and jam
Have you checked the top thread is correctly placed in the spring of the bobbin case?
Posted on Feb 21, 2009
  • 3 Answers
SOURCE: Bobbin is not winding correctly
slide plate may be worn - i had the same problem. try holding down the center of the bobbin with a pin while slide plate is in the winding position.
Posted on Mar 03, 2009
SOURCE: Singer 6267 self winding bobbin winds around shaft under
I just figured out why my bobbine was winding on shaft instead of on the bobbin. first of all make sure the bobbin is setting up high enough, top of bobbin needs to be a fraction higher then the bobbin shuttle, next check to make sure there are no burrs on the bobbin, then make sure that the thear is catching in the groove (**** in top) of the bobbin. In order to get mine to wind i had to lett the tread go down and then slip the thread in the groove. also remember to leave the pressure foot up do not put it down. let me know if this helps.
Posted on Mar 08, 2009
How do you wind the bobbin
Most bobbin winding procedures are very generic. There is a small peg on top of the machine and a lever to snap the peg against or the peg itself moves toward a stationery lever. Leave thread on machine like you would begin sewing but u thread the machine. There should be a thread holder of some kind on top to run thread through to hold tension. Wind thread a few times around bobbin and put bobbin on the peg on top of machine. Push lever toward bobbin peg or peg toward lever (whichever moves) and arrow by peg should show which direction thread will wind. Then push pedal and away you go...hope that helps.
Feb 11, 2015 | Sewing Machines
How to wind bobbin
1. LOOSEN THE HAND WHEEL. 2, PLACE BOBBIN ON BOBBIN WINDER AND PUSH TOWARDS INNER WHEEL TO LOCK. 3. RUN THREAD FROM THREAD HOLDER TO LITTLE METAL WHEEL ON LEFT OF MACHINE. 4.RUN THE THREAD AROUND THIS WHEEL AND TO THE BOBBIN. 5. ATTACH THE THREAD TO THE BOBBIN. 6. PUSH THE FOOT PEDAL.
7. WIND THE BOBBIN EVENLY AND STOP AT TWO THIRDS.
Nov 16, 2014 | Sewing Machines
Singer 6235 bobbin thread winds under bobbin
This happens to me when my bobbin isn't pushed down completely onto the bobbin holder. Also, it happens when I overfill the bobbin and the bobbin sensor doesn't stop the bobbin when it is full.
Oct 24, 2017 | Sewing Machines
Trying to wind the bobbin on my Pfaff hobby 1132. The thread keeps coming off the bobbin thread guide. The bobbin winds, but the thread is loose and uneven. I've pushed the bobbin holder to the right and...
Check to make sure the thread path from the spool to the bobbin is correct. The thread should make a loop around a little post that is actually a tensioner that helps the thread wind smoothly onto the bobbin. If something is wrong with that tensioner or the thread is not following the correct thread path, it could cause the thread to not wind smoothly. It appears that your machine has two locations where the spool can be placed to wind the bobbin. You might try using the other option, if one doesn't seem to be working.
Also, you might try slowing the machine down during the thread winding process. It it goes too fast the spool begins bouncing and pulls the thread akilter. Also, some threads will stretch if the winding is too fast causing the thread to "shrink" when sewing your garment and creating puckers.
FWIW, I found that a "SideWinder" stand-alone bobbin winder is a handy gadget. It is available for ~$30 from JoAnn's Fabrics, Amazon, etc and is battery or electric compatible. It saves wear and tear on a machine and can wind multiple bobbins one right after another. Just be sure to verify that your bobbins will work on the SideWinder as some Singer bobbins will not.
