Question about Cameras
My binatone WR780 e reader does not recognise the SD card when downloading apps or books when I get the message No SD Card. When I check on settings the SD card is recognised with the amou/t of available memory given. Any ideas?
3 Suggested Answers
SOURCE: fuji j10 - my mac wont recognise it even using finepix
I had the same problem with my camera & mac.  I got this off the Fuji site and it worked for me:
If images cannot be downloaded from the camera to a Macintosh, check the status of the camera and the Macintosh and resolve the problem accordingly.
1) Check the status of the camera and Macintosh.
1. Connect your camera to the Macintosh and turn the camera on.
2. Open the "Applications" folder on the Macintosh HD.
3. Double-click "Image Capture".
* If the "Imaging device not connected" message appears, follow the steps described in [Checking the connection between the camera and PC].
4. Select "Preferences" from the "Image Capture" menu.
5. The procedure for using the Image Capture Preferences window differs depending on the OS version used. Use the correct procedure for your version of Mac OS.
- Mac OS 10.4: Click "General" in the Image Capture Preferences window.
- Mac OS 10.3: Click "Camera" in the Image Capture Preferences window.
- Mac OS 10.2: Simply proceed to the next step.
6. In "Items launched at camera connection", select "FPVBridge" and then click the [OK] button.
* If FPVBridge is not among the displayed items, follow the steps in [Displaying FPVBridge] below.
7. Quit "Image Capture".
If you implement the above procedure up to step 6, FinePix Viewer launches automatically.
* To stop FinePix Viewer from launching automatically, follow the steps in [FinePix Viewer Setup] below.
Posted on Dec 08, 2008
bbstacker204
  • 40 Answers
SOURCE: My binatone WR780 e reader does not recognise the
try reformatting the SD Card.
Posted on May 18, 2014
Have. Gigaset qv830. I've put in an sd card. When I download book to kindle app how can I save to sd card and not on tablet?
Go into "storage" in settings and then scroll down to the Kindle app. Select "move to SD card"
Mar 13, 2016 | Tablets & eReaders
Files on SD card not appearing?
try to unmount your SD card from device storage settings from your phone and re mount it. Also make sure you are seating the SD card correctly, it could be that the SD card reader on the phone is damaged. However you can check this by inserting a different SD card and if that doesnt work. Its likely the SD card reader that has the problem.
Oct 15, 2015 | Android Apps
How do I access the SD card after I insert it?
Your camera should access your SD card as soon as you insert it. You can plug your camera into your computer and access the card through the camera, or you can get an SD reader and connect that to your computer. Pull the SD out of the camera and put it into the card reader, and your compute will have access to the card.
May 20, 2015 | Cameras
How do I transfer apps and files to ext SD card on my binatone 7inch tab 744?
To transfer apps to SD card, you will use Settings-Apps, open the selected app, then choose Move to SD Card.
If you meant copying files, then use Explorer or other software with similar functions to copy the desired files. I think you actually meant the above.
Jan 12, 2015 | Tablets & eReaders
I have a binatone e-reader but i dont have a debit card. can i download free books? if so where from and what app do i need?
One good source is Project Gutenberg. Many of their books are in HTML, EPUB, and plain-text formats.
Another place to check would be your local public library. Many libraries offer ebooks for check-out. Check with them for more details.
Jan 17, 2013 | Cameras
Sd Card reader not recognising SDHC cards
When You Insert your SD card into the internal card reader, then the SD card is not recognised by the system and the SD card drive doesn't show there. The problem can be because of driver issue, system issue and device issue.
To fix the problem you need to go at device manager if there is a yelllow sign in SD card controller, the problem is most probably caused by a driver issue. Then you need to update the driver. You can also download the driver for your card reader.
Also, check if your SD Card is broken. You can also check it into different devices port.
If it is detected then you can backup of your data.
If the problem not resolved by any means and you require you SD Card data then I will suggest you read - https://www.stellarinfo.co.in/services/removable-media-recovery.php
Mar 03, 2017 | Computers & Internet
Hi, Have purchased an Hitachi HDC-756E Camera but can't connect to my PC - message says " One of the USB devices attached to this computer has malfunctioned and Windows does not recognise it...
This camera uses SD memory cards - avoid connecting the camera to the PC - it only causes problems - get a card reader for $7
Get a SD card reader, take the memory card out of the camera and transfer the images by using the reader
-it's faster
-it's more reliable
- you don't eat up camera batetry life
-you can continue shooting with another card
- you can recharge while downloading pictures
May 01, 2008 | Cameras
Kingston 256mb SD Card not recognised by PDA
In my opinion it is definitely a hardware problem. If you have the same problem with two or more SD cards it must be hardware. Please contact Service partner in your country and ask them how they can help you.
Sep 11, 2005 | Toshiba e405 Pocket PC
Sep 11, 2005 | Toshiba e400 Pocket PC
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
