Question about Kenmore HE2 Plus Front Load Washer
Something catching on drum
It only started today, when the drum moves round something is catching and maxing a clicking noise. I've examined inside the drum with a torch an can't see anything stuck in any of the holes. If you turn the drum slowly you can actually feel it catch. The. Drum still moves freely. We have taken the pump off from underneath but couldn't see or feel anything. I'm scared if I use the machine I will really damage it but I really think it is a hair clip. My question is how do I get it out as the drum is completely enclosed.
    Problem Solver:
  • 6 Answers
It probably is a hair clip or bra wire, put your head inside the drum use a small torch so u can see, turn drum slowly so u can get an idea as to where it is. look closely in that area, when u spot it u can sometimes get it out by taking a hose off or u might have to wangle it out using another hair grip.....hope this helps
Posted on Aug 24, 2014
  • Kenmore Master
  • 2,251 Answers
Is it noisy in the spin cycle?on the back wall of the drum it looks like a peace sign,this is where the spider gear and or rear bearing is,the gear can crack from overloading or using to much detergent,this could be what you're hearing as you move the drum,if it's something between the tub it will end up in the pump but most likely it's from the spider gear,i've seen this before,when it starts to pin fast gravity pins the broken part to the side but when you move the drum by hand you can hear it,use it and keep an eye on it,if your washer starts getting loud in the spin you'll know it's the spider gear,it would cost more to fix it than have it repaired so this means new washer time.
Posted on May 19, 2014
SOURCE: Noisy Dryer Drum - Squealing/Grinding type Noise.
I have a Kenmore Stacked Washer/Dryer (Model 417.91702000) that has had the same thing happen. I have replace mine twice . . .It is the rear dryer bearing.
You can purchase a kit that contains everything to replace it.
You have to work from the front, all the way to the back.
Make sure that you also check the felt pad glide on the front door panel (the drum rotates on this). You may need to replace it also, it should have teflon pads built into the felt that the drum rests on . . .
Posted on Jan 21, 2008
SOURCE: Kenmore spin cycle thumping noises
I just went through the same issue with my Kenmore front loading washing machine. I assumed (and a Sears repairman also told me) that it is the bearings. After I took the drum assembly out, I saw the rear drum broken and the inner tub hitting the outer tub. I ordered the outer drum assembly and only when I took the inner drum assembly out I realized the the "Spider" attached to the inner drum (and spindle) was broken. Entire drum assembly cost $417 + shipping and it may be cheaper in the long run to buy a new washer. I like the front loaders because they save water and good for the environment, but the US manufacturers have not yet perfected the technology like European manufacturers (or they don't want the machines to last too long just like cars). Anyway, I am looking into welding the spider tomorrow. If not will return the outer tub assembly and buy a top loading washer for $300!
Posted on Mar 07, 2008
duby1990
  • 367 Answers
SOURCE: Kenmore Elite Washer (He3t) front load
The bearing in the duet is attached to the outer rear tub of the washer. You have to remove the whole rear half of the outer tub. Take off the back and you will see all the screws around the tub where they attach together. you have to buy the whole rear half too. They wont let you replace just the bearings.
Posted on Nov 18, 2008
  • 254 Answers
SOURCE: KENMORE ELITE HE3T CODE F-02
F02 is long drain.
Just because it came up doesn't mean there's a problem, it simply means there was a failure during the cycle, if it returns on a regular basis, you have a problem.
F02 error could be caused by the over use of soap, you need to make sure your using 2 tablespoons of HE soap, 1/4 cap at the most.
Over sudsing, could cause the water pump to run longer, the pump is designed for 15 min duty cycle which means, 15 minutes on to 45 minutes off. The computer may sense too much soap, and continue to pump. HE soap will cure that, along with SUD error, possible F09 (overflow condition), you may also notice the timing is wrong, HE soap works well in these machines and F/l washer go hand in hand
if the F02 returns the remove the 3 torx screws from the bottom kick panel, and remove the kick panel, right there in the middle you will see a big round handle, turn it and then slide it out, have some towels ready, there will be some water in there, and check to see if you have any thing in there that will slow water flow, tooth picks and other "floating" items may jam the impeller.