Nov 16, 2017 | Sewing Machines
How to fill a bobbin on Virtuosa 150
Put the thread spool on the vertical spool holder with a sponge pad underneath. Wind the thread off the spool and through the small wire thread guide next to the spool holder. Take the thread across the top of the sewing arm to the tension unit just next to the gap in the case through which the thread is normally threaded - the tension unit looks like the top of a shiny screw without the slots in it. Wind the thread in a clockwise direction around the tension unit once and pull the thread with a bit of tension until it slips into the sprung gap around the underside of the shiny part. Slip the end of the thread through one of the holes in the bobbin and, preferably, wind a few turns on, then push the bobbin onto the bobbin winder shaft at the right-hand end of the top of the machine. Turn the bobbin clockwise by hand a few more times to make sure the thread is 'locked' onto the bobbin and then just push the lever adjacent to the bobbin winder to the left. To wind the bobbin, you then press the foot controller and either stop when you've got enough thread on the bobbin or let it stop automatically when full. Make sure you dont go so fast that the spool rattles-around on the spool holder otherwise this could spoil the way the bobbin gets filled.
Sep 28, 2011 | Bernina Virtuosa 150
The bobbin thread keeps breaking! It is very loose and then snaps?? I've replaced the needle to make sure it was sharp, I bought the highest grade thread I could find, adjusted the tension... then...
Sounds more like the way the bobbin has been wound, is it loose and uneven or tight and smooth. Is it properly into the tension spring? being loose doesn't sound right, a thread under correct bobbin tension is usually pretty firm.
Is it loaded into the bobbin holder the right way ?
Also check the bobbin itself hasn't been damaged in some way, not worn/bent. It needs to turn smoothly in the bobbin holder so if one edge has been bent a little this will cause problems.
When winding bobbins, you must have tension on the thread so it winds smoothly with consistent tension on the thread. Most machines have a little tension disc on top or the thread goes through the regular tensioner in order to achieve this. But I always wind bobbins at about 3/4 speed and also add a little extra tension by holding my scissors handle on top of the thread spool so it doesnt bounce around. Also start winding with a little tail pulled through a hole on top of the bobbin and wind until this starting end is covered, then stop and snip off the tail. Then continue winding and watch the thread, giving it a nudge so that it fills evenly across the bobbin, not just all in the middle.
Think of it like the garden hose reel; if you wind it really fast the hose all goes into the middle of the reel, then jams up and you can't get the whole hose onto it. Same thing, wind smoothly and evenly across the whole depth of the bobbin so that the thread is smooth and even. Then when the thread feeds off it will be smooth evenly tensioned and should stitch out evenly.
There is some good trouble shooting information on this page too which might help you to work out what is causing this thread breakage.
http://sewing.about.com/od/sewingmachineindex/a/mtroubleshot.htm
Jul 17, 2011 | Necchi Sewing Machines
The tension on the bobbin is giving big loops and then breaking
This could be one of the following:
  • wrong bobbin for the machine
  • bobbin loaded the wrong way - must rotate anticlockwise when you pull the thread
  • thread not into the tension spring/device on the bobbin holder correctly
  • bobbin wound badly, uneven tension, loose or uneven across the bobbin
  • poor quality or old dry brittle thread could cause the breaking (but the loops is definitely tension issues).
This is a top loading bobbin machine machine and you can download a manual from
http://www.singerco.com/accessories/manuals.html
Here is the threading diagram from the manual.
tally_girl_21.jpg It is important to click the thread down into the tension spring on all top loading bobbin machines and then pull gently on the thread to check that it is under tension, you should feel firm resistance when you pull the thread. If not, then take it out, and try again.
Other thing to look at is how the bobbin is wound. It is necessary to wind a bobbin smoothly and with some tension on the spool as the thread comes off it. Best analogy is the garden hose reel. If you wind it up and don't control where the hose goes onto the reel it will all lump up in the middle, and you won't get all the hose onto it. And then when you go to pull the hose out, it will jam and be difficult to pull. Same with bobbin thread. You want a nice neat even fill across the whole width of the bobbin, not just the middle. To achieve this make sure you use the bobbin winder tension disc when winding. Also use the spool cap on top of the thread spool to stop it from bouncing around as it unwinds - the thread will then wind off around the spool cap and this keeps it running smoothly and not twisting and jerking. If you don't have a spool cap then put the curved handle of a pair of scissors on top of the thread spool to tension it while you wind the bobbin. Also watch the bobbin as it winds, give the thread a nudge with your finger to control the fill onto the bobbin so it winds top, bottom and middle of the bobbin evenly.
