Question about Caterpillar American Construction Equipment 1:87 Scale
When excavator machines hydraulics function is slow
Excavator machine accelerator cable is damage then i change the accelerator cable then i start the machine one day properly work after next day the hydraulic function is slow down
How do I change j c b 215 rubbertire backhoe hyd’s system over to excavator style right now the machine is backhoe style and I want it excavator style what hoses would I have to change it’s a 2003 jcb
the jcb 215 hoe is a 4 wheel tractor frame where as the excavator is a tracked vehicle
the change over would cost more than leasing the track machine
it is considered not a feasible exercise
contact JBC for further advice on the requirement
Jan 19, 2018 | Cars & Trucks
My sewing machine started making a clunking noise
Try a brand new needle. A bent, dull, or damaged needle will cause havoc. Changing the needle frequently is necessary to keep the machine functioning well. It is a "very" inexpensive fix for a lot of sewing machine problems.
Mar 06, 2016 | Sewing Machines
Why won't my excavator stop overheating?
Search Results
    Solving Hydraulic System Overheating Problems
    www.machinerylubrication.com/Read/680/hydraulic-overheating
    Overheating ranks No. 2 in the list of most common problems with hydraulic equipment. Unlike leaks, which rank No. 1, the causes of overheating and its ...
    Cat 320 overheating - Heavy Equipment Forums
    www.heavyequipmentforums.com/showthread.php?2828...overheating
    Mar 28, 2007 - 15 posts - ‎10 authors Anyone here have a problem with a Cat 320 overheating? ... that many heatingproblems in excavators are caused by hydraulic problems. 5T Excavator KX161-3 overheating
    Apr 22, 2013
    john deere 270D excavator over heat
    Aug 1, 2011
    cat 305CR overheating issue
    Jul 23, 2011
    cat 312 overheating
    Jul 31, 2008
    More results from www.heavyequipmentforums.com
Oct 14, 2015 | Cars & Trucks
Is there an adjustment to increase hydraulic power on Komatsu pc35mr-2 mini excavator? Or is there a sensor that is responsible for relationship between engine rpm and hydraulic operation?
you assumption is right
the pump is operating at idle as at full rpms and is controlled by pressure relief valves
When demand for pressure is low the valves will be partially opened and will operate when the pressure is reduced ( ram valve is moved)
Higher rpms maintain the pressure for faster ram operation
I would suggest that you have the system pressure tested by a service centre as it could be a malfunctioning valve (solenoid) or a failing pump
Mar 28, 2015 | Mini Cars & Trucks
How do I remove the engine on a IHI 35nx mini excavator to rebuild it
Undertaking that major a project, even on a "small" machine like a mini-excavator, should be done using an authorized service manual. I suspect with all of the hydraulics and other mechanicals you really want to be sure of what you're doing. If you're looking for a free service manual, I can't help except to say to consult your local dealer. An online source I found for a manual, albeit for a fee, is found here:
http://www.gciron.com/IHI_Parts_35NX_Service_Manual_Service_Manual_35NX_p/35nx%20service%20manual.htm
Dec 16, 2014 | Mini Cars & Trucks
Cat E70B excavator
Evacuate the hydraulic tank and clean with kerosene.Get as much fluid out of the machine as possible. Replace Filters and if it builds back up with metal SELL SELL SELL it or your in for some big money repairs.
May 05, 2013 | Caterpillar E70B Excavator
Ex40-2 slow on one track motor,may be loosing digging power when working hard,have change hydraulic filter and track motors oil
I am assuming this is a Hitachi EX40-2 mini-excavator. Two tests that need to be run. First is the propel motor pressure equal to both propels? Secondly, but possibly more important is to check the slow propel motor for excessive case drain. This would indicate the propel motor is worn out. Find in your hitachi service manual the accepted amount of case drain for that model, disconnect the case drain line from the propel motor and cap the line. Install another hose to the case drain port with the other end in a 5 gallon bucket. Start machine and run propel for 30 seconds. Shut off and check amount of oil in bucket as compared to acceptable amount of leakage from machine spec book. All this does is measure the amount of leakage past the propel motor slippers, which gives an indication of excessive wear tolerances. Replace propel motor if needed.
Jan 04, 2010 | Garden
Possible problem of slow movement of Hydraulic cylinder and Travel of Komatsu excavator
hi, have u checked ur fluid and filter, if so u need to check the pressure.
u can buy a normal guage and and get a bit of pipe made up to suit ur job.
you might be able to get away by increasing the spool valve. but if ran low on hydraulic then it is a new pump.
Aug 29, 2009 | Norscot Group/Cat Norscot Group 1/87 Ho...
Hyd controls get hard after machine has run ten
You got a pressure crossover problem there , main pump pressure is leaking into the servo system I would suspect the pump.
Apr 10, 2009 | Garden
Caterpillar American Construction Equipment 1:87 Scale Logo
279 people viewed this question
Top Caterpillar Toys Experts
fordexpert
DROPNDEAL
DROPNDEAL
Are you a Caterpillar Toy Expert? Answer questions, earn points and help others
