Question about Smeg A2.5 Dual Fuel (Electric and Gas) Kitchen Range
Brightness of the light - Smeg A2.5 Dual Fuel (Electric and Gas) Kitchen Range
How can I increase brightness on head light of my super splendor model 2011?
aim the light correctly
indicates that it aimed to high up into the he trees instead on along the ground
Nov 29, 2017 | Cars & Trucks
Picture gets darker when light in room is turned off!
The "auto" illI nation is turned on so it will dim when the lights go down so the unit is not too bright. You can adjust the brightness when the lights are on which shold also effect the brightness when the lights are off or turn off the auto-brightness control.
Nov 26, 2016 | Televison & Video
How do i turn light on or off
If you're referring to your display brightness, you can control this in your Settings. Use the Settings App and Open the Brightness &Wallpaper menu. Select the brightness level on the slider and flip to auto-brightness if you like. This will adjust brightness based on ambient lighting detected by your front-facing camera. If that's causing you problems, disable the auto-brightness and just control it manually from the slider.
Mar 29, 2014 | Apple iPhone Cell Phones
The picture is very dark and want to brighten it
If your keyboard doesn't have a brightness control button (mine is F6), open System Preferences and click on the Displays control panel. Move the brightness slider to the right to increase brightness. If you don't want the computer to automatically adjust brightness uncheck the box next to Automatically adjust brightness as ambient light changes.
Dec 26, 2013 | Computers & Internet
Light flicker
The power supply to the lights may share a circuit with some appliance such as a microwave or refrigerator. The flicker is more noticeable at high brightness but probably occurs at lower brightness as well
Jun 11, 2013 | Kitchen Ranges
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.)
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor.
Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
Brightness and contrast symbols
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
1992 ddome light would not go off
DOME LIGHT STAYING ON BECAUSE YOU HAVE BAD DOOR SWITCH OR BRIGHTNESS SWITCH ON HEADLIGHT SWITCH THAT CONTROL DASH BRIGHTNESS AND IF BRIGHTNESS SWITCH IN FULL ON POSITION ON HEAD LIGHT SWITCH IT WILL CAUSE DOME LIGHT TO STAY ON.
Aug 11, 2011 | 1992 Buick Park Avenue
I could not find where i can increase the light
You must find the 'brightness' control. Usually there are buttons on the front of the monitor. You push the left button, move over one button, select brightness, move over one button, and adjust the brightness.
Apr 20, 2010 | Compaq iPAQ Legacy-Light PC Desktop
Back lights are dim on speedometer, odometer
You probably checked this, but sometimes we forget.
The dial on the dashboard to the left of the instrument panel controls the brightness of the instrument panel lights. Turn the dial to adjust the brightness. Also, to reduce glare at night, the fuel and temperature gauges dim when you turn on the parking lights or headlights. You then adjust their brightness when you adjust the instrument panel brightness.
Turn the dial up as far as it will go to return the fuel and temperature gauges to their daytime brightness.
I hope helps and it's that simple for you.
Nov 03, 2009 | 1996 Honda Prelude
How can I lower the brightness of my screen in my Dell 1525 lapto
Sometimes the brightness is on the arrow keys hit the Fn or function key and press down on the arrow to dim the light or press up on the arrow key to increase brightness
Jul 28, 2009 | Dell Inspiron 1525 Laptop
Smeg A2.5 Dual Fuel (Electric and Gas) Kitchen Range Logo
18 people viewed this question
Top Smeg Kitchen Ranges Experts
ashburton
Joseph Mueller
Joseph Mueller
Your Consultant
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
