Question about Nespresso Citiz C110
How to check the fuse in the lattissima ? - Nespresso Citiz C110
Delonghi
For De\'Longhi En520.W Nespresso Lattissima Plus Coffee Maker Team De-Brewerz.com says:
1. Your coffee maker might suffer from water pump, water sensor or PC board failure. Claim the warranty if recently purchased. If you are in India then contact us @ www.De-Brewerz.com
Now you can order all De Brewerz Stuffs online in India @ www.fabkaart.com
Aug 29, 2014 | De'Longhi En520.W Nespresso Lattissima...
How obtained A download a manual?
Go to this site to get a manual. It is listed under CUSTOMER SUPPORT. :-) Here is the link to the website. http://www.delonghi.com/en-us/products/coffee-and-espresso/coffee-makers/nespresso-system/lattissima-pro-en-750mb-0132192224?gclid=Cj0KEQjwrqieBRCln82Rgufz7I0BEiQAPNjAIwPVQ5e68guS8rRE8O_Lry_tcDMQOapRV2KTlEHJuIkaAqS_8P8HAQ Lattissima Pro EN 750 MB
Jul 20, 2014 | DeLonghi Coffee Makers & Espresso Machines
Milk warmer container on side of machine
Check the heater or the thermal fuse, they may be busted.
Mar 12, 2014 | Nespresso Lattissima 660.R
Lattissima red light keeps flashing
Take the water tank off and dry the bottom of it.
May 25, 2012 | Nespresso Lattissima 660.R
Water button orange light appear even after descaling
I had the same problem too.
Do repeat the descaling with water only. After the descaling the Lattissima shuts down. Just wait some time after shutdown before restarting the Lattissima again. The orange light will be turned off.
Hope this helps you too!
May 01, 2010 | Nespresso Lattissima 660.R
I cannot get my Nespresso Lattissima to clean out milk when clean button is pressed, nothing happens. Can you help me?
Have to pull out the entire container and push it back into the unit so it fully connects with the machine. Then try again.
Dec 04, 2009 | Nespresso Lattissima 660.R
Coffee tastes very acidic
Hi kdimof,
I realize you posted this problem over a year ago, but I was curious to see if you were ever able to resolve this problem, or find the exact cause.
I have the same issue you describe. I descaled my Lattissima for the first time using the Nespresso descaling solution. And now, two months later, I cannot remove the chemical smell/taste of the descaling solution. I've run numerous descaling cycles with just water (as per Nespresso's customer service advice), with no success. I was forced to accept a refurbished machine (even though my Lattissima was only 3 months old). The refurbished machine is currently on the way. We'll see if I have the same issue when I descale this one.
Thanks, Redfran
May 14, 2009 | Nespresso Lattissima 660.R
Nespresso Citiz C110 Logo
51 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
