Washing machine wont spin,it does everything up to spinning,there is a noise just before it is about to spin
Might be a broken belt which would be an easy fix. Open the unit and see if the rubber belt is lying there broken. It sounds like it could well be the problem. If so, get a new one at an appliance parts place and follow the easy directions to replace it.
Posted on May 18, 2014
  • 1294 Answers
SOURCE: Washer doesn't spin
Does the machine pump water out? Could be there is some block in the outlet pipe, check by opening machine's rear panel. - Does the motor spin ? - In case your machine uses a belt for drum's movment, check that belt isn't broken or loose. In case motor receives power, check for motor's resistace and free movement while turning it by hand. If it dosen't get power looks like its a timer problem. Caution re electrical connections, unplug before examining rear.
Posted on Apr 24, 2007
SOURCE: GE washing machine, wont spin
Same problem (but without any smell). You should try to reset the two computer boards in the washer. You do this by 1) unplugging machine and wait for 30 secs; 2) plug in machine; and 3) open and fully close the lid at least 5 times. This resets computer boards, which can get messed up by power surges, etc.
Posted on Sep 04, 2008
SOURCE: my washing machine wont spin
How do you open the top to replace the lid switch?
Posted on Nov 06, 2008
rylee_smith
  • 8619 Answers
SOURCE: It won't spin
Hi
If your washer pumps out the water but doesn't spin, check these:
• The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
• The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
• A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
• The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
• The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
• The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
• The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 26, 2009
barkencoa
  • 3463 Answers
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Posted on Jan 19, 2010
if its belt driven the belt could have come off or snapped hope this helps. if possible state machine make and model then someone should be able to help you more
Oct 09, 2016 | Washing Machines
Why does my front loader make a banging noise while spinning?
Ive checked thru the top and back cant notice anythin brohen but when i do spin tbe tub the banging noice is coming from in tbe drum and its pretty wobbley
Aug 28, 2015 | Washing Machines
My fridgedaire front loader washing machine has been making weird noises when it spins or washes, making sounds like there is loose metal inside somewhere rubbing and clanking around. As of last night...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 13, 2011 | Frigidaire Washing Machines
Have a proforma toploader and is making a grinding noise in both wash and spin cycle. it is still draining and doing everything just making the noise.
We have a proforma toploader washing machine and when using the machine in makes a very loud grinding noise during the spin and wash cycle. On occassion it also does not spin the clothing out properly, however the machine is still usable.
Dec 29, 2010 | Maytag Performa PAV3200
Washing machine wont drain keeps bleeping ERR2
Jan 19, 2010 | Haier Washing Machines
Kenmore 90 series washer, wont spin, coupler?
my washer wouldn't spin or drain and it was a baby sock stuck in the pump! unplug everything and then take the hoses off and look in the pump! hope this helps!
Mar 10, 2009 | Washing Machines
Washer wont spin
is it draining ok or does it m ake any noises as if trying to spin?
Mar 05, 2008 | Zanussi F1045W Front Load Washer
Washing machine does not spin Whirlpool LLR7144
the motor coupling is probably broken. Especially if it wont wash either. Its probably just filling with water and then making noise but not actually washing. If its doing this than replace the coupling.
Jan 10, 2008 | Washing Machines
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
