Question about Minolta Office Equipment & Supplies
Minolta di450 how i can solve this code c-0540
  • Minolta Master
  • 6,161 Answers
Sir/Mam Just Looked at the Minolta Service manual no such cade please re-advise.
Posted on Dec 27, 2014
    President:
  • Minolta Master
  • 1,447 Answers
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
Posted on Jul 17, 2014
  • 1602 Answers
SOURCE: Minolta DiAlta Di450 Error Code C-0072
I NEED THE ERROR NUMBER OR HOW MANY TIMES DOES THE BLINK WHEN YOU TURN ON THE COPIER.
MORE INFORMATION PLEASE ROD
Posted on Feb 13, 2009
jqsababa967
  • 145 Answers
SOURCE: Minolta Di450 has full toner but copy paper comes
try copying from the document feeder and of the glass,and make sure the exposure light comes on
if all ok check you transfer unit its. sits below the drum,when you open the fron door release the convayance lever and you can slide that transer corona out there are 2 thin wire make sure they are not broken ,
Posted on Jun 05, 2009
SOURCE: minolta dialta Di450 Error message C-143E
The Document Feeder has only 1 Malfunction code for any problem with it.
If opening and closing the front cover (while it is turned on) resets it and you can use the machine, dont worry about it.
The unit was prone to this false malfunction code.
If it returns very often, then get an engineer to have a look at it.
Posted on Jun 12, 2009
SOURCE: Minolta Di450 service code reset service code
di450 . what is the solution of this code 1326?
Posted on Jun 11, 2011
love_but_tru
  • 3 Answers
SOURCE: minolta di450 error code c0201
i knw the solution
open the minolta box which is located on the front of the machine then u will see the small box on the left hand with a nut open the net and when u done u will see a small button press that button and then close the box and minolta box and press exit on the console the code will will remove
Posted on Mar 03, 2012
Error Code c0045
Bop. Error Code c0045. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.officeimagingsystems.com/id169.html
Konica Minolta Di450 Error Codes
http://www.biz.konicaminolta.com/download/users-guide/c554e_c454e_c364e_c284e_c224e/en/contents/id16-_101076518.html
Aug 25, 2016 | Konica Minolta Minolta Di450 Di470 Di550...
Erace the c-of24 on di450
The code refers to a sensor that looks at the drum - it might be dirty or something else is going on check this Fixya-link: Minolta DI450 error code C0F24
Jan 17, 2015 | Konica Minolta Minolta Di450 Di470 Di550...
How to reset to factory default
Sir, reset what part like access code etc. Di450 series great machines rugged. Service mode Memory Clear?
Dec 19, 2014 | Konica Minolta Minolta Di450 Di470 Di550...
Minolta DI450 error code C-0920
1st paper draw lift motor is jammed or burn out or the control board is bad. Check for paper behind the draw, also remove any paper from left side of draw.
Dec 26, 2013 | Konica Minolta Minolta Di450 Di470 Di550...
In my machine when we switch on the machine the code c- 12c0 appear
The C-12C0 code is a hard disk drive failure. Try to remove the hard drive and see if that solves your problem. You wont be able to scan big documents, but it should do the trick. Otherwise you'll have to get a new HDD of the same size that's in there. A bigger one won't work.
Oct 19, 2013 | Konica Minolta Minolta Di450 Di470 Di550...
Repair carriage wire of di450 photo copier
What carriage wire?
Is 2 wire in the transfer/separator corona.Is cut change.
Jan 06, 2013 | Konica Minolta Minolta Di450 Di470 Di550...
I have a Dialta Di-620 copier with an error code C-0540
i have a problem di620 code error c0540 please solve this thanks alote
Aug 23, 2011 | Minolta DiALTA Di620 All-In-One Laser...
Minolta Di450 service code reset service code C1326
Jun 09, 2011 | Minolta DI-2010F Copier
196 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
