Question about Toshiba e-Studio 232 Black and White Copier
Toshiba e232 indicate f070 - Toshiba e-Studio 232 Black and White Copier
What does call for service F 070, in toshiba e studio 230, refer to ? How can I solve the problem?
Toshiba Studio 230 Error Codes
Toshiba e-Studio 230 Error Codes Code: F070
Code
F070
Description
Communication error between System-CPU and Engine- CPU
Sep 30, 2016 | Toshiba E-studio 230 Multifunction Copier
How to fix toshiba studio 280 photocopier with an error code: F070. Thanks
If you wish to get some details; check the site linked here. Pull up older posts........
http://electro-medical.blogspot.com/
Jun 07, 2016 | Toshiba Office Equipment & Supplies
How can i format hdd and update frimware ? and my copier not running up and i tink hdd not knowe
Backup everything you wish to keep, if anything. Power up and left click on "My Computer". Select "Format" and if given the choice select NTFS. It is more modern than FAT32 format.
Jan 01, 2015 | Toshiba E-Studio 305 Digital Copier
Clear maintenance counter es 162f
Hi:
Press # * clr * then key in main code 20 sub code 01 and press the start button . Then press the function clr button twice to get back in normal mode.
Andrew
Jul 07, 2012 | Toshiba Office Equipment & Supplies
F070
F070 indicates Communication error between system CPU and main CPU. U need to check the version of the SYS ROM on the SYS board, and engine ROM on the LGC board. Perhaps 1 of the board causing issue.
Jul 02, 2012 | Toshiba e-Studio 232 Black and White...
F070
F070:SYTEM CPU-ENGINE CPU COMM PROBLEMS
You will need a technician to assist you with this problem.
May 20, 2012 | Toshiba e-STUDIO 4511 Printer
How to use toshiba e232 printer without ****
Without a print enabler (this allows you print through the network), the only option is print through the USB port, Want to be able to print by anyone in the network, share printer with a host PC via USB, or use a net print server (via USB).
Oct 21, 2011 | Toshiba Office Equipment & Supplies
I have a Toshiba EStudio 3511. It is giving a message saying Service Required. I hit clear and number 8 and I get error code F070. How do I fix this? I tried turning it off and on several times even from...
f070 communication error between system cpu and main cpu
firstly try updating the firmware version
then possibly replace the system board and or lgc board good luck
Mar 23, 2011 | Toshiba E-STUDIO 850 Copier
Why are all the lights flashing on my e232
If all lights are flashing,it indicates an error on the printer. Please press the continue button to seethe secondary error code. The secondary code will indicate the another lightsequence indicating specific problem on the printer.
For further assistance, please contact Lexmark Technical Support.
Feb 11, 2011 | Lexmark E232 Laser Printer
Toshiba e-Studio 232 Black and White Copier Logo
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
