Asko w620 sometimes the fabric softner will NOT take into machine, can you suggest solution?
  • 1,140 Answers
The easiest and cheapest solution is to use fabric softener sheets in the dryer and do not use the liquid fabric softener in the washing machine at all.
Posted on May 29, 2014
gittos73
  • 244 Answers
SOURCE: Fabric Softner section won't fully drain....
take your soap draw out pull the fabric softener tub out wash leave all of your soap draw in a bucket of hot water scrub with a brush this should clean a small hole which lets your conditioner out simply fix common fault m8
Posted on Aug 14, 2007
Buffalo12980
  • 625 Answers
SOURCE: Fabric Softner won't dispense
fabric softener goes into the dispenser. it may be a full blown solenoid valve -or- a flapper type of solenoid valve. operation of the solenoid operates a flapper to let the softener out. go to an appliance repair site to find the solenoid - appliance parts dot com or repair clinic dot com.
Posted on Sep 05, 2007
SOURCE: whirlpool duet fabric softner problem
According to the whirlpool FAQ's page, that is normal. They stated that at the end of the cycle, fresh water is used to clean the detergent holders. Not sure that I believe them though.
Posted on Dec 28, 2007
  • 3 Answers
SOURCE: Asko W620 washing machine not spinning
Sounds like the motor brushes need to be cleaned or replaced. Take the back off the washer, remove the motor and gently scrape the excess carbon or debris off the brushes with a pocket knife. I did this and it ran well for about 50 loads before building back up. I am ordering new brushes now because when I checked the brushes last week they were obviously worn more than 4 weeks ago.
Posted on Jan 21, 2008
murdozzz2
  • 75 Answers
SOURCE: Fabric Sofner won't dispense
hi there remove the soap drawer then remove the cover over the softener compartment you will more than likely find a blockage in the cover siphon or the down tube on the drawer
Posted on Feb 29, 2008
Fabric softener dispensing before wash begins
I was having the same problem. Repair man replaced VALVE AW
He told me it is from the sedement in your water. If you have a water softner, it may not be the problem, unless it is not working properly. Sounds strange, but problem is fixed.
Nov 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My Asko W620 washer won't spin the first time through.
Try Googling (asko)(W620)(manual) without parens.
Jul 22, 2017 | Asko W620
Water inlet valve problems
repairclinic.com has parts available.
Jul 31, 2008 | Asko W620
Asko 620 washing machine keeps filling
Sounds like your fill solenoid has stuck in the open position. There are 3 #20 Torx fittings along the back and you can lift off the top panel. The solenoid will be in the back left side.
I would shut off your house water supply to the machine and then do a voltage check to see if the solenoid is remaining energized. Another more simple option is to give the device a few light taps as some debris may have become trapped inside and caused it to become stuck open.
Jul 07, 2008 | Asko W620
Asko front loader washer w620
Check your motor brushes. They may need to be replaced.
Apr 19, 2008 | Asko W620
Feb 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dec 11, 2007 | Asko W620
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
