Question about Electric Kid Trax C6 Corvette Ride On
The corvette drives for about 30 seconds then stops. But if i hold up the car so the back tires are off the grounds it will keep running. Do i need a new battery i checked all the wiring everything looks good,
    Problem Solver:
  • 13 Answers
It is probably the battery, it doesn't have enough powe to run with a load so when you pick it up it will turn the wheels due to needing very little to turn the wheels. So, the real problem is the battery. Those batteries are known for being junk and it isn't fair to customers at all. It is under powered, won't hold a charge and cost an arm and a leg to replace. I know I own one and finally got the solutions to overcome the expense to fix it. If you go to www.cammhsm.com you can get the scoop on it and save a lot of time and money and get away from that stock battery and charger. www.cammhsm.com
Posted on May 29, 2010
My car is eating away at my tires
Keisha,
How many miles on these tires? Are they wearing on the outside edge, inside edge, or evenly across the tread? do you have them rotated regularly? Generally the number one cause of premature tire wear is improper inflation. Always use the tire pressure information on the sticker on the inside of your driver side door, not the "Max PSI" listed on the tire. The second cause is the wheels being out of alignment. Most tire shops will check the alignment for free. I usually suggest Firestone because they (to my knowledge) are one of the only shops left that do lifetime warranty alignments. Good luck and hope this helps.
Nov 23, 2012 | 2006 Suzuki Reno
1988 bronco II vapor locking?
Just a guess here, but check your ignition coil. Make sure it's mounted nice and tight to the block. a bad ground on a coil will mess with you bad. other than that, I'd check and replace your fuel filter.
Jun 16, 2012 | 1988 Ford Bronco II
Why the service LTPWS light stay on on my 1994 corvette LT-1
You need to reset the low tire pressure fault waring, this can be a defective sensor. Read the procedure below.
Replace sensors as required.
Clear DTCs by grounding DLC (under dash in front of driver) terminal 6 to 5, three times in ten seconds.
Receiver/control module will confirm that its memory has been cleared by illuminating both the "L0W/FLAT TIRE" and "SERVICE LTPWS" lamps at the same time. Both lamps will remain ON until the ignition is turned to the OFF position and then back to "ON".
RF sensor MUST be color code BLUE.
If you still get codes, read out the DTCs by connecting DLC terminal 6 to 5 to flash LTPWS. Look for 23, 33, 43, 53 or 24, 34, 44, 54. Right front is LOW TIRE DTC 53 and WHEEL SENSOR DTC 54.
All codes will be preceded with DTC 12. DTC 99 is possible receiver fault.
Nov 03, 2011 | 1994 Chevrolet Corvette
Wat can I do to get better gas milage in my 1989 chevrolet Corvette without droping horsepower or torque?
Make sure the engine is properly tuned. Check tire inflation. Accelerate slowly. Anticipate stops. Probably not what you wanted to hear when your driving a Corvette but there are no magic solutions.
Jun 21, 2011 | 1989 Chevrolet Corvette
When I pass 25 - 30 mph my car suddenly sounds like an airplane. It makes no sound when at a stop, only when in motion going past 30. at times it feels like it may be vibrating.
Hi, sounds like a bad wheel bearing, possible tire noise, if you can identify or narrow down which end of the car (front or rear) its coming from you can rotate your tires(front to back) and test drive and see if the sound moves to opposite end now. If not you can use a stethoscope or long screw drivers and spin each wheel by hand (vehicle not running!) and listen for a humming grinding sound while tires are off ground via a lift or jack.
May 17, 2011 | 2003 Toyota Corolla
When i start the car and begin to drive, the steering wheel vibrates, as i pick up speed it stops, i've had the tires rotated and balanced several times, it's fine for a while than it starts again???
These may not be your problems since it is occurring even at low speed but you might have the car just free of the ground and rotate each wheel and watch the clearance while you do it for changing clearance. This will reveal 'out-of-round' tires; it happens. Second; but less likely, I had this annoying problem of two speed ranges, around the 30 MPH and 70 MPH points causing wheel shake and it only stopped after I tossed the original brake rotors and replaced them with Brembos.
In 50+ years of driving, poor tires have happened several times and brake rotors twice. There was a feature of a now-defunct chain called 4-Day Tires that kept me going back called 'tire matching.' All replaced tires were checked and then shaved slightly to correct for roundness. With this done, I never had any loss of balance during the life of the tires. Haven't found this offered anywhere else since then; too bad.
Jan 26, 2011 | Kia Spectra Cars & Trucks
How to turn off change oil light on 2001 Corvette
Unless there is something wrong with you buttons the procedure is as follows:
1. Turn ignition key to ON (not start)
2. Press ENG MET button on trip monitor & release, then press it again within 5 seconds.
3. Within 5 seconds again press and hold GAUGES button until Change Oil lamp flashes.
4. Continue Holding Gauges button until lamp stops flashing & goes out.
5. You should be done, start & shut off car. If it didn't work turn off car and start from top.
Some buttons are very sensitive so try and be deliberate & steady when holding.
If that helps please rate my answers!
Brett
Mar 19, 2009 | 1994 Chevrolet Corvette
1985 Corvette, starts runs rough then dies
if you changed your fuel and that did not fixit its definitely the maf sensor.
Nov 26, 2008 | 1985 Chevrolet Corvette
1996 Corvette
normally a spare will not fit in the storage area of the corvette. most came with run-flat tires. it is also possible that the car came with a small compressor and some sort or liquid stop leak (ie tireslime) My best advice is to contact a local corvette club or dealer. they can tell you exactly what your vehicle is equipped with.
Oct 02, 2008 | 1996 Chevrolet Corvette
Electric Kid Trax C6 Corvette  Ride On Logo
151 people viewed this question
Top Electric Toys Experts
ray gallant
Robert A. Watson
Robert A. Watson
Tom Chichester
Are you an Electric Toy Expert? Answer questions, earn points and help others