Posted on Apr 01, 2009
lojacksdad
  • 121 Answers
SOURCE: Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
Posted on May 02, 2009
I had someone out today to try repair my zanussi jet system washing machine as it wouldn't spin, the engineer said that is something stuck between the drum and liner and he can not repair it
Not a very good engineer, so I that has suggest you contact another more reputable one. It is a case of removing the rubber seal between the drum and liner and fishing around inside if that is the case. Can you manually spin the drum in either direction? If it moves freely then there is nothing stuck in there and it may be the actual machine program or spin activation at fault.. If it moves in only one direction can you hear something catching? In which case he may well be right. My guess would be that it is an underwire from a brassiere.
Nov 10, 2015 | Zanussi Washing Machines
During spin cycle the washer makes a loud thumping noise. Not a clanging/sharp noise. When I manually turn drum it sounds like something is loose inside. Like a ball may sound inside drum as it turns.
Is it a front loader? You may have something stuck between the tubs or it may be a broken "paddle" One of the plastic baffles that move the clothes around in the tub. they should all be tightly against the tub.
May 26, 2015 | Washing Machines
Clicking noise stihl 250
Probably your clutch is loose and noise is coming from chain cover. Anchor the bar in a vice and remove the nuts holding the cover on.
Mar 05, 2014 | Garden
I have a Zanussi zwf1621s washing machine which is approx 6 yrs old. When spinning today it made a strange noise so i turned the machine off. When I went to restart the machine all the lights came on but...
it really depends on the sound it made, if it was a rumble or a screech it could be the motor, or grinding it could be the bearing or something is in the drum, if it was on a drain cycle it could be the pump or something in the pump blocking/catching on the fins in the pump ( hair can affect the pump). coins can sometimes get to the drum housing and cause damage, ie catch the heating element, this can make the washer not start as the washer has a earthing sensor on the element resistance. hope this helps.
Nov 06, 2017 | Zanussi ZWF1420W Front Load Washer
When on spin mode the machine makes a terrible grinding noise and won't spin on 1200 speed Hotpoint Ultima WT965 7kg
Turn drum by hand, if you feel it catching, its something between the drum and tub, put in through soap draw usually by children. Can be removed by taking out the heater element to get access under drum.
If it feels rough all the way round when turned and it can be lifted up slightly ( free play ) then its probably the drum bearings and seal failed.
Oct 20, 2013 | Washing Machines
Machine is filling with water but the drum wont turn or spin
MOST LIKELY THE MOTOR IS SHOT OR THE BELT AROUND THE DRUM CAME OFF THE DRUM
Feb 06, 2013 | Washing Machines
My washing machine's drum is making a scraping sound when turning
There are two different types of "drum balancers" manufactured into washing machines today... One is a disk type (most washers with this have 2-6 depending on age, manufacturer, and quality), the other type is a self-balancing style. It sounds like you need to order some new drum balancers. The repair will take approxmiately 1-3 hours depending on if the it is a front or top-loading machine.
Hope this helps, James
Jan 05, 2011 | Hotpoint Washing Machines
Re: Lavamat 72630, 6 yrs old Very loud noise from drum movement, has increased over last ten washes. When machine is stopped, on rotating drum we note it is catching on something. Nothing rattling, don't...
Hiya admin47..... to be a litle more certain diagnosing your problem, please can you do the following.
1. with the washer empty.. ie the drum... please rotate the drum by hand at any speed you can get... without moving the drum sideways/backwards. Listen for any peculiar noises.
2. Then move the drum backwards at the bottom of the door ( dont force).. then let the drum housing go.. swinging by its own movement, again listen for any strange noises.
3. Do the same pushing the drum from the inside to the outer casing..again dont force.. let go listening again...
Please post me the results
Regards Faggly
Mar 18, 2008 | Washing Machines
Kenmore HE2 Plus Front Load Washer Logo
139 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
