Question about Toshiba Satellite Pro L300 Notebook
No display there is power source and no display
    Scholar:
  • 46 Answers
You need to do some troubleshooting here to figure out what the problem is exactly.
1. On all Laptops there is a Fn key and one of the Function Keys at the top row that has a picture of monitors on them. Hold down the Fn Key then hit this monitor function key at the top, usually it's anywhere between I'd say F8 and F11 in most cases. Hit it one time, and wait to see if the monitor lights up. If it does not hit it again. You will want to do this at least 3-5 times and wait for about a good 10-15 seconds between each time.
2. If that does not work, then try hooking up an external monitor to the laptop through the Blue VGA connector on the back of the laptop. (Sometimes these connectors are on the side of the laptop) You can hook up any external monitor to this port assuming you have the right cable. Some laptops come with a White connector that looks different than the blue connector in that it does not have pins. This is called a DVI connector. Most newer LCD's are now converting to DVI connectors, but all LCD monitors can use the blue VGA connector cables. Note: You may have to use the Fn + FKey again to get an image on the external monitor. IF you do get a picture on the external monitor and the laptop appears to operate normally otherwise, then chances are your LCD is dead and is in need of replacement.
Fix 1: Inverter is bad or died - Depending on LCD this can range in price from I'd say $40-$150 to purchase if you are tech savvy you can fix this yourself.
Fix 2: Backlight has died or is bad - Depending on where you shop for it, this part is usually fairly cheap, and if you are savvy enough can be replaced at reasonably low cost.
Fix 3: You are not tech savvy: Take your laptop into a local PC shop, and have them check it out for a bad inverter, backlight, or to confirm rather or not the LCD is dead. Note: LCD replacements can run upwards of $300 or more. I've seen them go as high as $500.
Hope this information helps.
Posted on Jun 06, 2014
  • I forgot to note one more thing of importance: If you still get no picture from the "External Monitor" Chances are your video card is dead. You will need a Motherboard replacement to fix this on any and all laptops. This is often not worth the cost and you may as well buy a new laptop.
  • On rare ocasions failing ram can cause no picture to be seen, but if the PC sounds like it boots up normally, and you hear windows sound if any... chances are it is not failing ram causing the problem. Ram is cheap and easy to replace if this is the case.
White screen display
You may try this; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, and power ON the NB. If the laptop will not boot by doing this, take it to the nearest repair center to have it check for LCD issue.
Mar 16, 2011 | Computers & Internet
A white screen display on my laptop
You may try this; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, and power ON the NB. If the laptop will not boot by doing this, take it to the nearest repair center or contact ASUS (if in warranty) to have it check for LCD problem.
Mar 16, 2011 | ASUS LCD Monitor
I have a white screen display on my laptop. an asus laptop. tnx
Mar 16, 2011 | ASUS Computers & Internet
The display is blank the printer can off and on but nothing comes on the display
Good day!
POWER CYCLE
You may try this; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, and power ON the NB. If the laptop will not boot by doing this, take it to the nearest repair center to have it check for possible motherboard issue.
You may also try connecting an external monitor to check if the display will show. If it does, the problem is the LCD of your laptop and you need to take it to the nearest repair center.
Mar 13, 2011 | Computers & Internet
I my projector is new one used for 4 hrs, when i try to turn it on it just has a blinking green light. Please help Solve It! .
The blinking green light means the unit is either Powering On (Warming Up) or Powering Off (Cooling Down).
Powering On the Projector
1. Remove the lens cap.
2. Securely connect the power cord and signal cable. When connected, the ON/STANDBY LED will turn Amber.
3. Turn on the lamp by pressing " " button either on the top of the projector or on the remote. The ON/STANDBY LED will now turn Green. The startup screen will display in approximately 10 seconds. The first time you use the projector, you can select your preferred language from quick menu after the startup screen displays.
4. Turn on and connect the source that you want to display on the screen (computer, notebook, video player, etc). The projector will detect the source automatically. If not, push menu button and go to "SETUP". Make sure that the "Source Lock" has been set to "Off". If you connect multiple sources at the same time, press the "SOURCE" button on the control panel or direct source keys on the remote control to switch between inputs.
If you are still unable to get the unit to turn on, try unplugging it for 10 minutes and plugging it back in. If it still ceases to work, contact Optoma here: http://www.optomausa.com/rma_policy.asp
Their Technical Support line is 1-888-887-5001
Feb 25, 2011 | Optoma HD20 DLP Projector
Won't turn on at all the green light does not appear tv was turned off manually yesterday
The TV has two power status functions on the same button. First power on the Tv by pressing firmly on the power button displays a ready to use functionality where the TV may not necessarity display any thing on the screen just yet. Second, using the remote control by pressing on the power should display the ready signal screen like before. However, ascertain that the power cables connecting the TV to source of curent is not been disconnected along the entire circuitary. Check on the power outltet sources on the one aspect, and the connection side of the TV. Thereafter, the TV should be ready to be powered on by pressing.
Jan 17, 2011 | LG 37LG30 37 in. LCD HDTV
Screen is black except briefly blue upon power on or putting source on "VGA"
Your backlights power inverter board is what causes this prob. It is a Darfon V144-001.
Dec 30, 2007 | Sceptre NagaIII X30SV 30 in. HD-Ready LCD...
Toshiba Satellite Pro L300 Notebook Logo
35 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