I would suggest the following:
clean out the race following the manual directions to remove the bobbin holder, clean in this area, replace it. Wind a fresh bobbin and then load it into the machine, following the manual instructions carefully. Also thread the top of the machine following the manual, put in a new sharp needle from the pack, turn the top tension dial to a medium number (often 5 if dial goes from zero to 10).
Now test sew again. Look at the seam, if you have loops on the bottom of the fabric, underside, then the top thread tension is too loose or not in the top tension discs fully. Generally you should not need to adjust the tension on the bobbin thread for these machines.
Apr 13, 2011 | Singer 5050 Mechanical Sewing Machine
Bobin jumps when sewing
Could be in around the wrong way, poorly wound or not under tension correctly. Or even the wrong bobbin for this machine.
I suggest that you check that the bobbin is correct, ie do you have several that came with the machine and are they all the same in shape and diameter? Consult the manual if you have one.
Nextly, wind a fresh bobbin taking the thread from the spool through the tensioner (if your machine has one on the top) and then onto the bobbin. Keep a little tension on the thread spool with the handle of your scissors to ensure that the bobbin winds smoothly and evenly. Use your finger tip to nudge the thread to fill all areas of the bobbin. You want a neat smooth wind so the thread will then flow smoothly off the bobbin when it is in the machine making stitches.
Now, load the bobbin into the bobbin holder or bobbin case as per your manual, ensuring the thread is correctly into the tension spring and bobbin is rotating the right way around.
Now thread up and test sew again.
Apr 09, 2011 | Brother Sewing Machines
Bobbin is clumping up
You haven't given a lot of details so I'll just assume this is a bobbin issue initially.
Take out the bobbin and rewind a fresh bobbin of thread paying attention to the following.
You want to keep a bit of tension on the thread spool as the thread winds off it - good way is by placing the round handle of a pair of sewing scissors onto the top of the spool. If you let it just bounce around it will affect the bobbin winding neatly and the thread won't then run off the bobbin smoothly as you sew.
Also visually watch the bobbin as it fills, and give the thread a nudge with your finger tip to ensure it fills top and bottom, not just in the middle.
Think of how you wind up the garden hose reel, if you let it all go in the middle, it jams up before the whole hose is wound onto the reel. But if you wind it carefully and move the hose around winding it evenly across the whole reel, it stays neat and doesn't all jam up. Same principle for bobbins; don't just run the thread through the little tension disc and press the pedal hard until it stops.
Also quality of the thread is important; cotton wrapped polyester is nice to sew with and has a bit of spring, strength and good sheen; not sure where you are. But the brands I look for are Sylko Supreme, Guttermann and Mettler threads; there are other good brands too. Don't use those cheap bags of 5 white or black thread in the bargain bin. Some threads you can actually see particles of dye coming off the thread around the spool holder as you sew. Darker colours do this more.
And keep your threads stored neatly in air tight containers away from light, insects or damp; textiles fade and break down under UV rays eventually.
Now rethread your machine and ensure that the bobbin has gone into the bobbin holder winding in the correct direction for your machine, and that the thread has clicked into the tension spring.
Hope this helps, a good source of general sewing machine info is www.sewing.about.com.
Mar 06, 2011 | Brother SE-270D Computerized Sewing...
Singer 750 how to rewind the bobbing?
1. Push in indent (illustration 1) on hand wheel disc. This will stop the needle from moving.
2. Place spool of thread on spool pin.
3. Slide spool pin holder/cap (illustration 2) firmly over rim of spool to prevent thread from tangling.
4. Lead thread passing it first through the lower slot of the thread guide. Next through the upper slot, leading the thread to the right and around (illustration 3).
5. Wind thread clockwise around front of bobbin winder tension disc (illustration 4).
7. Pass thread end, from inside, through small hole in rim of bobbin.
8. Holding thread end, step on speed controller to run machine until desired amount of thread is wound. (Winding stops automatically once bobbin is full.)
9. Cut thread; push bobbin to the left and remove it from bobbin winder pin.
10. Trim thread end from top of bobbin.
11. Press the bobbin winding indent on hand wheel to its original position. If necessary, turn hand wheel to engage needle movement.
Feb 09, 2009 | Sewing Machines
Sewing Machines Logo
66 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
