Question about Samsung HLR5067WX 50" Rear Projection HDTV
Changed light engine for samsung dlp model hl-r5067w picture good but upside down. How do you get into yhe service menu. Thanks James
  • timeasier Jun 24, 2009
    Yes thak you very much have a great nite James
    President:
  • 1,197 Answers
After you get to the item that needs adjusting
Write down the original setting
just in case you have to go back.
1. TV turned off
2. Press 'Mute' then '182' then 'Power' buttons on the remote.
You are now in the Adjustment mode
4. Use the 'Channel up'or"Channel dwn' to select the category.
5. Use the 'Volume up or dwn' to enter the category.
note:Some models may not have Category Selection.
6. Use the 'Channel up or dwn' buttons to select item to be adjusted.
7. Write down the old value of the item before changing.
8. Use Volume up and down adjust the value.
9. When you have made all the adjustments you want turn the set off to exit.
if ur not able to flip the screen by going to the service menu......
a failed dm board on the back of the engine... it can be repaired or replaced.
You when you remove the back cover you will find a board right in the middle remove the ground sheild and you will find failed caps on this board about 20 they are 4.7mfd and 100mfd caps all 25caps
You can replace them yourself it does require a solding station with a temp. control and there is a great risk of damage to the traces if you have not remove surface monted caps before.
But i can tell you a service center (perferable a samsung authorized one) should be able to repair this set for under $350.
This is a complex repair but it can be done you could also replace the board it is ussually refered to as the formater or the dmd board but customer cost is ussually 3 times the dealer cost us service centers pay for the part.
You can confirm this failure with a blow dryer on the back of the board while it is on... it will cause it to act up or improve depending on the level of the failure on the caps. if you have access to an esr meter you can narrow it down quickly the caps will measure less then 50
do not remove the board until you get a replacement, the DLP chip is mounted to the back of it so reinstalling it has a difficult align proceedure (but that is a whole other issue)
If you would rather not replace the engine many service companies can remove the board and send it for rebuilding but this option is not open to consumers it is only open to service centers with state required lic. or proff of sales tax lic.
shud u require any place from where u can get replacements....... i would recommend http://www.samsungparts.com/
if u feel i ve helped you... kindly rate my service......
good luck
Posted on Jun 24, 2009
  • SAM JAYANTH CHANDRASEKAR
    hi thi is iversh again... please stay safe and ensure the tv is all plugged off and cool if ur trying to work inside the tv..... the tv has quite high voltages......
    stay safe.... and good luck
Samsung dlp HL-R5067W sound no picture
Check for open or leaky capacitors look for bulge on the top of caps
Mar 28, 2014 | Samsung Hl-r5067w 50-inch Hd-ready Dlp Tv
Buzzing noise in my HL-R5067W
you might be right. Color wheel can make this noise.
Jun 08, 2012 | Samsung DLP HL-P5663W 56" TV
I have a Samsung HL-R5067W DLP HDTV. I have HD cable from Comcast. My TV plays the HD signal flawlessly. The non HD channels have columns and rows of colors on the screen. The picture can sort of be made...
this could be 1 of 2 things--either the light engine or the digital board--i'm betting on the board because hd cable is good--light eng/cost prohibitve--board maybe !!
Jul 22, 2009 | Samsung DLP HL-P5663W 56" TV
Remote Code Samsung 50" DLP HL-R5067W
022 036 043 159 160 170 175 212 215 702 713 706
Dec 14, 2008 | Samsung 50" Slim-Depth DLP HDTV
Samsung HL-R5067W
defective color wheel needs service
Sep 09, 2008 | Samsung DLP HL-P5663W 56" TV
Picture is upside down Samsung HLR 4667W 46 inch
Enter service.....go to engine and change engine type. This work
May 31, 2008 | Samsung HL-R4677W 46 in. HDTV Television
No sound or picture HL-R5067w
sounds like ur tuner is bad.. ur better off buying a new tv then geting it repaired
Jan 18, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
DLP HL-R5067W RESOLUTION
Please provide all part info for verification.....Your model is
HL-R5067W.......Engine # = ? , DMD # = ?.....Possible wrong part installed or bad new parts............T.
Dec 21, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung HL R5067W Problem
You have a bad Light Tunnel in the Light engine, you can replace the engine, or try to replace the tunnel.
Jul 31, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung HLR5067WX 50" Rear Projection HDTV Logo
60 people viewed this question
Jerry Greenberg
Jerry Greenberg
