Question about Gamehouse NCIS The TV Game
Model number 30201
What year this tracter 35 Massey ferguson chassis number snm173291 model code 30201
I have a Massey Ferguson tractor serial number 9A89879 I would like to know what model it is and what year it is
I cant give you an exact date but it is from the early 70s. That is when they were yellow. My educated guess on this is 1973. If you go to a Massey Ferguson dealer with your numbers they will gladly tell you what year it is exactly.
Jan 27, 2016 | Toys
We need a Repair manual
Hi Susan:
Here's a link that will give you a huge number of contacts where you should be able to find the info that you need.
https://www.google.ca/#q=massey+ferguson+231S+tractor
Cheers and Happy New Year.
Jan 01, 2016 | Toys
Does the Massey Harris combine serial number 25-06-03 indicate the year of manufacture?
I don't think it does most were shorter numbers if I recall, and just indicated the model but not the year since they were made multiple years for the same model Your AGCO dealer and MF dealers might be a better source
Jan 04, 2015 | Toys
Lookup serial numbers
Hi, here's a link to these specs. It looks like however that you did also find this info. Perhaps you'd comment if this was helpful. Thanks and good luck!
Just in case:
TractorData.com Massey Ferguson 362 tractor information
http://www.tractordata.com/farm-tractors/000/7/8/784-massey-ferguson-362.html
Aug 30, 2014 | Garden
Trying to find out what year a Massey ferguson tractor is the serial # is 9 A 108154
1971 and appears to be one of these models. Massey Ferguson Model MF-135, MF-150, MF-165, MF-175 and MF-180
Mar 06, 2014 | John Deere Tractor 1020, 1520, 1530,...
Where would i find the chassis number on a massey ferguson 3115
Climb up into the tractor's seat. Look below the lower left-hand side and lower right-hand side of the steering wheel panel for the serial number. Certain older Ferguson tractors have the serial number stamped to a plate that is mounted to one of these areas of the steering wheel panel.
Serial Number Plate:
http://old20tractorparts.com/mf-165-tinwork-parts/1356-massey-ferguson-165-serial-number-plate.html
Inspect the left- and right-hand sides of the tractor's main frame. Certain older Ferguson tractors have the serial number stamped to a plate on the outside of one of these areas of the main frame.
Inspect the top of the transmission housing for the serial number. Certain older Ferguson tractors have the serial number stamped to a plate that is mounted to the top of the transmission housing.
Jan 27, 2014 | Aprilia Pegaso 650 i.e Motorcycles
Massey Ferguson 35 has no spark, I have replaced the coil, what could be the problem?
Test the plug wires, coil wire---could be the ends of the wires. Points could be burned and replace the condenser?
Feb 26, 2010 | RTO Massey-Ferguson Tractor TE20, TO20,...
Gamehouse NCIS The TV Game Logo
42 people viewed this question
Top Gamehouse Apps Experts
Are you a Gamehouse App Expert? Answer questions, earn points and help others
