Question about DuroMax RV Grade 4400 Watt 7.0 Hp Gas Generator w/ Wheel Kit - XP4400
My generator is brand new and no power is coming out of the receptacles it starts and runs fine is it a bad fuse or breaker?
I have a 10kw/8kw portable generator. started up and runs fine but no ac output. checked breakers, all are on ok but no power to receptacles.is there something i can try to reset generator?
Bob,
Not sure what generator you have, but there are videos on how to test the portable generators on this page:
http://www.generatorguru.com/help-me-fix-my-generator-repair-advice/
Dec 16, 2016 | Electrical Supplies
My generator is not pushing out any popwer
didnt specify make or model --generic answer-does it start and run - check the breakers and fuses -open panel and with a meter check output to the receptacles if no power than possible open winding /burnt wire internally
Jul 07, 2016 | Electrical Supplies
Why is there only power coming out of one side of the 30 amp outlet not both
Check that you have power on the generator side of the circuit breaker, check each leg to neutral and you shoudl see 120V approx. If you still only see it on one side you have a bad stator. if you see it on both legs measure across them L1 L2 and you should have 240V, then check again on the receptacle side of the breaker, if you don't have it you need a new breaker
Oct 27, 2012 | Coleman Powermate Premium Plus 6250W...
On our 6250 Generator, the breaker pops continually. This happens when running only lights on our RV, or when using it to run a water pump. It will run just fine and then the sound changes and the...
You will have more available power (and use a different larger breaker already on your generator) if you use the 220 plug instead of the 115v plugs. Have an electrician make you an breakout box separating the 220v plug into two 115v outlets. Or your can replace the push button breakers with better quality 25 amp. Problem is that the 115v receptacles are probably 15 amp. Other solution is to try a 220v pump instead of 115v (more efficient draws less amps). Good luck
Sep 02, 2011 | Coleman Powermate Premium Plus 6250W...
Can a circuit breaker fail? There is no power in my daughters room, but the circuit breaker seems to be fine. It doesn't reset or fix the problem.
Make sure to click breaker completely over to one side and then click all the way back to reset.
Yes, breakers go bad.
You can check your breaker in a simple way.
Turn main breaker OFF.
Mark daughter's breaker.
Take cover off breaker box.
The main breaker will still have power on the lugs where big wires connect.
Rest of box will have no power.
Notice that each 120 volt breaker has a wire connected to end of breaker.
Use screwdriver and tighten this wire.
If screw is already tight, then loosen screw and pull wire out, and move wire to another breaker marked with same amperage. For example if daughter's breaker is 20, then move wire to another 20. Now there will be two wires connected to that breaker.
Turn power ON and see if daughter's room is restored.
This set up will work fine until you have time to replace breaker with same brand as marked on breaker box, usually available at home center (if available).
If power is not restored by moving wire, then there is a loose wire inside a junction box located in daughter's room.
Test each receptacle in room to confirm that nothing on that circuit has power.
If some receptacles have power, start opening other receptacle boxes looking for loose wire, especially at the quick-connects where wires stab into back of receptacle device.
If whole circuit is off, then to isolate location of loose wire, start at the ceiling box, and see if there is a loose black or white wire. Most electricians run wire from breaker to the ceiling box, and then other wires spread out from there and go box to box until each box has a black and white wire that connects back to original breaker.
Dec 29, 2010 | Electrical Supplies
DEWALT DG6300B NO POWER OUTPUT
Hello avid.....
If there is no power to the receptacles:
1. Turn the circuit breaker switches off and disconnect all electrical loads from the generator.
2. Turn the circuit breakers on and test the GFCI's by following the procedures in this manual
on page 1 -
TO TEST A GFCI:
Start the generator. Turn the auto idle switch off. Push in the TEST button (A) on the receptacle.
The RESET button (B) will pop out. Power is now off at the receptacle.
If the RESET button does not pop out, the GFCI is not working. Do not run
generator until the problem can be corrected. To restore power to receptacle,
push the RESET button in. If the RESET button pops out during operation,
stop the generator and check the generator and equipment for defects.
3. Place the voltage selector to the 120 Volt only positions (unless you are using a tool that
requires 240 Volts).
4. Turn the idle control switch off.
5. Turn the circuit breaker(s) off and reconnect the electrical loads. Be sure that the plugs are
securely connected to the receptacles.
6. Turn the circuit breaker(s) on.
7. If there is still no power at the receptacles, take the generator to an authorized DEWALT
service center. To locate a DEWALT service center nearest to you, call 1-800-4-DEWALT
Joe
Thanks for choosing Fixya!
Nov 27, 2010 | Garden
Genset starts and runs fine but the 30 Amp circuit breaker trips as soon as a load (AC) is applied. Started right up, ran half a day, but now when it starts the minutes I click on the ac the circuit...
What about when you have it powering the motorhome, without AC on, does it trip then? Do you have anyone you know with a multimeter and knows how to use it? How about buying a plug in voltage meter at a hardware store as a good start. You simply plug it in to a receptacle in your motorhome and it will tell you the incoming voltage and they are not very expensive. That will help diagnose generator problem.
Nov 01, 2009 | Watts Onan Portable Generator - 4000 ,...
Brand new freezer not starting
You may have plugged your freezer into a bad receptacle, which is not providing the proper voltage. (usually due to a loose wire or bad contacts in the receptacle.) After letting the unit sit for at least 10 minutes, plug it into a different outlet (preferably on a different breaker). You can use a heavy gauge (like 14 or 12 gauge) extension cord for the test. If it starts and runs, fix your original receptacle / breaker / wiring. If still the same results (compressor not starting), call for warranty service.
Jan 06, 2009 | Refrigerators
DuroMax RV Grade 4400 Watt 7.0 Hp Gas Generator w/ Wheel Kit - XP4400 Logo
61 people viewed this question
Top DuroMax Electrical Supplies Experts
Steve
Gene Haynes
Are you a DuroMax Electrical Supply Expert? Answer questions, earn points and help others
