Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
AC unit is running, but the house doesn't get cooler.
I just installed a rth7500 about a week ago. Prior to this the AC worked great. The house cooled quick and the unit cycled on and off when needed. Since I put in the new stat the unit runs all day and the house does not go under 78 until about 11pm. I had a service guy out a few weeks ago to check the outside unit and everything was fine. I never had this problem with the last stat. Could there be a problem with the wiring? Any ideas? Thank you.
Chris
  • 139 Answers
A/c is either on or off,there no in between.check air filters make sure they are clean.also keep in mind a/c will only bring temp down about 15 degrees from outdoor temp
Posted on Jun 24, 2009
Swamp Cooler on top of my house will not blow any air out how can U fix it?
Did you check belt? Is motor running? If motor is not running replace after you ensure that the power is applied to motor. The motors go bad and it is not uncommon.
May 08, 2018 | Heating & Cooling
Why can't I lower my honeywell 8500 below 67 on cool?
With a two story house you have to be aware that cold air flows downwards so any cold air coming from an ac unit will flow downstairs( normally down the stairway) so unless you can close off the down stairs then the up stairs unit will be cooling downstairs as well. Ac units have a thermostat located in the air intake and it cools until the cold air has risen to that point. In effect the space above the ac unit will be hotter than the floor. Knowing how they work ,you can see that the upstairs unit will never reach the set temperature because the cold air is continually heating from the house and will never get to the top thermostat.
So your solutions are
1-- fit controls that restrict the cold air from leaving the upper floor (Doors)
2--don't run the upper ac unit unless you are living up there (waste of money
)3 place an ac in each upper room and keep the room door closed
Aug 12, 2014 | Heating & Cooling
I went downstairs to start a load of clothes and noticed water under my furnace. My A/C is running and I had it cleaned a few weeks ago and the unit itself had to be charged. It has run beautifully and...
Hello, most likey if the unit is cooling and there is no visible ice on the suction line then it is probably a cloged condensate line that will need to be cleaned.
Jul 11, 2011 | Heating & Cooling
I have a new kenmore ac unit model 580.75101500 i bought about two weeks ago and installed last week. its been blowing ice cold as it should no problems until today. Now the ac turns on runs about 5...
Take it back or call Sears. A 2 week old unit should not do that. I'll assume the settings are right like set on AC Auto or Max cool and not just fan. Are the coils icing or were they icing behind the filter? If not, I think it may need to be serviced.
Aug 07, 2010 | Kenmore Heating & Cooling
Ice build-up on GE ZDW24A wine cooler cooling coil
Probably the thermostat is bad , you can bypass it by putting together the two wires from the thermostat and if the unit starts working ,replace the thermostat ;only do this if you havesome knowledge of electrical work and be very carefull.
Nov 04, 2009 | GE ZDW24A Wine Cooler
Thermostat just stopped working.
is the tstat in cool mode? if not hit the mode button untill cool pops up then hit the down airow untill desired temp. sometimes the thermostat has a 5 min delay so be patent. If unit still does not run call the service co. and find out about how long they warranty their service call. usualy one month.
Jun 14, 2009 | Honeywell Electronic Programmable...
My heat pump won't cool my house. I have a honeywell rth7500 programmable therostat. It is blowing cool air out of the outside unit and the lines are normal temp.
Warm air should be blowing out the outdoor unit. Have a technician evaluate if the compressor is functioning. There are many reasons why the compressor is not working. One of them being a start capacitor not working. Another being out of Freon due to a leak. Good luck
Apr 25, 2009 | Honeywell Electronic Programmable...
Replacing pads
How do I replace a rigid pad on my Mastercool swamp cooler?
May 22, 2008 | Mastercool 67680 Evaporative Cooler Air...
Heating & Cooling Logo
365 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
