Question about Xerox Office Equipment & Supplies
What is the reason of printer device inactive issue and how it will resolve?
This sucks i cant even figure out how to get onto netflix to watch anything cant even sign in
If you are unable to sign in to your Netflix account, it typically points to an earlier, partially-completed sign up attempt, or to some information from an inactive account that is saved on your device. Follow the troubleshooting steps for your device below to resolve the issue.
If you've forgotten or no longer have access to your Netflix email or password, see " forgotten login or password" to reset your account info and regain access to your account.
Aug 18, 2017 | Computers & Internet
Tip
HP Inkjet Printers - Fixing Paper Path Issues: Paper Jam, Carriage Jam, and...
For a printer to work, the paper has to move through the printer. The route that paper follows through the printer is called the paper path. If the paper doesn't pick up (no pick) or something interferes with the paper path, nothing prints. If the paper is stuck in the path, you have a paper jam. Sometimes jammed paper in the printer can lead to the device that carries your ink cartridges back and forth in your printer to get stuck (carriage jam) as well. Sometimes the carriage can stop moving for other reasons.
The videos in the following playlists were created to help resolve these paper path issues. These videos are not short or entertaining but they are complete. They repeat steps (test print) so even novice users can follow these without having to refer back to instructions earlier in the video. The solutions in these videos are what works to solve paper path issues most of the time. Follow the steps completely. Sometimes people shortcut some of the solutions. Avoid shortcuts for accurate troubleshooting.
The steps for resolving paper path issues are specific to your printer. These playlists have videos for about many different models. We will continue adding to the collection or updating the videos when we find new ways to resolve these issues. The title and description of the videos explain what models the videos apply to.
Some of the videos end with a step that explains that the printer needs to be serviced. If your printer is still in warranty and you get to that step, contact HP for help. If your printer is out of warranty, open a new post in this forum and see if others have a non-conventional solution that will help. Also, Google is your friend offering non-HP out of warranty solutions for servicing/fixing a broken printer.
Fixing Paper Jams on HP YouTube
Fixing Carriage Jam YouTube
Fixing Paper Pick Up Issues YouTube
on Dec 04, 2014 | HP Office Equipment & Supplies
Unable to access voicemail feature inactive
This means the system can no longer communicate with the voice mail. You can try to locate the voice mail and power cycle the unit to resolve the issue, If you still get inactive feature after the reboot you will need to replace the vms.
Mar 18, 2014 | Nortel Networks T7316E Telephone Platinum...
How do I remove the ink cartridge
go to start menu, right-click computer, click manage, on the left double click device manager, when the menu is populated look for other devices, you should see your printer. double-click it. a menu will pop up, click the tab labelled driver, then click update driver, click the option that lets windows search for solutions/drivers online. this will find and install the drivers automatically the way windows knows best, this should fix the printer not detected issue and the printer should be ready for use. that is given that you have the latest kodak software installed on your computer. for some reason there is a compatability issue with windows 7. its the kodak software not windows 7. im looking for a way to report the issue to kodak now, hopefully they can resolve this issue to eliminate all this trouble. took me all night to troubleshoot my printer only to find that kodak hadnt corrected the issue on their end. I LOVE WINDOWS 7 :) hope i helped
Jan 21, 2013 | Kodak ESP Office Equipment & Supplies
How to resolve 107.10 printhead Error on Lexmark c782dn
Make sure the printer is plugged straight into the wall and not through a surge device or power strip. Please try this even if the printer previously worked correctly with this surge device. Power strips and uninterrupted power supplies can cause a low amperage problem, which can trigger a false printhead error.
You may also want to try plugging the printer into a different wall outlet to see if the printhead error continues. This will eliminate the power source as a possible cause of the issue.
If still have the same issue a replacement of your printhead assembly is necessary.
For further assistance please contact Lexmark Technical Support.
Apr 18, 2012 | Lexmark C782dn Laser Printer
I can not log in my apple ID account by Itunes it says that my account is inactive
If your account is inactive, Apple has most likely disable it for some reason. You will want to contact Itunes support for assistance with the issue you are having.
Jun 01, 2011 | Apple iTunes
I was using this printer (Cannon Mp 540) since last one year in between I changed all ink bottes also now the ink cartreges are almost full, two days back I started this printer and I got message on screen...
Resume the printer
You need to use the Resume option to solve the error easily and simply. The printer must be turn off while selecting the Resume option. After holding down the Power button, you need to press down the Resume option. You need to continue this process four or five times. During this process, the counter absorber option will be modified and the issue can be solved. After completing these processes, you need to restart the printer. The error will be resolved after this.
Fix cartridge issues
The storage medium in a printer is the cartridge. If this has any issues, then also the printing process will not happen and thus the printer error B200 would occur. You could change this storage device to resolve this issue.
Proper driver installation
If none of the above solutions could resolve the issue, then the issue might be related to the driver of the printer. Failure of driver updation, incompatibility of drivers due to Operating System up-gradation, malwares are some of the reasons behind the failure of printer drivers. If you update the driver properly, then you could resolve most of the errors that may arise due to the driver issue.
Feb 15, 2011 | Canon PIXMA MP540 All-In-One InkJet...
My printer used to work fine. all of a sudden it has stopped working. I have reloaded the cartridges. It printed an alignment page. I deleted the device from the computer and when i re-connected the...
This Utility program resolve all the printing issue for HP Printers ( Network and USB connection )
This Utility will Resolve :
1. Check Connectivity between the Pc/laptop and HP Printer
2. Check if there any Documents stuck in Queue
3. Check if all the software/Drivers are correctly Installed
4. Check if the HP Printer icon is the default icon to print
5. Will Resolve Printer Spooler Issue and few more issue
This Utility program will fix all these issues.
Download the file on Desktop and Run the program ( Ex. File name = HPPDU.EXE )
Click here to download the Utility and save on Desktop location
Run the HPPDU file and follow the instruction on screen to fix.
This is very useful tool for your future assistance too. This will resolve your issue.
Regards,
Ron
Nov 04, 2010 | HP Officejet 5610 All-In-One InkJet...
I've had this HP printer for years with no problem using it most days. just plug it in when i want to print. but for some reason it has just decided that windows does not recognise this USB device. i have...
Disconnect the power cord from back of printer
Disconnect the USB cable from PC
Turn off your PC
Disconnect the power cord from wall outlet
wait for 10 minutes
Reconnect the PC Power cables
Power on the PC
When you see the PC desktop
Re-connect the Power cable to printer
Re-connect the USB cable of Printer to PC
This should resolve your issue
Sep 25, 2010 | Office Equipment & Supplies
Cleaning tray Error every morning
What I have seen cause that is some of the ink has seeped behind the tray and is allowing it to just barely break the sensor that tells the machine the tray is in the proper position.
Getting the ink removed from behind the tray resolved that issue.
Aug 28, 2007 | Xerox Phaser 8500/DN Printer
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
