Question about Gmc Dodge Ford Reverse Back-up Sensor Alarm Kit
Toyota valkvire throtle not respon after battery change
Where does the throtle body gets his signal?
Too funny-while I was typing the question changed I think
Oct 29, 2013 | 1995 Toyota Camry
My 1AZ engine D4 Toyota Premio G 2003 keeps shutting off when i drive and is now having problems to even start. I carried it to a dealer and they changed spark plugs, clean the injector and told me that i...
buy carb cleaner.,. remove the tube or hose going to the throtle,, .remember do not unplug any socket or wire sensor from d engine
start engine . then spray the carb cleaner direct at the throtle ..as the engine runing,d more u spray d more u have u rev d engine,,. rev the accelerator to 3 to 5000 Rms'tachomrter.. to flash out dirty carbon that causes the car to stop
do it several times,until u hear the engine is stable.and respond quickly..den stop eng, installed back d remove parts
Sep 11, 2013 | Toyota Passenger Cars & Trucks
Idles to high
check for a vacumn leak ,there is a vacumn hose that could have come off during your cleaning process.
Nov 06, 2011 | 2002 Toyota Tacoma
Battery dead and is not responing to charger
ITS BETTER TO CHANGE BATTERY SIR. IT MAY BURST WHEN CHARGING WHILE ITS NOT RESPONDING . THANK YOU
Dec 31, 2010 | Nokia 2720 Fold Cell Phone
Rough idle 1995 dodge cummins 190 K
if you have cruise ensure that isn't interfering with the throttle linkgae near the engine above the injector pump. could be injector pump giving you issues.
Apr 08, 2010 | 1995 Dodge Ram 2500
After changing a batery requires a reprograming?
you may have to get the ECU reset. Sometimes changing a battery can cause a fault. Take it to the dealer for verification.
Sep 16, 2009 | 2004 Chevrolet TrailBlazer
Wii console will no longer start
In the manuel, there is no mention of a cell battery in de console.
We have opened the console and changed the battery. Everything is ok now.
Apr 05, 2009 | Nintendo Wii Console
Mr2 turbo
Have you changed the fuel filter lately? if not do so, this sounds like a fuel pressure problem.
Oct 16, 2008 | 1994 Toyota MR2
Toyota 2002 van's engine will cut off when you try and put the car in geer. Will do this when the car is warm.
most likley it is the idle air control valve on the bottomof the throtle body. About $215. It will get worse the dirtier it gets. I just replace mine and it runs fine now. Also if you replace this and the spark plugs are anywhere needing to be replaced do it while you have the throtle body off. the rear three are hard to get to normaly
Aug 05, 2008 | 2002 Toyota Sienna
Gmc Dodge Ford Reverse Back-up Sensor Alarm Kit Logo
14 people viewed this question
Top Toyota Vehicle Parts & Accessories Experts
ashburton
Colin Stickland
Colin Stickland
jamie suver
Level 1 Expert
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
