Question about Compaq Computers & Internet
D5305 video driver? - Compaq Computers & Internet
Bccode 100000ea bcp1 8a8a8c70
This might indicate a hardware problem with the video adapter, or a faulty video driver.
Try reinstalling the video card drivers by doing the following:
1. Download Driver Cleaner Pro or Driver Sweeper (both have free versions; make sure the version will work with your OS) to your desktop screen and install.
2. Download the latest diver(s) for your video card but don't install them.
3. Uninstall your video card drivers and reboot your PC into Safe Mode. Run Driver Cleaner Pro or Driver Sweeper but ONLY for the video card drivers. I had someone use it on their chipset drivers! If it doesn't find any video card drivers that is quite okay.
4. Reboot and install new video card drivers.
Oct 11, 2013 | Alienware PC Systems Area-51 750i PC...
When playing videos on my computer the video driver fails and the video screen goes green... I get a message saying "video driver failed but has recovered" Happens every time i try to watch a video. I'm...
Most probably the drivers downloaded from Nvidia is not the correct version or an older version for your video card. That is probably windows revert the best options drivers for your video card. You can check the version or the date windows automatically installed from the device manager. You also can also use "Microsoft Updates" to update your drivers.
To remove the video drivers, go to "safemode" and from the "device manager" uninstalled the video drivers.Be sure to download the correct version for you video card and run the installer from Nvidia.
Do update your DirectX too.
Hope it helps.
Jul 29, 2010 | Computers & Internet
Video cam drivers Model video cam nb
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Jul 06, 2010 | Genius VideoCAM Express Webcam
The video its wrong
If you cannot change the video settings ie. the screen resolution and the number of colors, then most likely problem is the video driver was not installed or the wrong video driver was installed.
If you have lost the driver CD for the video card then :-
Have a look at the video card, you need its make and model to download the XP or Vista video driver from the video card manufacturer's WEB site, and then install this video driver.
Oct 28, 2009 | Computers & Internet
I cant find the lcd driver
RIGHT CLICK YOUR DESKTOP BACKGROUND.
choose PROPERTIES, SETTINGS
on left side at bottom there is a small rectangular dialogue box which allows you to select 16 bit, 32 bit, 256 colors, etc. choose 32-bit. REBOOT
also if you have an OFFBOARD VIDEO card you have to go to MFR website to download video card driver and resintall it. it is probably using default since there is no driver loaded for the video card.
If ONBOARD video you have to go to MOBO MFR and download CHIPSET drivers. download EVEREST HOME EDITION (last free version) 321 and RUN it. it will identify all chipset & mfr
Apr 26, 2009 | Computers & Internet
Need video controller driver for acer travelmate 2355LCi
It could be listed as a vga driver or a graphics driver. Hope this helps.
Jan 22, 2009 | Acer TravelMate 2355LCi Notebook
Acer Aspire 5920
Thanks. Driver Provider is Intel Coporation, that means the manufacturer's driver for your video card isn't installed yet. Here's what you can do. If your video card is built-in, you need to run the setup CD for your motherboard and install the Video Driver. Alternate solution is click on Update Driver let is search the net for the udpated driver.
Are you using built-in Video Card or a separate Video Card? What is the brand of your computer?
Jul 28, 2008 | Computers & Internet
Windows 98'
We confirmed the following software and drivers compatibility with Windows 95, 98, and ME. Picture Navigator JLIP Video Capture JLIP Video Producer JLIP Video Player Card Navigator USB Drivers GV-PT2 Printer driver & Capture GV-DT1 Printer driver & Capture Video Navigator None of the above software will be compatible with Windows NT. At this time there are no drivers available to make these software programs compatible with Windows NT. There is an update available for the Picture Navigator software to work with Windows 2000 and XP in the Customer Support area of this site. (When executing the update be sure to have Picture Navigator closed). The following versions of software and drivers will work with Windows XP. Picture Navigator 2.1.5.1 JLIP Video Capture 3.1 JLIP Video Producer 2.0 JLIP Video Player 1.0 Card Navigator 1.0 USB Drivers Video Navigator
Sep 14, 2005 | JVC GR-D70EK Mini DV Digital Camcorder
Windows 98'
Sep 14, 2005 | JVC GC-A33 Digital Camera
Computers & Internet Logo
35 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
