Question about Kitchen Ranges
Defy wiring to dhd 395 770 tc to electrical point and type of wire to use.
2 Suggested Answers
SparkyNZ
  • 43 Answers
SOURCE: wiring problem
If they only way to fit your cable is by using the terminal push on connector (which, frankly, i'm not 100% sure what that's describing) and you can easily get that from your hardware store then yes, as long as you can connect up your wires without difficult and without stray copper.
Red wire is live, but white may be live as well during one aspect of operation. Usually neutral is black or blue. If your cable has red white and blue color in it then your using a 3 phase cable. A single phase 3 core cable will have red/brown black/blue green/greenyellow.
Hope this helps. Let me know.
John
Posted on May 09, 2009
I need a wiring diagram for a Defy slimline 600 TW thermofan
Request the wiring diagram directly from Defy.
Oct 03, 2017 | Kitchen Ranges
3 plates stopped working and the 4th one does not switch off.
unplug the unit and gain access to the wiring connection for all 4 elements(plates). remove the wiring from the element that will not shut off. while making sure none of the unconnected wires do not touch any metal or another wire, and plug in power cord. if the 3 non-working elements get hot then replace the none working control knob
Apr 03, 2014 | Stoves Kitchen Ranges
Wiring diagram of defy hob dhd326
Hi.
Does anyone know how to wire a defy hob Model dhd 326 pls
Im sure the earth goes to the green
neutral to purple
Live ?
Dec 13, 2013 | Cars & Trucks
Wiring Diagram Defy 521 Electric Stove
NEED A WIRING DIAGRAM OF A DEFY 521 ELECTRICAL STOVE
Sep 29, 2012 | Kitchen Ranges
Pilot will light but can't get burners to fire. Replaced thermostat and even bypassedit at one point. Any ideas?
Most heaters have a Thermo Couple (TC)-- is that what you have?
One possibility is that the Thermo Couple is beginning to fail'
What is a Thermo Couple? (TC)
The Thermo Couple (TC) is a small Rod-shaped device with a couple wires coming out the bottom.
The TC actually generates a small electrical current from the heat of the Pilot.
This electrical current is sensed by the control board, or the Main Gas Valve.
As long as there is a pilot, it is safe for the Main gas valve to open, and admit the large amount of gas into the heating burner.
Now-- What helps this TC work the best?
It needs to be just at the edge of the pilot flame--- Not too much in the flame, or the resulting poor combustion of the pilot flame, results in soot forming on the TC-- which insulated the TC from sufficient heat.
Obviously the TC has to be clean (of soot) in order to receive enough heat, to generate the needed voltage to tell the valve that it is safe to open.
And age does deteriorate the TC-- some last a few years, but that is about the end of life for most.
Replacing requires getting down where the TC is, and with a screw driver (usually)-- loosening the bracket that holds the TC. Pay attention to where the wires are routed, and any polarity indicated on the old wires, and duplicate on the new one. Duplicate routing, and polarity, and position the new TC at the edge of the pilot flame.
Pilot flame is maintained by pushing some over ride button-- for a minute or two, until when you begin to release the button, you can feel that the voltage generated by the TC is now holding the pilot valve open, instead of your pressure on the 'start' button.
Any further Questions, let us know..
Mack B
Jan 25, 2011 | Heating & Cooling
100 watt dhd amp wont turn on
If it's an aftermarket stereo, there's a small blue wire (accessory/antenna) that goes to the amp. So in essence, you have the large cable going to the battery that powers the amp. However, the small power wire going into the amp tells it when to turn on, by the stereo.
Mar 09, 2010 | DHD NTX-2004 Car Audio Amplifier
Help installing DHD 2114 amp to Impala 03 factory radio
What car are you looking for the wiring diagram for?
A simple line level converter would convert an input signal to a factory speaker - into a useable Low Level RCA signal for your amplifier.
033d2e7.jpg There is your signal - now all you'll need from behind the radio is the 12V Remote signal.
Send me your make/model/year, and i will tell you which wire to use.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 14, 2009 | DHD NTX-2114 Car Audio Amplifier
DHD AMP
How do you have it wired now?
Impedance of each voice coil?
Number of voice coils per speaker?
Nov 03, 2008 | DHD NTX-2008 Car Audio Amplifier
Dhd ntx 2009
With two 4 ohm svc subs and a 4ch amp the best way to hook it up is as you have described. There is no way of wiring it to get a lower ohm with your set up.
Aug 28, 2007 | DHD NTX-2009 Car Audio Amplifier
Kitchen Ranges Logo
60 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
